In our robot we found the alarm, "Motor phase short circuit alarm" while running in cycle. When we jog in manual, initially motor starts, as the speed progress it gives the above same alarm. Since our robot is the washing robot, we suspect about the water particles entry in the robot. We thoroughly cleaned the water. Still alarm persist. Could any one help me how to resolve this issue? What must be cause of this issue? Ver urgent.
ABB Robot IRB6640 washing robot
vijae -
October 28, 2013 at 3:51 PM -
Which model? Panel and manipulator. The error number too.
Error no 20610. Model: foundry plus.
What is the manipulator model? IRB 4600, 6640....
The error indicates a specific axis. Could you tell us the axis that have been indicated?
IRB6640, Also it doesn't specifies any specific axis on alarm.
Yesterday only we resolved this issue. We found problem with MP cable (controller to manipulator). We replaced new cable. Now it is k. Main root cause is water entry in the connector area.Thanks for ur interest on resolving this issue.
For people that meet this error code, here is what's written in the ABB troubleshooting manual:
Quote20610, Motor phase short circuit
Description
The drive unit for joint arg has reported short circuit. The joint is
connected to drive module arg with unit position arg and node arg.
Consequences
No operation will be possible until the fault is corrected. The system
goes to Motors Off state with zero torque.
Probable causes
1) Short circuit in cables or connectors between the phases or to
ground.
2) Short circuit in motor between the phases or to ground.
Recommended actions
1) Check/replace cables and connectors.
2) Check/replace motorHope this helps !
Ok Vijae, Good!
This place is to share experiences, when we received the notice what solved the problem, more people learn.
Your robot is a Foundry Prime, if you remove some parts you need caution because foundry Prime has special procedures to sealing.
Thanks for your valuable input. We have done the sealing during cable replacement. Is there any specific procedure for sealing? If there plz share with us...
To robots foundry prime have many procedures to do. If you look at maintenance schedule you can realize that the period is smaller than a standard robot for some things, however the inspection is more frequent, the environment is hard then we must have double attention.
The procedure to change cables that require special sealing and if you did, it's ok!
have procedure to do a leak-down test, to test the integrity of all enclosing... so on.
The main, don't let any surface without paint exposed to the aggressive working environment and don't let possiblity leak to inside.
have for example specifics products to use, like mercasol to rust preventive and Sikaflex to seal, this are important products!Send a PM if you need more information about foundry Prime, the manual is big to attach.
