It seems to me that some functions are defined in MMC, and I wonder is there any way to see the contents of these functions.
Besides, is there any manual helpful to understand stuff written in MMC file? I don't know where to find explanations on things such as MMC_REAL_PARAM and MMC_REAL_DATATYPE.
What is defined in MMC.cfg?
plutoyouyou -
March 2, 2016 at 3:22 AM -
In this file are defined the parameters of the external devices like a welder equip, but wait other user confirm this
MMC mean Man Machine Communication.
It is used to configure the way instructions and routines appear when you are programming. For example you can hide a routine, so the operator can't call from the pendant.
In S4 it was used for some TPU configuration also. -
In S4 it was used for some TPU configuration also.For routines that are set to hidden in MMC, are they defined in some encrypted modules?
Possibly yes.
Not exactly, you can hide any routine independent if it's encrypted or not.
Please see example below:
-name "MeasureWearL"\
-default_struct 1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0What are the numbers defining? I found some instructions that ha the same values as in:
-default_struct 1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0and
-name "DressL"\
-default_struct 1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 -
This defines which argument should have proposed value.
0 means no proposed value.
1 means use proposed value.In real it's used when you add this instruction using FlexPendant.
Arguments with 1 automatically receive a proposed value. Most of the time the last value you entered.
Arguments with 0 will appear blank, so you need to change the parameter manually.
