Does anyone know what system variables have to be changed in order to get a 2000iA with an RJ3iB GM controller to cycle start from the SOP?
Menu>system>config remote/local setup = local
Sent from my VS985 4G using Tapatalk
Thanks but I had already done that. I think it has something to do with $shell_cfg
What is your prog select set to?
$remote_cfg.$Remote_type
1 is local (sop)
Every time I put this to 1 it sends the unit back into remote. I check the config and it says Local. Entering a 1 puts it into remote. Still no luck cycle starting starting this one with SOP. Any other suggestions? This unit is running version 6.40 XA-X. It is the only one I cant get to work!
Select is set to Other and UOP like the robot next to it which works fine on an older version of software.
