Ethernet/IP Configuration
  • mcnealweld
  • November 12, 2013 at 1:18 AM
  • mcnealweld
    Guest
    I need some advice. I am using an i30B controller and Im trying to configure my I/O. Im connected to a Turck BL20-GW-EN-IP I/O module. I have given it an IP address and configured the scanner. But it keeps telling me its offline. The robot cant see the I/O. But I can ping it from the robot, and I can ping it from a pc. I have even tried a new ethernet cable from the robot to the module. Any suggestions would be greatly appreciated.
  • Sergei Troizky
    70
    658
    • November 12, 2013 at 3:39 AM
    The scanner must be correctly configured for the connection size and the adapter input/output/configuration assembly instances.
    This information must be provided by the adapter device manufacturer.
  • mcnealweld
    Guest
    • November 12, 2013 at 12:43 PM
    All of the instances are correct according to the manufacturer.
  • mcnealweld
    Guest
    • November 12, 2013 at 12:45 PM
    Im curious if there is a bug in this new software. Its material handler pro V8.20. This robot is a copy of a previous cell that we made. Everything is identical except the software version.
  • Sergei Troizky
    70
    658
    • November 13, 2013 at 2:37 AM
    Stupid question, but did you start the scanner?
    Also, are you sure the Turck is acting as an adapter?
