Hi, I need some help to run this program in KRC1, when I load this program I got an error, please open image. I was told to add the following lines:
BAS(#PTP_DAT)
FDAT_ACT = {TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE}
BAS (#FRAMES)
BAS (#VEL_PTP, 50)
but not sure where to put them, which line should I replace them to?
[noae]
&ACCESS RVP
&REL 1
&PARAM TEMPLATE = C:\KRC\Roboter\Template\vorgabe
&PARAM EDITMASK = *
DEF kukaprc_project ( )
;FOLD INI
;FOLD BASISTECH INI
GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
INTERRUPT ON 3
BAS (#INITMOV,0 )
;ENDFOLD (BASISTECH INI)
;ENDFOLD (INI)
;FOLD PTP P2 Vel= 50 % PDATP2;%{PE}%R 5.2.26,%MKUKATPBASIS,%CMOVE,%VPTP,%P 1:PTP, 2:P2, 3:, 5:50, 7:PDATP2
$BWDSTART = FALSE
PDAT_ACT = {VEL 50,ACC 100,APO_DIST 100}
BAS (#PTP_PARAMS,50)
$H_POS = {A1 5,A2 -90,A3 100,A4 5,A5 10,A6 -5,E1 0,E2 0,E3 0,E4 0,E5 0,E6 0}
PTP {A1 5,A2 -90,A3 100,A4 5,A5 10,A6 -5,E1 0,E2 0,E3 0,E4 0,E5 0,E6 0}
;ENDFOLD
;FOLD PTP P4 Vel= 50 % PDATP4 TOOL[6] BASE[6];%{PE}%R 5.2.26,%MKUKATPBASIS,%CMOVE,%VPTP,%P 1:PTP, 2:P4, 3:, 5:50, 7:PDATP4
$BWDSTART = FALSE
FDAT_ACT = {TOOL_NO 6,BASE_NO 6,IPO_FRAME #BASE}
;ENDFOLD
PTP {X -253.090, Y 61.397, Z 320.000, A -13.636, B 33.963, C 45.728}
LIN {X -253.090, Y 61.397, Z 320.000, A -13.636, B 33.963, C 45.728} C_DIS
$VEL.CP=0.00166666666666667
LIN {X -240.194, Y 58.268, Z 166.481, A -13.636, B 33.963, C 50.454} C_DIS
$VEL.CP=0.00333333333333333
LIN {X -231.721, Y 82.286, Z 168.340, A -19.550, B 34.395, C 43.468} C_DIS
LIN {X -229.544, Y 91.131, Z 166.759, A -21.654, B 34.028, C 41.155} C_DIS
LIN {X -228.367, Y 95.544, Z 165.903, A -22.704, B 33.829, C 39.968} C_DIS
LIN {X -223.855, Y 98.167, Z 170.458, A -23.679, B 34.890, C 37.947} C_DIS
LIN {X -221.571, Y 99.462, Z 172.678, A -24.175, B 35.412, C 36.940} C_DIS
LIN {X -216.940, Y 101.973, Z 177.038, A -25.176, B 36.448, C 34.941} C_DIS
LIN {X -208.538, Y 110.094, Z 182.196, A -27.831, B 37.691, C 30.611} C_DIS
LIN {X -214.346, Y 110.757, Z 174.907, A -27.326, B 35.940, C 32.348} C_DIS
LIN {X -215.878, Y 127.321, Z 161.215, A -30.531, B 32.751, C 29.758} C_DIS
LIN {X -213.047, Y 129.139, Z 163.517, A -31.222, B 33.279, C 28.355} C_DIS
LIN {X -201.489, Y 136.079, Z 172.304, A -34.034, B 35.324, C 22.836} C_DIS
LIN {X -198.545, Y 137.731, Z 174.396, A -34.749, B 35.819, C 21.480} C_DIS
LIN {X -195.580, Y 139.351, Z 176.447, A -35.470, B 36.307, C 20.134} C_DIS
LIN {X -192.446, Y 147.054, Z 173.620, A -37.385, B 35.635, C 17.377} C_DIS
LIN {X -210.297, Y 136.461, Z 161.114, A -32.980, B 32.728, C 25.945} C_DIS
LIN {X -213.765, Y 134.192, Z 158.434, A -32.119, B 32.118, C 27.705} C_DIS
LIN {X -217.195, Y 131.870, Z 155.693, A -31.264, B 31.497, C 29.479} C_DIS
LIN {X -225.475, Y 116.371, Z 156.279, A -27.299, B 31.630, C 35.369} C_DIS
LIN {X -226.974, Y 111.971, Z 157.318, A -26.258, B 31.865, C 36.672} C_DIS
LIN {X -228.411, Y 107.561, Z 158.314, A -25.216, B 32.090, C 37.946} C_DIS
LIN {X -232.347, Y 94.258, Z 161.042, A -22.081, B 32.711, C 41.607} C_DIS
LIN {X -236.744, Y 76.358, Z 164.090, A -17.876, B 33.411, C 46.174} C_DIS
LIN {X -253.090, Y 61.397, Z 175.419, A -13.636, B 33.963, C 50.454} C_DIS
LIN {X -218.890, Y 74.371, Z 320.000, A -18.766, B 42.588, C 36.789} C_DIS
LIN {X -207.737, Y 70.582, Z 201.662, A -18.766, B 42.588, C 39.266} C_DIS
LIN {X -204.490, Y 71.609, Z 204.597, A -19.299, B 43.359, C 38.244} C_DIS
LIN {X -199.685, Y 80.875, Z 205.886, A -22.049, B 43.701, C 34.823} C_DIS
LIN {X -198.850, Y 85.011, Z 205.026, A -23.147, B 43.472, C 33.606} C_DIS
LIN {X -197.969, Y 89.153, Z 204.117, A -24.244, B 43.232, C 32.375} C_DIS
LIN {X -197.041, Y 93.298, Z 203.161, A -25.337, B 42.980, C 31.132} C_DIS
