KSS26158 error at KRC4
  • DraganV
  • March 29, 2016 at 3:50 PM
  • DraganV
    Hi guys,
    We have robot KUKA KR360 with linear stage KL1500. Robot controller is KRC4.
    Recently we meet the following error: KSS26158 Common brake error (Servo) (E1), Originator: Drive.
    I can find any information for this error.
    Does someone had same or similar issue before? Any information is welcome.
    Thanks,
    panic mode
    1,278
    13,079
    • March 29, 2016 at 4:55 PM
    check brake circuit connections, make sure that no contact is burned, bent, loose, pushed out etc. usually this resolves problem. in some cases new drive/motor may be needed as well.
  • DraganV
    • March 29, 2016 at 5:11 PM
    Thanks for fast response.
    We checked brake connection and seems to be all ok. Is it possible somehow to temporary disable this monitoring?
    Regards,
  • kosgga
    19
    • March 29, 2016 at 9:55 PM
    check the motor cable and check also drive configuration in workvisual..are the cables connected right in drive confıg
