hi everybody
ı have robots with krc4. when ı power off the robots, programs resetting automaticly. but ı want robots continue the programs after power off. what ı must do?
program reset after power off
basbasan -
November 17, 2015 at 1:25 PM -
I guess you should use Hibernate mode as a shutdown type so that the controller will reboot from the same event. It is Windows property which helps the computer to start from the same restore point keeping all the applications intact.
You can choose option after login in Expert or Administrator following the path:
File>Shutdown>Hibernate
Program is resetting after power outage even though shutdown mode is in hibernate.What should be the problem?
I am facing same issues please let me konw anyone other setting or way
Can you share 1 photo of
Menu > Shutdown.