LIN {X -193.401, Y 107.837, Z 199.428, A -29.143, B 42.007, C 26.663} C_DIS
LIN {X -192.795, Y 109.906, Z 198.884, A -29.686, B 41.866, C 26.002} C_DIS
LIN {X -192.137, Y 111.966, Z 198.371, A -30.231, B 41.734, C 25.327} C_DIS
LIN {X -191.414, Y 114.009, Z 197.906, A -30.779, B 41.614, C 24.637} C_DIS
LIN {X -190.630, Y 116.042, Z 197.480, A -31.330, B 41.505, C 23.931} C_DIS
LIN {X -188.349, Y 121.005, Z 196.689, A -32.719, B 41.302, C 22.094} C_DIS
LIN {X -185.940, Y 124.769, Z 196.629, A -33.862, B 41.287, C 20.497} C_DIS
LIN {X -183.670, Y 127.328, Z 197.121, A -34.731, B 41.413, C 19.221} C_DIS
LIN {X -182.842, Y 128.080, Z 197.404, A -35.011, B 41.485, C 18.798} C_DIS
LIN {X -177.370, Y 130.863, Z 200.547, A -36.420, B 42.297, C 16.534} C_DIS
LIN {X -176.406, Y 130.948, Z 201.339, A -36.587, B 42.504, C 16.236} C_DIS
LIN {X -175.437, Y 130.899, Z 202.216, A -36.728, B 42.733, C 15.970} C_DIS
LIN {X -174.465, Y 130.705, Z 203.180, A -36.840, B 42.985, C 15.741} C_DIS
LIN {X -173.039, Y 133.252, Z 202.745, A -37.599, B 42.871, C 14.699} C_DIS
LIN {X -170.108, Y 138.317, Z 201.831, A -39.115, B 42.632, C 12.592} C_DIS
LIN {X -170.891, Y 141.233, Z 199.132, A -39.572, B 41.930, C 12.090} C_DIS
LIN {X -171.674, Y 141.233, Z 198.458, A -39.443, B 41.756, C 12.319} C_DIS
LIN {X -173.249, Y 141.049, Z 197.216, A -39.150, B 41.437, C 12.825} C_DIS
LIN {X -174.034, Y 140.871, Z 196.651, A -38.988, B 41.292, C 13.099} C_DIS
LIN {X -174.814, Y 140.638, Z 196.125, A -38.817, B 41.158, C 13.385} C_DIS
LIN {X -177.072, Y 139.643, Z 194.806, A -38.260, B 40.822, C 14.297} C_DIS
LIN {X -178.498, Y 138.762, Z 194.133, A -37.861, B 40.651, C 14.934} C_DIS
LIN {X -181.120, Y 136.598, Z 193.237, A -37.023, B 40.425, C 16.238} C_DIS
LIN {X -181.724, Y 135.992, Z 193.098, A -36.809, B 40.389, C 16.564} C_DIS
LIN {X -182.877, Y 134.719, Z 192.901, A -36.378, B 40.340, C 17.213} C_DIS
LIN {X -183.966, Y 133.383, Z 192.794, A -35.944, B 40.313, C 17.858} C_DIS
LIN {X -186.002, Y 130.598, Z 192.746, A -35.074, B 40.302, C 19.128} C_DIS
LIN {X -191.587, Y 132.318, Z 185.985, A -34.631, B 38.617, C 20.429} C_DIS
LIN {X -192.936, Y 128.454, Z 187.295, A -33.655, B 38.940, C 21.730} C_DIS
LIN {X -194.235, Y 124.592, Z 188.556, A -32.678, B 39.252, C 23.009} C_DIS
LIN {X -195.486, Y 120.733, Z 189.770, A -31.700, B 39.555, C 24.266} C_DIS
LIN {X -196.690, Y 116.875, Z 190.938, A -30.719, B 39.846, C 25.507} C_DIS
LIN {X -201.047, Y 101.456, Z 195.169, A -26.777, B 40.914, C 30.298} C_DIS
LIN {X -203.861, Y 89.892, Z 197.900, A -23.795, B 41.613, C 33.743} C_DIS
LIN {X -204.716, Y 86.035, Z 198.730, A -22.795, B 41.827, C 34.868} C_DIS
LIN {X -206.305, Y 78.315, Z 200.273, A -20.787, B 42.226, C 37.086} C_DIS
LIN {X 103.336, Y 139.040, Z 320.000, A -126.620, B 56.516, C -79.442} C_DIS
LIN {X 103.336, Y 139.040, Z 261.889, A -126.620, B 56.516, C -80.709} C_DIS
LIN {X 98.070, Y 131.955, Z 248.544, A -126.620, B 56.516, C -80.709} C_DIS
LIN {X 98.551, Y 129.559, Z 249.612, A -127.259, B 56.890, C -81.210} C_DIS
LIN {X 99.108, Y 127.256, Z 250.575, A -127.912, B 57.230, C -81.731} C_DIS
LIN {X 99.740, Y 125.044, Z 251.436, A -128.577, B 57.538, C -82.269} C_DIS
LIN {X 103.022, Y 117.079, Z 253.935, A -131.346, B 58.444, C -84.564} C_DIS
LIN {X 106.274, Y 111.991, Z 254.888, A -133.500, B 58.796, C -86.391} C_DIS
LIN {X 107.521, Y 110.453, Z 255.036, A -134.229, B 58.851, C -87.013} C_DIS
LIN {X 108.850, Y 108.983, Z 255.105, A -134.965, B 58.877, C -87.643} C_DIS
LIN {X 110.245, Y 107.581, Z 255.101, A -135.701, B 58.875, C -88.273} C_DIS
LIN {X 114.859, Y 103.830, Z 254.619, A -137.887, B 58.696, C -90.144} C_DIS
LIN {X 117.459, Y 102.237, Z 254.077, A -138.963, B 58.496, C -91.062} C_DIS
