Almost reay for Milling!
  • happytriger2000
  • August 25, 2013 at 10:25 AM
  • happytriger2000
    327
    • September 2, 2013 at 9:59 AM
    • #21
    I need some suggestion from you guys, I'm deciding between the following setups, my aim is for large scale milling so which one is better:
    this one:
    and this one:
  • RAS-Skordos GR
    147
    • September 2, 2013 at 1:09 PM
    • #22
    A combination of the two? :smiling_face: (unless I didn't understand correctly....)
    Why don't you leave the robot on the track (so that you can mill lengthy objects) and also place the rotary horizontally directly on the floor (for working like lathe)?
    Edited once, last by RAS-Skordos GR (September 2, 2013 at 1:17 PM).
  • happytriger2000
    327
    • September 2, 2013 at 3:05 PM
    • #23
    Quote from RAS-Skordos GR
    That's what this picture illustrates, there should be a Robot on track beside it, I didn't added them in.
    but it will take me some time to drill the holes into the concrete floor 30 holes + hammering anchor wedges. I'm thinking of a simpler solution maybe a couple of H-beam link between the Headstock and the taistock to increase strength and prevent from bending.
  • happytriger2000
    327
    • October 30, 2013 at 2:50 PM
    • #24
    Ok Guys,
    A peek of the 5 meter external rotary base:
    Edited once, last by happytriger2000 (July 13, 2014 at 6:01 AM).
    vvelikov
    485
    • October 31, 2013 at 12:39 AM
    • #25
    That looks solid :smiling_face:
  • Robot_architect
    10
    • October 31, 2013 at 5:48 AM
    • #26
    Awesome work!
    Sent from my SM-T310 using Tapatalk
  • happytriger2000
    327
    • October 31, 2013 at 6:28 AM
    • #27
    Thanks guys,
    Took that picture 1 hr ago, I'm in a waiting list, should be finished by the end of Nov.
  • happytriger2000
    327
    • December 5, 2013 at 4:55 PM
    • #28
    Some updates on External axis:
    I was asked to provide the distance X,Y,Z, from the rotary centre point to A1 centre point:
    I manage to find the distance for X and Y, struggled a bit on the Z. The coordinates from the centre of the rotary plate:
    X =1852.160
    Y = -31.5
    Z = 1180.5362
    I'm not sure if the Z value is correct, the above picture Z = 1180.5362, if I change the Z value = 0 which means the same height as A1 centre point, but somehow it went even further down, way low, under the ground (I stopped before touching the ground), can someone explain this?
    thanks,
  • happytriger2000
    327
    • December 7, 2013 at 8:37 AM
    • #29
    This post here:
    https://www.robot-forum.com/robotforum/kuk…vs-robotmaster/
    describe exactly what I'm facing.
  • happytriger2000
    327
    • December 7, 2013 at 9:37 AM
    • #30
    Just curious about the height of A1, measured it, on KCP I got Z = 484.1797 take away the height of the pararell block = 31 leaves me 453.1791, the KL-1500-2 pdf stated 452mm, that's close, I guess the excess is the coat of paint..:)
    Edited once, last by happytriger2000 (December 20, 2013 at 6:38 AM).
  • ashishyadav
    7
    • December 18, 2013 at 10:13 AM
    • #31
    sir,
    i have almost the same application in milling, but i am very much confused to transfer 3D coordinates to robot. how much it move, like CNC where codes are there.
    SkyeFire
    1,059
    9,450
    • December 18, 2013 at 8:31 PM
    • #32
    Well, it depends on what software you have, and what you might be willing/able to buy. Some posters here use SprutCAM, others have used RobotMaster (IIRC), and I think Rhino and/or Grasshopper have shown up sometimes. Also, there are KUKA tech packages that will accept CNC G-code, although which one you can use will depend on the model and age of your robot controller.
  • happytriger2000
    327
    • December 19, 2013 at 5:21 AM
    • #33
    Agree with sky.
    I use RM.
  • ashishyadav
    7
    • December 19, 2013 at 8:05 AM
    • #34
    dear,
    We can buy a new krc4 controller or any robot for application..you please tell the tech package name, which accept the CNC G- code
    SkyeFire
    1,059
    9,450
    • December 19, 2013 at 9:25 PM
    • #35
    I believe that, for the KRC4, the software option is called KUKA.CNC. However, I do not know much about it, other than that it allows the KUKA robot to execute G-code.
    vvelikov
    485
    • December 20, 2013 at 1:15 AM
    • #36
    It is not that simple - you can't execute G-code directly in a robot.
    You will need to "translate" the G-code via postprocessor in your CAM software to get the right language and commands for the particular robot.
    It is all depend of what are you using for CAM programming and are you ready to learn new software if needed.
    You will also need to have proper simulation and collision/singularities checking and code editing software - to check the created code before you start it on the robot.
    So basically it is structured like that:
    CAM software -> Postprocessor -> Simulation&Verification -> Execution on the robot
  • happytriger2000
    327
    • April 25, 2014 at 2:20 AM
    • #37
    I have decided not to use horizontal style (lathe style) I realized is not easy to load the stock and the chuck need to be re-designed, so I transform it to vertical where the rotary sits on top of the linear base plate:
  • fazza85
    52
    • April 25, 2014 at 3:57 PM
    • #38
    Quote from SkyeFire
    We have had KUKA.CNC on a few of our robots. It's a nice bit of kit. It DOES allow the execution of g-code, as the file extensions are .nc if I remember correctly. One advantage of it is that it has no file size limitation as programs are stored directly on the C drive in the robot rather than in R1. It also runs an axis 1 backlash compensation move at the start of each program. We had much better machining results using KUKA.CNC files as opposed to regular .krl files as they use spline blocks in the programs, something which I can't get working in .krl files as I haven't had time to play with it yet.
    vvelikov
    485
    • April 25, 2014 at 5:28 PM
    • #39
    Hi fazza85, can you post some sample code about this backlash prevention for A1 - i am curious to take a look at it.
  • TylerRobertson
    70
    • April 28, 2014 at 3:26 PM
    • #40
    it's not code, it's a compensation tuning built into the controller that you have to set up in the kuka interface. Actually in that case there's probably a .dat file somewhere in the system that has the code at least for the parameters.
    kuka CNC does allow the robot to run g-code, although like every controller that takes G-code, it isn't always exactly like your standard FANUC-cnc code, so you will need to post-processes the code in a particular way.
    I have done test cuts with it and the results are impressive if not just from a usability (memory limitation is not an issue).
    The new Kuka controller is a great platform
    Taylor Guitars - Robotics Engineer
    - IRC5 IRB4400
    - IRC5 IRB2400
    - S4C+ IRB4600
    - S4 IRB2400
    - Epson G3-351 RC180
