My company just bought a FANUC 430Si (USED), and we just installed it, connected all the cables as they were labled, and we now have a SVO ERROR 232 NTED INPUT showing up on the screen. I do not have a manual of any kind to reference this error. Can anyone help me with this?
robot Joe -
June 15, 2016 at 4:18 PM -
http://www.linuxsand.info/fanuc/code/SRVO-232
Cause: The NTED (non-teacher enabling device) was detected.
Remedy:
1. Press the NTED (non-teacher enabling device), and then press RESET.
2. If this alarm cannot be reset, refer to the Controller Maintenance Manual for more information.The NTED is just a deadman on a cable, usually used to allow a programmer and a non-programmer to work in the cell together safely. With a robot that old, I am not sure if it would be a single channel or double channel connection. You will have to find where it lands, and then jump the connection(s) together.
Hopefully some else here can help out on the connection.
I've seen this fault a lot with bad teach pendant cables. Are there any other alarms showing? Was the controller configured to be PLC controlled?
We have a couple of router cells that tie the door switches to the NTED input, so both doors must be fully open before robots can be manually driven.
Thanks for the help...I was able to clear the fault.
