Hallo Guys
i took a backup from my KRC4 Robot and i am trying to restore the file back but i am always getting an error message that the file does not exist
actually i only have the same backup i took from the Robot and im trying to restore it back without success
i dont know why it is not working
the file Name on the Archive is thesame.
thanks in advance
Restore Backup
maxwell -
October 3, 2016 at 3:20 PM -
Where is the file located? And which menu option are you selecting?
what is the content of your backup? one can create archive that only contains log files...
Actually its a complete Backup i am trying to restore.
the file(Archive) is located in my usb stick.
and its the only file on the stick. -
Are you selecting Restore from USB on the menu? Has the name of the file been changed from what it originally was?
yes im selecting restore from a usb on the menu.
The Name actually is thesam. that is the more reason i am so confused. -
you still did not clarify what exactly are you trying to restore from... is it an ARCHIVE or BACKUP? (they are not same things)
its an Archive. is there somewhere in config dat where i can Change the Name of the Robot ?? maybe thats the Problem
thanks in advance -
Go restore archive mwke sure
A. no program is selected
B. You are logged in as expert
C. Archive is for the right robot (same serial number, kss version etc)
D. Archive has right name and path
E. You are restoring from correct path (USB on cabinet)
F. Reboot ( cold start with reload files)
