Hey everybody; Matt here.
Is there a way to copy and paste a series of in-line forms and re-use the same exact point names? When I do the paste, new points are created. I was hoping to use the same points over so if touch-up is needed, only one set of points would need to be adjusted; not every set of points. Makes sense?
I know I can manually go into each in-line form and re-assign the original point name. There are lots of lines so I was looking for a way to avoid all the editing..
