hi all
I cannot acess to the smarthmi or the windows in a krc4
there is an IP adress default
what can I do ?
please help
solved : it was a virus in the usb recovry !
need your help please (solved)
nc56 -
October 1, 2013 at 9:43 PM -
What happened to cause this issue?
Are you able to connect to the robot using WorkVisual?
Do you have a good system restore backup?
Have you tried unplugging the SmartPad and using a monitor (and keyboard and mouse) plugged directly into the KRC?
I tried backup , but i Had the message : NTLDR is missing !!!
Thats a windows system library, so probably your Windows is corrupt. Hence I suggest setting up everything from scratch startin with Windows Embedded.
Fubini
use 7 zip to check your images are ok before restoring
