I have kuka KRC2-360 , windows is XP , KRC is 5.4.14
I need I/O for move robot , When turn on cabinet connect signal LED is off but Run and I/O Run signal LED are ON.
now don't see Input ,
please help me .
what can I do ? for solve problem .
how I do connect wago 750-306
km427 -
June 13, 2016 at 8:30 AM -
Give image wago
I hasn't Image of WAGO .
How can I install WAGO ? I need software
How can I purvey WAGO software ?
Send IOSYS.INI and your DEVNET.INI
please send me download link for install Wago 750-306 .
Do I must need install WAGO software ?
no . write what you already did that? Top shoot weigh as it is connected.
The attached manual should clear up most issues but here are a few pointers for what they are worth
1) the devnet.ini file set the baudware an Mac ID , this must match the dip switch settings on the wago 306
2) Use method 2 in the examples. At some point along the way method one stopped being supported. the driver is dn2drv.oThe number in front of the value is the Wago 306 Mac ID in a line like INB=13,0 13 = mac ID
When they refer to Form 1 or Form 2 they mean format or method
If it does not work right away just start off with 1 input block and 1 output block. Once you get it working then things will start to make sense
(panic mode - fixed formatting issue)
My Bad
It looks like I uploaded a prohibited document.
Mea culpa. -
Hi
Thank you for help me.
I'm trying to do this exact same thing and have set the baud and macid in the devnet.ini.
I think the addresses need setting but not sure where or how to do it?
any such info is very well guarded and only revealed to high priests and wizards... whatever you do, don't google 750-306 manuals or check old posts here. it may bring bad luck, drought or mummy curse.