LIN {X 119.318, Y 101.301, Z 253.585, A -139.669, B 58.316, C -91.661} C_DIS
LIN {X 120.290, Y 100.879, Z 253.294, A -140.016, B 58.209, C -91.954} C_DIS
LIN {X 128.122, Y 98.942, Z 250.199, A -142.323, B 57.097, C -93.869} C_DIS
LIN {X 130.727, Y 98.943, Z 248.847, A -142.879, B 56.622, C -94.313} C_DIS
LIN {X 135.642, Y 100.217, Z 245.686, A -143.542, B 55.533, C -94.807} C_DIS
LIN {X 136.297, Y 100.559, Z 245.184, A -143.580, B 55.362, C -94.828} C_DIS
LIN {X 138.013, Y 101.792, Z 243.710, A -143.589, B 54.867, C -94.807} C_DIS
LIN {X 138.530, Y 102.289, Z 243.208, A -143.558, B 54.700, C -94.772} C_DIS
LIN {X 139.025, Y 102.827, Z 242.698, A -143.512, B 54.530, C -94.724} C_DIS
LIN {X 140.983, Y 105.893, Z 240.238, A -143.090, B 53.723, C -94.335} C_DIS
LIN {X 141.474, Y 107.187, Z 239.374, A -142.851, B 53.443, C -94.127} C_DIS
LIN {X 142.331, Y 112.445, Z 236.436, A -141.690, B 52.505, C -93.153} C_DIS
LIN {X 142.286, Y 115.051, Z 235.206, A -141.041, B 52.119, C -92.624} C_DIS
LIN {X 142.065, Y 117.586, Z 234.083, A -140.386, B 51.768, C -92.096} C_DIS
LIN {X 140.913, Y 123.773, Z 231.577, A -138.705, B 50.996, C -90.767} C_DIS
LIN {X 140.262, Y 126.190, Z 230.666, A -138.023, B 50.719, C -90.236} C_DIS
LIN {X 139.515, Y 128.559, Z 229.809, A -137.340, B 50.459, C -89.709} C_DIS
LIN {X 138.656, Y 130.867, Z 229.025, A -136.655, B 50.223, C -89.183} C_DIS
LIN {X 132.355, Y 141.384, Z 226.488, A -133.111, B 49.467, C -86.496} C_DIS
LIN {X 131.531, Y 142.321, Z 226.381, A -132.744, B 49.435, C -86.218} C_DIS
LIN {X 130.676, Y 143.232, Z 226.302, A -132.375, B 49.411, C -85.938} C_DIS
LIN {X 128.878, Y 144.963, Z 226.230, A -131.638, B 49.390, C -85.377} C_DIS
LIN {X 127.939, Y 145.781, Z 226.238, A -131.270, B 49.393, C -85.096} C_DIS
LIN {X 125.983, Y 147.312, Z 226.344, A -130.538, B 49.424, C -84.534} C_DIS
LIN {X 121.820, Y 149.894, Z 226.926, A -129.101, B 49.596, C -83.417} C_DIS
LIN {X 120.726, Y 150.431, Z 227.156, A -128.748, B 49.664, C -83.139} C_DIS
LIN {X 119.604, Y 150.926, Z 227.420, A -128.396, B 49.743, C -82.860} C_DIS
LIN {X 116.084, Y 152.148, Z 228.428, A -127.342, B 50.044, C -82.011} C_DIS
LIN {X 114.865, Y 152.463, Z 228.834, A -126.994, B 50.166, C -81.726} C_DIS
LIN {X 109.773, Y 153.151, Z 230.865, A -125.632, B 50.779, C -80.581} C_DIS
LIN {X 107.170, Y 152.991, Z 232.190, A -125.011, B 51.184, C -80.035} C_DIS
LIN {X 104.634, Y 152.360, Z 233.757, A -124.479, B 51.667, C -79.544} C_DIS
LIN {X 103.416, Y 151.837, Z 234.637, A -124.259, B 51.941, C -79.329} C_DIS
LIN {X 102.251, Y 151.156, Z 235.586, A -124.077, B 52.238, C -79.140} C_DIS
LIN {X 101.114, Y 150.283, Z 236.632, A -123.934, B 52.567, C -78.977} C_DIS
LIN {X 97.427, Y 142.407, Z 242.966, A -124.378, B 54.619, C -79.058} C_DIS
LIN {X 97.282, Y 138.295, Z 245.387, A -125.124, B 55.431, C -79.576} C_DIS
LIN {X 97.362, Y 136.983, Z 246.090, A -125.404, B 55.670, C -79.781} C_DIS
LIN {X 180.448, Y 84.891, Z 320.000, A -154.806, B 50.573, C -101.397} C_DIS
LIN {X 179.873, Y 84.620, Z 241.773, A -154.806, B 50.573, C -103.358} C_DIS
LIN {X 180.174, Y 78.413, Z 224.037, A -156.481, B 48.747, C -104.327} C_DIS
LIN {X 177.987, Y 90.239, Z 221.318, A -153.115, B 47.960, C -101.559} C_DIS
LIN {X 176.327, Y 98.188, Z 219.253, A -150.889, B 47.371, C -99.769} C_DIS
LIN {X 173.513, Y 110.216, Z 215.754, A -147.576, B 46.386, C -97.171} C_DIS
LIN {X 172.477, Y 114.255, Z 214.479, A -146.478, B 46.032, C -96.329} C_DIS
LIN {X 171.479, Y 118.328, Z 213.066, A -145.393, B 45.642, C -95.504} C_DIS
LIN {X 170.666, Y 122.456, Z 211.380, A -144.340, B 45.180, C -94.708} C_DIS
LIN {X 172.293, Y 132.106, Z 204.126, A -142.521, B 43.234, C -93.294} C_DIS
