Can anyone point the way to some Panasonic Weld Robot Programming Training?
I have thorough experience with Fanuc, and some with Motoman. However, my new company have an dinosaur Panasonic VR-008 with G2 controller (Greeen screen). The language looks similar to current Panasonics. However, my knowledge with Panasonics is barely above 2nd Grade.
I can Trace programs, Touch-up points, edit calls to run new programs, etc... However, if we get a new part for this robot I am SOL.
Panasonic Training?
holmes1997 -
November 13, 2015 at 4:02 PM -
Look into this. MWA is the source for Panasonic training
https://reg.abcsignup.com/view/view_mont…&aid=MEM&wp=264 -
Good day sir .... for setting counter in the robot panasonic GII or GIII let appear on the monitor how ya do ....?
program : ....
SET LI001 = 0 (Set 0 to variable LI001)
SET GR002 = 0 (Set 0 to variable GR001)
INC LI001 (Increment the value of LI001 by 1)
ADD GR001, 2 (Add 2 to variable GR001)
....monitor : View --> Display change --> Display variable --> Integer (or Real)
change value : Set --> Variable --> Integer (or Real)
Thank you very much sir on his direction ....
Sent from my ASUS_Z00RD using Tapatalk
good afternoon sir yes sir ... ohh .... sorry sir I ask again ... that make the program create a button how sir? for panasonic GII. because if I change its operation to continou, operators quickly lose the same robot guidance please sir ...
connect opetation button to I/O terminals User-IN001.
at the begin of program, add : WAIT_IP I1#(001) = ON -
Thank you very much sir, for helping
good evening sir, to counter setup I have tried but they failed to create .program: .... SET LI001 = 0 (Sets 0 to variable LI001) SET GR002 = 0 (Sets 0 to variable GR001) LI001 INC (Increment the value of LI001 by 1) ADD GR001, 2 (Add 2 to variable GR001) .... monitor: View -> Display change -> Display variables -> Integer (or Real) change value: Set -> variable - -> Integer (or Real), for the program for this counter setting input into the program at the beginning or at the end sir. I should have asked for an example of the program to enter sir.
if to counter can already appear sir but the counter is not running although robots have completed the process still rates still at 0
Ok, GR001 = counter
at the end of program : ADD GR001, 1 (add 1 to counter)
monitor : View --> Display change --> Display variable --> Real
to reset the counter : Set --> Variable --> Real
thanks sir ..... I'll try again.[emoji1]
Hello sir .... thanks for the guidance that has been given to me , everything has been running smoothly . There is one more thing I want to ask sir , if I want to add additional devices such as PLC 's , do I need to register for a robotic device before the signal I/O I plug in one program .... sir ? ... Excuse me sir if I ask many questions ....
these status input/output and user input/output are ready to use
Thank you sir , if the OTC or protecting nachi right to know the level of user or beginer , experts , specialists and integrators to pasword.
What in panasonic also there like that or just passing user id that alone sir for robot models in the password .... ?Sent from my ASUS_Z00RD using Tapatalk
Only users of the system administrator level can set, change and delete all parameters.
Thank you sir ... for his guidance , I hope that the father of science has also increased and growing , amen ....
Hi , there are some problems with my Panasonic robot AW005cl after the relocation Recently ,
I have a panarobo AW-005cl. When i turn on servo. Robot display error : " A6110 encoder batt Err0001".
Please help me! Thanks -
Ok, GR001 = counterat the end of program : ADD GR001, 1 (add 1 to counter)
hello sir .... I want to ask panasonic robot GII often Alarm A4010 safety warnings holder when the gun or the robot head not hit anything .. if there is a problem in the sensor or there are other constraints yes sir ...? yes sir please help ... thanks in advance ...[emoji4]Sent from my ASUS_Z00RD using Tapatalk
A4010 xxxxxx ------- what error message you have ?
