Hi
In the main program i wrote this instruction ( PulseDO\PLength:=0.5,INDEX_UNLOCK;) when i execute this program sometimes INDEX_UNLOCK output cant change to zero its fix to 1 .
the controller is s4c+ with irb2400 .
where is the problem ?
pulse output
ELECOMP -
December 11, 2014 at 8:38 AM -
Could you check your signal is zero before pulse command?
yes,I check it , it's zero
To clarify the problem, which of these two do you mean?
1. Upon executing the PulseDO command, the signal changes from 0 to 1, but will not return to 0.
2. Upon executing the PulseDO command, the signal is ALREADY a 1, and will not pulse. -
Maybe there is a setting command for the signal in the following code.