LIN {X 173.829, Y 132.271, Z 202.711, A -142.731, B 42.862, C -93.415} C_DIS
LIN {X 174.359, Y 132.192, Z 202.307, A -142.832, B 42.756, C -93.477} C_DIS
LIN {X 176.378, Y 131.492, Z 201.009, A -143.295, B 42.417, C -93.768} C_DIS
LIN {X 177.343, Y 130.986, Z 200.489, A -143.550, B 42.282, C -93.931} C_DIS
LIN {X 181.791, Y 127.750, Z 198.585, A -144.903, B 41.789, C -94.802} C_DIS
LIN {X 181.453, Y 135.487, Z 193.706, A -143.252, B 40.543, C -93.604} C_DIS
LIN {X 175.677, Y 139.998, Z 195.811, A -141.448, B 41.078, C -92.453} C_DIS
LIN {X 171.147, Y 142.113, Z 198.285, A -140.295, B 41.712, C -91.715} C_DIS
LIN {X 167.861, Y 141.875, Z 201.241, A -139.796, B 42.478, C -91.404} C_DIS
LIN {X 167.320, Y 141.491, Z 201.961, A -139.781, B 42.666, C -91.399} C_DIS
LIN {X 166.869, Y 141.000, Z 202.676, A -139.803, B 42.853, C -91.418} C_DIS
LIN {X 166.194, Y 139.847, Z 204.025, A -139.920, B 43.208, C -91.508} C_DIS
LIN {X 165.068, Y 135.884, Z 207.586, A -140.539, B 44.155, C -91.966} C_DIS
LIN {X 158.262, Y 146.377, Z 205.745, A -137.234, B 43.663, C -89.666} C_DIS
LIN {X 157.323, Y 139.058, Z 211.462, A -138.526, B 45.203, C -90.574} C_DIS
LIN {X 159.919, Y 130.482, Z 214.952, A -140.788, B 46.163, C -92.216} C_DIS
LIN {X 164.449, Y 113.585, Z 221.041, A -145.367, B 47.880, C -95.689} C_DIS
LIN {X 166.413, Y 105.249, Z 223.681, A -147.689, B 48.643, C -97.517} C_DIS
LIN {X 167.326, Y 101.104, Z 224.908, A -148.858, B 49.001, C -98.453} C_DIS
LIN {X 168.195, Y 96.974, Z 226.076, A -150.034, B 49.345, C -99.405} C_DIS
LIN {X 169.021, Y 92.856, Z 227.186, A -151.217, B 49.674, C -100.371} C_DIS
LIN {X 170.549, Y 84.653, Z 229.240, A -153.602, B 50.288, C -102.347} C_DIS
LIN {X 171.253, Y 80.565, Z 230.186, A -154.806, B 50.573, C -103.358} C_DIS
LIN {X 162.190, Y -106.110, Z 320.000, A 146.806, B 51.884, C -161.046} C_DIS
LIN {X 162.190, Y -106.110, Z 247.044, A 146.806, B 51.884, C -161.774} C_DIS
LIN {X 161.674, Y -105.772, Z 246.258, A 146.806, B 51.884, C -161.775} C_DIS
LIN {X 150.285, Y -107.341, Z 233.872, A 144.464, B 51.703, C -164.620} C_DIS
LIN {X 148.072, Y -110.390, Z 233.865, A 143.295, B 51.701, C -166.073} C_DIS
LIN {X 141.044, Y -116.755, Z 235.115, A 140.382, B 52.090, C -169.775} C_DIS
LIN {X 139.404, Y -117.721, Z 235.610, A 139.820, B 52.245, C -170.499} C_DIS
LIN {X 137.689, Y -118.571, Z 236.192, A 139.267, B 52.428, C -171.213} C_DIS
LIN {X 136.803, Y -118.951, Z 236.516, A 138.993, B 52.530, C -171.567} C_DIS
LIN {X 135.898, Y -119.300, Z 236.861, A 138.721, B 52.640, C -171.919} C_DIS
LIN {X 125.953, Y -120.714, Z 241.595, A 136.217, B 54.166, C -175.150} C_DIS
LIN {X 124.889, Y -120.551, Z 242.227, A 136.012, B 54.375, C -175.415} C_DIS
LIN {X 123.815, Y -120.310, Z 242.898, A 135.822, B 54.597, C -175.660} C_DIS
LIN {X 122.721, Y -119.964, Z 243.623, A 135.651, B 54.838, C -175.882} C_DIS
LIN {X 116.964, Y -115.592, Z 248.519, A 135.338, B 56.507, C -176.337} C_DIS
LIN {X 116.261, Y -114.517, Z 249.345, A 135.433, B 56.796, C -176.236} C_DIS
LIN {X 115.231, Y -112.395, Z 250.785, A 135.714, B 57.305, C -175.924} C_DIS
LIN {X 114.850, Y -111.332, Z 251.433, A 135.891, B 57.537, C -175.725} C_DIS
LIN {X 113.891, Y -106.183, Z 254.083, A 137.006, B 58.499, C -174.464} C_DIS
LIN {X 113.780, Y -104.256, Z 254.929, A 137.501, B 58.811, C -173.906} C_DIS
LIN {X 113.766, Y -102.385, Z 255.693, A 138.014, B 59.096, C -173.328} C_DIS
LIN {X 116.989, Y -98.356, Z 255.820, A 139.945, B 59.144, C -171.093} C_DIS
LIN {X 123.115, Y -97.389, Z 253.303, A 141.655, B 58.213, C -169.011} C_DIS
LIN {X 126.206, Y -96.847, Z 251.985, A 142.498, B 57.735, C -167.969} C_DIS
LIN {X 148.742, Y -92.639, Z 241.035, A 148.085, B 53.983, C -160.714} C_DIS
