Setting up KRC4 Master Reference Switch
  • siege342
  • January 6, 2016 at 9:24 PM
  • siege342
    13
    I have been through KRC2 programming class, but this is my first KRC4 commissioning, so all I have is KRC2 references.
    My issue is: How do I go about setting up the Master Reference switch? I have the switch and actuation plate mounted.
    My KRC2 manual references R1/TP/SafeOperation/MasRefReq.SRC , but the SafeOperation folder is not present in my controller, but SafeOperation is installed (and configured as far as I can tell). I'm not sure withing which program I am suppose to be teaching the reference point to.
  • panic mode
    1,296
    13,137
    • January 6, 2016 at 10:27 PM
    like on KRC2, all software on the controller has installation files on D: and each option will have documentation there as well.
  • mhasman
    82
    • January 7, 2016 at 1:30 PM
    Hi!
    First - Install the tecnology in your controller.
    Second - After install, will appear inside the System fold the module masref_main and masref_user.
    The module masref_user you will insert the moves from for example Home until Masref Position, the masref_main is used to execute main routine that make the full process.
    I hope I've helped!
    Sorry my bad inglesh!
  • siege342
    13
    • January 7, 2016 at 5:50 PM
    masref_user.src was what I was looking for. Mastered the first time. :beerchug:
    Thanks guys
  • mhasman
    82
    • January 9, 2016 at 12:51 AM
    :bravo:
