Hello guys, does anybody know how to reset faults from remote? I used "enable UOP signals" but it enables all the signals (for example, IMTS stop) but I only want to use the reset from remote
Reset fault
Bulo -
September 29, 2015 at 9:18 PM -
You can still use the UOP signals. Set the IMSTP to Rack 35 Slot 1 Start 1 for an "always ON" setting. (and any others that need to be ON, like HOLD, etc.) You can then use the Reset input for remote reset. Be aware that some faults have to be reset at the pendant.
Hello guys, does anybody know how to reset faults from remote? I used "enable UOP signals" but it enables all the signals (for example, IMTS stop) but I only want to use the reset from remoteHow are you starting production right now? Locally?
Yes, locally...the customer wants local start cycle but remote reset fault -
Good idea! I didn't know Rack 35 was a always ON signal...thank you so much I'll try it -
DaveP ; thank you for description...