LIN {X 155.458, Y -91.208, Z 237.314, A 149.600, B 52.783, C -158.617} C_DIS
LIN {X 158.864, Y -90.450, Z 235.340, A 150.345, B 52.161, C -157.561} C_DIS
LIN {X 165.769, Y -88.841, Z 231.153, A 151.812, B 50.867, C -155.426} C_DIS
LIN {X 166.464, Y -85.147, Z 232.043, A 152.910, B 51.139, C -154.200} C_DIS
LIN {X 166.759, Y -83.296, Z 232.502, A 153.458, B 51.280, C -153.595} C_DIS
LIN {X 167.477, Y -75.868, Z 234.520, A 155.629, B 51.904, C -151.256} C_DIS
LIN {X 167.515, Y -74.004, Z 235.088, A 156.165, B 52.081, C -150.695} C_DIS
LIN {X 164.785, Y -59.227, Z 241.127, A 160.230, B 54.013, C -146.748} C_DIS
LIN {X 157.360, Y -50.216, Z 248.033, A 162.301, B 56.338, C -145.232} C_DIS
LIN {X 156.337, Y -49.579, Z 248.807, A 162.405, B 56.608, C -145.203} C_DIS
LIN {X 153.046, Y -48.041, Z 251.143, A 162.573, B 57.433, C -145.273} C_DIS
LIN {X 151.911, Y -47.677, Z 251.900, A 162.576, B 57.704, C -145.350} C_DIS
LIN {X 149.621, Y -47.162, Z 253.364, A 162.504, B 58.235, C -145.583} C_DIS
LIN {X 148.468, Y -46.996, Z 254.072, A 162.435, B 58.495, C -145.732} C_DIS
LIN {X 147.315, Y -46.885, Z 254.763, A 162.346, B 58.750, C -145.899} C_DIS
LIN {X 146.165, Y -46.826, Z 255.435, A 162.236, B 59.000, C -146.087} C_DIS
LIN {X 142.765, Y -46.925, Z 257.333, A 161.805, B 59.716, C -146.744} C_DIS
LIN {X 140.573, Y -47.186, Z 258.489, A 161.445, B 60.159, C -147.246} C_DIS
LIN {X 138.473, Y -47.569, Z 259.550, A 161.041, B 60.572, C -147.784} C_DIS
LIN {X 134.657, Y -48.587, Z 261.363, A 160.160, B 61.290, C -148.905} C_DIS
LIN {X 128.292, Y -51.312, Z 264.031, A 158.200, B 62.376, C -151.256} C_DIS
LIN {X 125.567, Y -52.939, Z 265.018, A 157.140, B 62.788, C -152.483} C_DIS
LIN {X 120.871, Y -56.466, Z 266.469, A 154.960, B 63.405, C -154.953} C_DIS
LIN {X 119.825, Y -57.389, Z 266.744, A 154.408, B 63.523, C -155.571} C_DIS
LIN {X 108.019, Y -72.862, Z 268.006, A 145.999, B 64.073, C -164.816} C_DIS
LIN {X 103.188, Y -85.334, Z 266.222, A 140.410, B 63.299, C -170.917} C_DIS
LIN {X 100.290, Y -101.953, Z 261.441, A 134.529, B 61.321, C -177.439} C_DIS
LIN {X 100.187, Y -103.649, Z 260.813, A 134.027, B 61.070, C -178.007} C_DIS
LIN {X 100.126, Y -105.389, Z 260.138, A 133.533, B 60.803, C -178.567} C_DIS
LIN {X 100.189, Y -109.036, Z 258.607, A 132.579, B 60.205, C -179.658} C_DIS
LIN {X 100.333, Y -110.955, Z 257.733, A 132.122, B 59.869, C 179.815} C_DIS
LIN {X 100.580, Y -112.956, Z 256.766, A 131.683, B 59.500, C 179.305} C_DIS
LIN {X 101.210, Y -116.082, Z 255.119, A 131.085, B 58.882, C 178.602} C_DIS
LIN {X 101.841, Y -118.197, Z 253.893, A 130.749, B 58.429, C 178.201} C_DIS
LIN {X 102.229, Y -119.251, Z 253.244, A 130.605, B 58.191, C 178.027} C_DIS
LIN {X 102.679, Y -120.300, Z 252.565, A 130.481, B 57.944, C 177.875} C_DIS
LIN {X 106.799, Y -126.134, Z 247.968, A 130.255, B 56.316, C 177.564} C_DIS
LIN {X 108.661, Y -127.693, Z 246.356, A 130.396, B 55.761, C 177.719} C_DIS
LIN {X 112.621, Y -129.871, Z 243.421, A 130.931, B 54.771, C 178.346} C_DIS
LIN {X 113.638, Y -130.242, Z 242.750, A 131.105, B 54.548, C 178.555} C_DIS
LIN {X 119.697, Y -131.366, Z 239.206, A 132.339, B 53.389, C -179.929} C_DIS
LIN {X 121.677, Y -131.415, Z 238.178, A 132.797, B 53.059, C -179.356} C_DIS
LIN {X 125.580, Y -131.133, Z 236.300, A 133.761, B 52.462, C -178.135} C_DIS
LIN {X 127.501, Y -130.833, Z 235.436, A 134.261, B 52.191, C -177.496} C_DIS
LIN {X 129.398, Y -130.449, Z 234.613, A 134.768, B 51.933, C -176.844} C_DIS
LIN {X 131.273, Y -129.997, Z 233.821, A 135.280, B 51.687, C -176.181} C_DIS
LIN {X 136.731, Y -128.223, Z 231.662, A 136.839, B 51.022, C -174.146} C_DIS
LIN {X 140.204, Y -126.676, Z 230.435, A 137.902, B 50.648, C -172.748} C_DIS
