People help to run the KUKA KR10R1100sixx
Does not work in automatic mode.
Error :
(SYS-X44) error during ECat stack initialization
KSS13012
KSS00001
KSS00099
Not connected connector X55
KR C4 compact
vadim -
March 22, 2016 at 1:31 PM -
if your KRC4 has built in I/O and X55 connector, you must wire X55 - this is how I/O get powered up. check manuals section on this forum for details
what is the meaning of the error KSS13012
KSS00099 -
KSS00099
what is your I/O configuration and does it match physical setup. is the KEB topology correct?
open two quarter-turn latches and look inside cabinet. you should see X44 cable going to EK1100, then another cable going from EK1100 to X65 (if you have I/Os in the cabinet). another thing to note is rest of the modules, normally EL1809 and EL2809 for 16/16 setup. for 16/24 setup, you will have EK1100, EL1809, EL2809, EL9xxx (not in configuration) and EL2024. Something like this:
ECat driver could not be initialized because of project and hardware mismatch...
Как я понял нужно обязательно присоединиться к X65?
hello. From pictures you have no power supply on beckhoff coupler.
Не совсем понял, на какой разъем не хватает?
your robot came with documentation... i would recommend to:
1. find DVD labeled parts and docs (it is inside big white paper envelope that says "STOP - only open if you agree with...")
2. use it to find manuals related to your system
3. explore manuals section of this forum
4. only when all of above fails (and you did put in own effort), ask for detailed help
