Good evening to all. please help ... how can copy a program made by me with the pendant dx 100 in computer?
or how can I run a same program in several positions on the x axis ( translation ).
I use an external station which unfortunately has never position at the beginning of the program.
I do not know how clear I was but I can make an example:
made computer program such as a circle with a diameter of 50 mm and a program made by me but also a circle with a diameter of 100 mm.
I would like to run program made by me in the same position on the x axis ( translation ) where the computer program runs .
that is to stick two programs made at different points in my case the final program being two concentric circles.thank you.
please help me
mihaita -
June 15, 2016 at 9:27 PM -
Hi mihaita
Welcome to the robot-froumYou are asking to many questions
Save the program in a usb stick and open your program using an editor on your computerhow can I run a same program in several positions on the x axis ( translation ).
Are you using P points ? P variables ?
Are you using relative job option ?
Do you have a user frame defined for these points ?If you dont, if they are just "regular" points, they are based on pulses so you can not use mm
thank you for the answer.
use the shift function
buna ziua.
reprezentanta Yaskawa pentru Romania este SAM Robotics si suntem in masura a va da toate aceste informatii
cu stima
