Stop Spindle at Robot Stop for program error
  • Marco
  • August 4, 2016 at 6:10 PM
  • Marco
    116
    Hi there,
    I generate my milling programs from Sprutcam and sometimes it generates duplicated points or circles with middle point equal to start point (I found how to fix this last). I'm actually developing a little code to check the .src file before loading it to the KRC, however I would like to develop a safety function that stops the spindle whenever to KRC stops the program for an error within the code. At the moment, like in the cases I mentioned before, I get the KRC stopping the motion and enabling brakes, but the spindle keeps running, which is really dangerous. How and where can I set an instruction that switches off the spindle as well if the KRC stops the program? Any help is really welcome.
    This is my SPS:
    DEF sps( )
      ;FOLD DECLARATIONS
      ;FOLD BASISTECH DECL
      ;Automatik extern
      DECL STATE_T STAT
      DECL MODUS_T MODE
      ;ENDFOLD (BASISTECH DECL)
      ;FOLD USER DECL
      ; Please insert user defined declarations
      ;ENDFOLD (USER DECL)
      ;ENDFOLD (DECLARATIONS)
      ;FOLD INI
      ;FOLD DEFAULT MSG_T
      $MSG_T={MSG_T: VALID FALSE,RELEASE FALSE,TYP #NOTIFY,MODUL[] " ",KEY[] " ",PARAM_TYP #VALUE,PARAM[] " ",DLG_FORMAT[] " ",ANSWER 0}
      ;ENDFOLD (DEFAULT MSG_T)
      ;FOLD AUTOEXT INIT
      INTERRUPT DECL 91 WHEN $PRO_STATE1==#P_FREE DO RESET_OUT ()
      INTERRUPT ON 91
      $LOOP_MSG[]="                                                            "
      MODE=#SYNC
      $H_POS=$H_POS
      ;Automatik extern
      IF $MODE_OP==#EX THEN
        CWRITE($CMD,STAT,MODE,"RUN /R1/CELL()")
      ENDIF
      ;ENDFOLD (AUTOEXT INIT)
      ;FOLD USER INIT
      ; Please insert user defined initialization commands
      ;REMOTE PENDANT INITIALIZATION
      $OUT[5] = TRUE                ;+24V to pendant
      $OUT[6] = FALSE               ;Resume Pendant LED (white)
      $OUT[7] = FALSE               ;Stop Pendant LED (white)
      $OUT[8] = FALSE               ;Reset Pendant LED (white)
      $OUT[9] = FALSE               ;Communication LED (blue)
      $OUT[17] = TRUE               ;TOOLCHANGER EV A (LOCK)
      $OUT[18] = FALSE              ;TOOLCHANGER EV B (UNLOCK)
      ;ENDFOLD (USER INIT)
      ;ENDFOLD (INI)
      LOOP
         WAIT FOR NOT($POWER_FAIL)
         TORQUE_MONITORING()
        ;FOLD USER PLC
        ;Make your modifications here
        SC()              ;call custom subprogram
        $OV_PRO = 100-(99*$ANIN[1])  ;Robot override (pot)
        ;ENDFOLD (USER PLC)
      ENDLOOP
      ;FOLD ;%{H}
      ;FOLD
    END
      ;ENDFOLD
    DEF  RESET_OUT ( )
      INT N
      $LOOP_MSG[]="                                                            "
      IF REFLECT_PROG_NR == 1 THEN
        FOR N = 0 TO PGNO_LENGTH - 1
          $OUT[PGNO_FBIT_REFL + N] = FALSE
        ENDFOR
      ENDIF
      IF (PGNO_REQ>0) THEN
        $OUT[PGNO_REQ]=FALSE
      ELSE
        IF (PGNO_REQ<0) THEN
          $OUT[-PGNO_REQ]=TRUE
        ENDIF
      ENDIF
    END
    ;FOLD USER SUBROUTINE
    ; Integrate your user defined subroutines
    and this is my security check sub:
    DEF SC( ) ; -- This Subrutine is ment to start running from system startup and check all security systems and external sensorsSC
      ;FOLD DECLARATIONS
      ;FOLD USER DECL
      ;ENDFOLD (DECLARATIONS) ; Declare the variables
      ;FOLD INI
      ;FOLD USER INIT
      ;ENDFOLD (INI)
    ;HSD_ALBERO_FERMO=$IN[3]    ;Check if Spindle is running
    ; RELEASE CONE WHEN HSD_BUTTON IS PRESSED
      IF $IN[4] == TRUE THEN
        PULSE($OUT[1], TRUE, 1)         ;OPEN VALVE
        PULSE($OUT[9], TRUE, 1)         ;COM LED ON
      ENDIF
    ; REMOTE PENDANT FUNCTIONS
      IF $IN[9] == TRUE THEN   ;PAUSE BUTTON
        $OUT[7] = TRUE         ;PAUSE LED (RED)
        $OUT[6] = FALSE        ;RESUME LED (GREEN)
        $OUT[10] = FALSE       ;FILEDBUS REFERENCE VALUE ENABLE
      ENDIF
      IF $IN[10] == TRUE THEN  ;RESUME BUTTON
        $OUT[7] = FALSE
        $OUT[6] = TRUE
        $OUT[10] = TRUE        ;FIELDBUS REFERENCE VALUE ENABLE
      ENDIF
      IF $IN[11] == TRUE THEN            ;RESET BUTTON PRESSED
          PULSE ($OUT[8], TRUE, 3)       ;LED ON
          PULSE ($OUT[11], TRUE, 1)
      ENDIF
    ;--TOOLCHANGER CONTROL
    ;$OUT[17] = TRUE     ;EV A STAY LOCK AT START UP
    ;$OUT[18] = FALSE    ;EV B RELEASE WHEN TRUE
    ;-- CHECK IF EMERGENCY BUTTONS ARE HIGH OR LOW AND TAKE ACTIONS
        $OUT[2] = NOT $ALARM_STOP        ;Switch on E-Stop Led
        $OUT[3] = NOT $ALARM_STOP        ;Switch on E-Stop Led (pendant)
        IF ($ALARM_STOP==FALSE) THEN ;   !!!When it is false there is an emergency stop breaking the circuit!!!