LIN {X 141.881, Y -125.794, Z 229.890, A 138.439, B 50.484, C -172.040} C_DIS
LIN {X 143.515, Y -124.841, Z 229.396, A 138.981, B 50.335, C -171.325} C_DIS
LIN {X 145.102, Y -123.815, Z 228.953, A 139.526, B 50.201, C -170.606} C_DIS
LIN {X 146.662, Y -122.705, Z 228.556, A 140.082, B 50.082, C -169.874} C_DIS
LIN {X 148.163, Y -121.534, Z 228.213, A 140.639, B 49.980, C -169.142} C_DIS
LIN {X 150.994, Y -119.020, Z 227.682, A 141.753, B 49.821, C -167.683} C_DIS
LIN {X 152.324, Y -117.681, Z 227.492, A 142.311, B 49.764, C -166.957} C_DIS
LIN {X 158.140, Y -110.270, Z 227.236, A 145.112, B 49.688, C -163.371} C_DIS
LIN {X 160.086, Y -107.014, Z 227.430, A 146.238, B 49.746, C -161.964} C_DIS
LIN {X 160.978, Y -105.333, Z 227.585, A 146.802, B 49.792, C -161.267} C_DIS
LIN {X 162.605, Y -101.876, Z 228.002, A 147.932, B 49.916, C -159.890} C_DIS
LIN {X 163.340, Y -100.105, Z 228.261, A 148.498, B 49.994, C -159.209} C_DIS
LIN {X 88.651, Y 140.724, Z 265.154, A -122.210, B 57.902, C -76.772} C_DIS
LIN {X 84.403, Y 133.980, Z 252.447, A -122.210, B 57.902, C -76.772} C_DIS
LIN {X 85.061, Y 130.393, Z 254.099, A -123.118, B 58.505, C -77.478} C_DIS
LIN {X 85.440, Y 128.684, Z 254.842, A -123.582, B 58.779, C -77.846} C_DIS
LIN {X 85.851, Y 127.030, Z 255.533, A -124.052, B 59.036, C -78.223} C_DIS
LIN {X 87.274, Y 122.369, Z 257.319, A -125.497, B 59.710, C -79.407} C_DIS
LIN {X 88.376, Y 119.490, Z 258.294, A -126.487, B 60.084, C -80.235} C_DIS
LIN {X 88.971, Y 118.112, Z 258.723, A -126.990, B 60.250, C -80.659} C_DIS
LIN {X 93.109, Y 110.544, Z 260.604, A -130.107, B 60.987, C -83.335} C_DIS
LIN {X 97.186, Y 105.086, Z 261.373, A -132.763, B 61.293, C -85.652} C_DIS
LIN {X 98.983, Y 103.089, Z 261.494, A -133.836, B 61.342, C -86.593} C_DIS
LIN {X 104.904, Y 97.653, Z 261.272, A -137.050, B 61.253, C -89.414} C_DIS
LIN {X 109.356, Y 94.487, Z 260.610, A -139.172, B 60.989, C -91.272} C_DIS
LIN {X 111.772, Y 93.049, Z 260.102, A -140.223, B 60.789, C -92.187} C_DIS
LIN {X 118.494, Y 89.957, Z 258.207, A -142.795, B 60.051, C -94.402} C_DIS
LIN {X 121.481, Y 88.950, Z 257.166, A -143.788, B 59.652, C -95.243} C_DIS
LIN {X 124.662, Y 88.111, Z 255.929, A -144.748, B 59.185, C -96.046} C_DIS
LIN {X 128.071, Y 87.498, Z 254.452, A -145.659, B 58.635, C -96.792} C_DIS
LIN {X 133.690, Y 87.146, Z 251.668, A -146.902, B 57.621, C -97.775} C_DIS
LIN {X 135.710, Y 87.256, Z 250.546, A -147.261, B 57.220, C -98.045} C_DIS
LIN {X 137.776, Y 87.531, Z 249.319, A -147.572, B 56.787, C -98.269} C_DIS
LIN {X 141.969, Y 88.703, Z 246.537, A -148.003, B 55.823, C -98.538} C_DIS
LIN {X 144.038, Y 89.650, Z 244.990, A -148.102, B 55.297, C -98.567} C_DIS
LIN {X 145.984, Y 90.826, Z 243.400, A -148.112, B 54.763, C -98.521} C_DIS
LIN {X 147.720, Y 92.219, Z 241.823, A -148.024, B 54.242, C -98.394} C_DIS
LIN {X 148.486, Y 92.984, Z 241.060, A -147.945, B 53.991, C -98.303} C_DIS
LIN {X 151.347, Y 97.242, Z 237.575, A -147.279, B 52.867, C -97.648} C_DIS
LIN {X 151.744, Y 98.158, Z 236.944, A -147.103, B 52.666, C -97.487} C_DIS
LIN {X 152.386, Y 100.031, Z 235.746, A -146.718, B 52.288, C -97.142} C_DIS
LIN {X 153.220, Y 104.804, Z 233.118, A -145.628, B 51.469, C -96.203} C_DIS
LIN {X 153.302, Y 106.684, Z 232.209, A -145.166, B 51.190, C -95.817} C_DIS
LIN {X 153.011, Y 112.215, Z 229.782, A -143.744, B 50.451, C -94.654} C_DIS
LIN {X 152.126, Y 117.684, Z 227.623, A -142.275, B 49.803, C -93.484} C_DIS
LIN {X 149.721, Y 126.638, Z 224.389, A -139.775, B 48.849, C -91.549} C_DIS
LIN {X 147.645, Y 131.817, Z 222.776, A -138.241, B 48.380, C -90.391} C_DIS
LIN {X 146.837, Y 133.498, Z 222.309, A -137.724, B 48.245, C -90.005} C_DIS
