Hello All;
I have to turning off "simulate" signal function on T1 and T2 mode.
Is that posssible and how to?
KSS 5.6.8
Hello All;
KSS 5.6.8
Should be the system variable, um.... $IOSIM_OPT? $IO_SIM_OPT? Something like that....
Thank you SkyFire;
I have been found $IOSIM_OPT variable on KUKA system variable manual, but I don't have "$operate.dat" file. Do you know where is the variable declaration? I don't checked "Variable->Single" on robot.
I am not sure, but $Operate.dat is not a file. It means its a system variable that u can use. In fact, every variable in the manual showing $operate.dat can be use, but not found in a specific file.
Sims
Hello,I am not sure, but $Operate.dat is not a file. It means its a system variable that u can use. In fact, every variable in the manual showing $operate.dat can be use, but not found in a specific file.
Sims
Thank you.
You are right.