           HSD_LOGIC_SET = 5
           HSD_SPEED_SET = 0
           WAIT FOR HSD_SPEED_IN < ABS(50)
           HSD_LOGIC_SET = 0
        ENDIF
      ;FOLD USER PLC
        ;ENDFOLD (USER PLC)
      ;FOLD ;%{H};
    END
      ;ENDFOLD
    ;Integrate your user defined subroutines
      ;ENDFOLD (USER SUBROUTINE)
    Kuka KR150-2 KRC2 ed05 V5.6.11<br />VFD TDE Macno<br />Spindle HSD ES915 with Automatic tool changer<br />Sprutcam 11
  • SkyeFire
    1,044
    9,391
    • August 4, 2016 at 10:47 PM
    $PRO_ACT is the system variable that should give you what you want. You could also look at $STOPMESS, $ALARM_STOP, and $PRO_MOVE. But I suspect $PRO_ACT will be what you want.
  • Marco
    116
    • August 5, 2016 at 9:42 AM
    Thanks, I will need a combination of these variables to address several cases actually.
    BTW, scrolling the pages of the System Variables manual I found this $MSG_T.ANSWER and I was hoping it would show the number of the STOP softkey button on the KCP. I could also use this with something like
    IF ($MSG_T.ANSWER == thenumberoftheKCPstopsoftkey) then
      stop spindle
      bla bla
      bla bla
    endif
    but setting the variable in the single variable monitor it did not show anything while pressing the stop softkey. I tried while a program was running. Did I do something wrong?
  • SkyeFire
    1,044
    9,391
    • August 5, 2016 at 2:40 PM
    No, that variable only comes into play when your program posts a Dialog Message to the pendant -- the message type that puts a number of option buttons along the bottom row (max 7). $MSG_T.ANSWER just provides the number of the button that the operator pressed.
  • Marco
    116
    • August 5, 2016 at 6:03 PM
    Got it. As the $PRO_ACT shifts from TRUE to FALSE when you press the RUN or STOP softkeys it solves this aspect. That's very useful to link actions to this softkeys.
    :beerchug:
  • robot-cnc
    10
    414
    • July 8, 2017 at 2:52 PM
    Hi Marco !
    I am interested how you solved error in program code when middle point equal to start point.
    I met same issue and the robot stop at that error.
    Thank you.
  • Marco
    116
    • July 8, 2017 at 3:13 PM
    If you program your paths with Sprutcam you have to tune the tolerance setting. Very little values (i.e. 0.001) produce this problem. I solved the issue with 0.025. Otherwise you can avoid arcs, but then your programs files might become too large and you could run into memory issues.
  • robot-cnc
    10
    414
    • July 9, 2017 at 6:17 AM
    Thank you. I will try that.
  • Marco
    116
    • July 9, 2017 at 12:31 PM
    Actually, my last setting is 0.05. This completely solved the issue.
  • Wall-E
    245
    • June 10, 2018 at 12:14 PM
    Hi Marco,
    Could you post the code where you use the $PRO_ACT variable to shut down your spindle and explain where it should be located ?
    Thanks ?
  • SkyeFire
    1,044
    9,391
    • June 12, 2018 at 2:55 PM
    • #11
    Simplest place to put it would be the User section of the main SPS loop. Something like
    IF O_SpindleOuput AND NOT $PRO_ACT THEN
      O_SpindleOutput = FALSE
    ENDIF
  • Marco
    116
    • June 14, 2018 at 11:41 AM
    • #12
    Hi Wall-E,
    In my system folder I customised the SPS as to load a sub that performs several checks. Among these I have:
    ;-- CHECK IF THERE IS A "STOP MESSAGE" DURING EXECUTION
     IF ($OUT[1010] == TRUE) THEN ; CHECK $STOPMESS STATE
       HSD_LOGIC_SET = 5
       HSD_SPEED_SET = 0
       HSD_LOGIC_SET = 0
     ENDIF
    This stops the spindle in the case of the mentioned errors (the specific lines depend on your spindle I/O setup) and if I press the stop softkey.
    Best,
    Marco