LIN {X 145.969, Y 135.152, Z 221.880, A -137.204, B 48.122, C -89.617} C_DIS
LIN {X 143.002, Y 139.937, Z 220.844, A -135.621, B 47.824, C -88.446} C_DIS
LIN {X 141.903, Y 141.456, Z 220.585, A -135.090, B 47.750, C -88.054} C_DIS
LIN {X 139.546, Y 144.370, Z 220.200, A -134.027, B 47.640, C -87.271} C_DIS
LIN {X 135.643, Y 148.411, Z 219.953, A -132.426, B 47.570, C -86.089} C_DIS
LIN {X 132.811, Y 150.867, Z 220.010, A -131.358, B 47.586, C -85.296} C_DIS
LIN {X 129.810, Y 153.117, Z 220.247, A -130.291, B 47.653, C -84.497} C_DIS
LIN {X 126.651, Y 155.151, Z 220.662, A -129.225, B 47.772, C -83.690} C_DIS
LIN {X 123.356, Y 156.947, Z 221.258, A -128.166, B 47.943, C -82.878} C_DIS
LIN {X 119.947, Y 158.484, Z 222.034, A -127.120, B 48.166, C -82.064} C_DIS
LIN {X 112.853, Y 160.780, Z 224.094, A -125.065, B 48.763, C -80.418} C_DIS
LIN {X 105.491, Y 161.985, Z 226.796, A -123.074, B 49.558, C -78.753} C_DIS
LIN {X 98.011, Y 161.587, Z 230.407, A -121.239, B 50.640, C -77.117} C_DIS
LIN {X 97.085, Y 161.385, Z 230.941, A -121.030, B 50.802, C -76.921} C_DIS
LIN {X 96.161, Y 161.143, Z 231.495, A -120.826, B 50.971, C -76.727} C_DIS
LIN {X 90.660, Y 158.636, Z 235.413, A -119.748, B 52.183, C -75.629} C_DIS
LIN {X 88.224, Y 156.549, Z 237.724, A -119.404, B 52.914, C -75.209} C_DIS
LIN {X 87.523, Y 155.740, Z 238.514, A -119.335, B 53.167, C -75.105} C_DIS
LIN {X 86.313, Y 153.980, Z 240.092, A -119.273, B 53.676, C -74.959} C_DIS
LIN {X 85.347, Y 152.045, Z 241.665, A -119.307, B 54.190, C -74.894} C_DIS
LIN {X 84.953, Y 151.015, Z 242.449, A -119.360, B 54.448, C -74.891} C_DIS
LIN {X 84.112, Y 147.775, Z 244.728, A -119.648, B 55.209, C -75.000} C_DIS
LIN {X 83.816, Y 145.631, Z 246.111, A -119.922, B 55.677, C -75.153} C_DIS
LIN {X 83.670, Y 141.502, Z 248.557, A -120.596, B 56.520, C -75.590} C_DIS
LIN {X 88.934, Y 141.173, Z 266.002, A -122.210, B 57.902, C -76.772} C_DIS
LIN {X 212.435, Y 76.387, Z 320.000, A -160.223, B 44.032, C -103.103} C_DIS
LIN {X 212.435, Y 76.387, Z 218.249, A -160.223, B 44.032, C -106.065} C_DIS
LIN {X 201.610, Y 72.495, Z 207.128, A -160.223, B 44.032, C -106.065} C_DIS
LIN {X 208.097, Y 70.466, Z 201.331, A -161.293, B 42.501, C -106.426} C_DIS
LIN {X 207.480, Y 73.903, Z 200.735, A -160.394, B 42.346, C -105.719} C_DIS
LIN {X 206.832, Y 77.339, Z 200.108, A -159.498, B 42.183, C -105.019} C_DIS
LIN {X 203.919, Y 91.093, Z 197.290, A -155.929, B 41.456, C -102.288} C_DIS
LIN {X 200.457, Y 104.872, Z 193.966, A -152.383, B 40.609, C -99.667} C_DIS
LIN {X 199.584, Y 108.331, Z 192.963, A -151.508, B 40.355, C -99.030} C_DIS
LIN {X 199.181, Y 110.067, Z 192.396, A -151.075, B 40.213, C -98.716} C_DIS
LIN {X 198.467, Y 113.584, Z 191.085, A -150.217, B 39.883, C -98.090} C_DIS
LIN {X 198.512, Y 119.161, Z 187.610, A -149.025, B 39.018, C -97.175} C_DIS
LIN {X 199.389, Y 120.418, Z 185.870, A -148.871, B 38.589, C -97.011} C_DIS
LIN {X 200.001, Y 120.802, Z 184.961, A -148.868, B 38.365, C -96.975} C_DIS
LIN {X 200.338, Y 120.917, Z 184.520, A -148.886, B 38.257, C -96.969} C_DIS
LIN {X 201.056, Y 121.001, Z 183.682, A -148.959, B 38.053, C -96.985} C_DIS
LIN {X 201.430, Y 120.982, Z 183.285, A -149.010, B 37.956, C -97.002} C_DIS
LIN {X 204.123, Y 119.991, Z 180.942, A -149.551, B 37.386, C -97.250} C_DIS
LIN {X 206.267, Y 118.404, Z 179.551, A -150.143, B 37.051, C -97.562} C_DIS
LIN {X 206.926, Y 117.764, Z 179.213, A -150.355, B 36.969, C -97.679} C_DIS
LIN {X 207.552, Y 117.079, Z 178.937, A -150.573, B 36.903, C -97.803} C_DIS
LIN {X 208.697, Y 115.587, Z 178.576, A -151.020, B 36.816, C -98.064} C_DIS
LIN {X 209.697, Y 113.981, Z 178.437, A -151.474, B 36.783, C -98.340} C_DIS
LIN {X 210.150, Y 113.149, Z 178.432, A -151.701, B 36.783, C -98.481} C_DIS
