Hi all,
I have an m710iC robot with only the EE cable that runs through the arm. The 8 RI/RO are not enough for my tool. I know there are robots with an ap1 and as1 cable through the robot.
Is it possible to put an extra cable in the arm? From the base to axis 4 (next to EE plug)
Thx
Extra cable through robot arm
TRBe -
March 11, 2014 at 3:50 PM -
Yes, it is probably possible, but FANUC will not honor your warranty if you change the internal cableset without approval. You're probably better off running the cable externally.
I did this once on a S-500 robot, and there was in some places not enough room for an extra cable.
So I changed the original cable with another with more leads (36 x 0.34) witch is only a litlle bit bigger, and that worked (and still works) fine.Be sure to buy a good quality cable, and keep the routing of the cables and hoses exactly the same as it was !
I have seen M710ic robots with AS1 and AP1 cable, I've opened the side plates and it seems to have enough space left to put some extra cables.
I have contacted Fanuc about this I will see what they have to say and post it here. -
Why not use the existing passthru between 24-pin ASi connectors?
What do you mean with existing passtrough? I only have the EE cable in the robot arm.
