Can anybody help me? I need to modify entire robot program by a tool offset, for example 100mm...some position are register, some are local..how can i do IT without modify tool?
Position register with tool?
Bulo -
March 15, 2016 at 8:59 AM -
Add a Tool_offset instruction at the end of each of you're motion instructions and set the PR value used with the tool_offset to your offset values (keep in mind that it is tool coordinates offset).
example:
1056: UTOOL_NUM=2 ;
1058:J PR[5:ueber Palette 2] 100% CNT50 ACC150 ;
1056: UTOOL_NUM=1 ;You create/copy(UTOOL 2) new user tool with the required offset.
