I need to know how to reset the hand broke to enabled on our rj3ib. we replaced the wire and it shows presence when metal is passed under the sensor, but still shows error srvo 302 on the pendent and I cannot get it reset. any help is appreciated
fanuc rj3ib error srvo 302
erik b -
May 3, 2016 at 1:58 PM -
First, try to reset the handbroken by pressing SHIFT + RESET and DO NOT RELEASE SHIFT. Then, you should be able to jog the robot.
Second things, if you have a safety wrist, check if it is at the reset position (sometimes, the arm of safety wrist, roll and become fully inactive.).
Third, if you want to Fully Disable the Handbroken, go into MENU-SYSTEM-CONFIG, the variable is there.
Thank you for the info. I tried all of these options before posting here. Ended up replacing wire and plug which took care of this problem but created another. I figured the other out. Thank you for the help!!
Lerak;
Disable the Handbroken any damage for robot? I'm asking to learn.
