We have KRC4 V8.3.7
We are trying to load some massive milling tool path that includes SPLINE commands.
It seems that when we added the SPLINE command the memory usage raised significantly.
When trying to run the program we've encountered the following ERROR:
"Spline: No physical memory available, cold start required."
We did some optimization in the code that it will allocate the minimum memory (moving arrays to global $config) in order to try and fix it, and last week i tried running our program with the SPLINE commands and it ran perfectly with no errors.
But, today, the same error occured again when i started up the KRC4.
Same code, same program.
Anyone has any ideas how to solve this? Even if you don't know how to solve this please try and elaborate on the possible reasons for this issue - maybe it will drop a few coins
Also - How can i see the actual current physical memory usage?
THANKS!
