Hi all.
I have a krc4(kss 8.2) I want to see IO signals on my PC. Because I can't catch situation of the IO. The screen of smartpad is too small. I must see all 20 signals at the sametime..
LG-D802 cihazımdan Tapatalk kullanılarak gönderildi
Hi all.
Can't you see them if you put the IO you want to monitor in the variable monitor?
Sent with Tapatalk.
Variable monitor? I want to see them external monitor..
Have you figured how to do that. I want to do the same.
Take a look at the software option KUKA.EthernetKRL, with this option you can send and receive data over TCP/IP or UDP/IP in XML or RAW data format. I have attached the official documentation.
Unfortunately in KRC4 is not so easy to give additional monitor, like in krc2.
This is because smartPad is not a just panel, it is a computer which logs in, as external desktop on KRC.
I heard from KUKA that there will be an option or a package for that, but not yet.