LIN {X 210.576, Y 112.302, Z 178.466, A -151.929, B 36.790, C -98.624} C_DIS
LIN {X 211.353, Y 110.572, Z 178.627, A -152.383, B 36.828, C -98.915} C_DIS
LIN {X 212.667, Y 107.036, Z 179.220, A -153.284, B 36.971, C -99.511} C_DIS
LIN {X 214.251, Y 101.651, Z 180.465, A -154.618, B 37.271, C -100.425} C_DIS
LIN {X 215.230, Y 98.051, Z 181.290, A -155.508, B 37.471, C -101.046} C_DIS
LIN {X 216.170, Y 94.450, Z 182.082, A -156.398, B 37.663, C -101.672} C_DIS
LIN {X 217.936, Y 87.238, Z 183.569, A -158.184, B 38.025, C -102.947} C_DIS
LIN {X 224.750, Y 64.644, Z 184.696, A -163.953, B 38.300, C -106.985} C_DIS
LIN {X 225.980, Y 70.150, Z 181.152, A -162.754, B 37.437, C -105.851} C_DIS
LIN {X 225.368, Y 73.357, Z 180.643, A -161.970, B 37.314, C -105.275} C_DIS
LIN {X 224.709, Y 76.561, Z 180.134, A -161.186, B 37.191, C -104.705} C_DIS
LIN {X 221.026, Y 92.549, Z 177.162, A -157.280, B 36.477, C -101.928} C_DIS
LIN {X 218.200, Y 103.728, Z 174.452, A -154.575, B 35.832, C -100.059} C_DIS
LIN {X 217.769, Y 106.913, Z 173.062, A -153.851, B 35.503, C -99.536} C_DIS
LIN {X 218.045, Y 109.449, Z 171.118, A -153.345, B 35.045, C -99.125} C_DIS
LIN {X 218.177, Y 109.755, Z 170.753, A -153.295, B 34.959, C -99.075} C_DIS
LIN {X 218.528, Y 110.274, Z 169.968, A -153.224, B 34.776, C -98.992} C_DIS
LIN {X 221.499, Y 110.184, Z 166.138, A -153.552, B 33.884, C -98.985} C_DIS
LIN {X 223.313, Y 108.780, Z 164.628, A -154.028, B 33.535, C -99.183} C_DIS
LIN {X 224.917, Y 106.894, Z 163.677, A -154.580, B 33.316, C -99.452} C_DIS
LIN {X 225.865, Y 105.472, Z 163.293, A -154.969, B 33.227, C -99.657} C_DIS
LIN {X 226.299, Y 104.730, Z 163.170, A -155.165, B 33.199, C -99.764} C_DIS
LIN {X 227.082, Y 103.195, Z 163.060, A -155.561, B 33.174, C -99.989} C_DIS
LIN {X 228.077, Y 100.797, Z 163.171, A -156.157, B 33.199, C -100.346} C_DIS
LIN {X 228.646, Y 99.167, Z 163.373, A -156.553, B 33.246, C -100.593} C_DIS
LIN {X 229.662, Y 95.891, Z 163.904, A -157.338, B 33.368, C -101.093} C_DIS
LIN {X 230.576, Y 92.598, Z 164.513, A -158.120, B 33.508, C -101.603} C_DIS
LIN {X 232.238, Y 85.987, Z 165.758, A -159.683, B 33.796, C -102.644} C_DIS
LIN {X 237.130, Y 62.718, Z 169.232, A -165.185, B 34.603, C -106.447} C_DIS
LIN {X 237.692, Y 59.377, Z 169.650, A -165.974, B 34.701, C -107.013} C_DIS
LIN {X 241.262, Y 57.785, Z 165.099, A -166.531, B 33.644, C -106.949} C_DIS
LIN {X 240.461, Y 62.492, Z 164.551, A -165.432, B 33.517, C -106.176} C_DIS
LIN {X 239.597, Y 67.190, Z 163.960, A -164.335, B 33.381, C -105.415} C_DIS
LIN {X 237.676, Y 76.557, Z 162.644, A -162.146, B 33.078, C -103.923} C_DIS
LIN {X 235.495, Y 85.886, Z 161.151, A -159.963, B 32.737, C -102.472} C_DIS
LIN {X 234.305, Y 90.536, Z 160.338, A -158.873, B 32.551, C -101.762} C_DIS
LIN {X 233.049, Y 95.177, Z 159.479, A -157.785, B 32.355, C -101.061} C_DIS
LIN {X 230.728, Y 102.197, Z 158.506, A -156.110, B 32.134, C -100.030} C_DIS
LIN {X 227.598, Y 108.772, Z 158.656, A -154.456, B 32.168, C -99.097} C_DIS
LIN {X 226.989, Y 109.784, Z 158.832, A -154.189, B 32.208, C -98.955} C_DIS
LIN {X 225.001, Y 112.618, Z 159.674, A -153.411, B 32.399, C -98.561} C_DIS
LIN {X 222.753, Y 115.069, Z 161.072, A -152.680, B 32.718, C -98.219} C_DIS
LIN {X 219.236, Y 117.607, Z 164.037, A -151.789, B 33.398, C -97.855} C_DIS
LIN {X 218.766, Y 117.809, Z 164.519, A -151.697, B 33.510, C -97.826} C_DIS
LIN {X 217.409, Y 118.083, Z 166.114, A -151.492, B 33.878, C -97.781} C_DIS
LIN {X 216.600, Y 117.937, Z 167.270, A -151.432, B 34.146, C -97.800} C_DIS
LIN {X 215.179, Y 116.527, Z 170.070, A -151.563, B 34.799, C -98.006} C_DIS
LIN {X 212.512, Y 116.901, Z 173.139, A -151.185, B 35.521, C -97.921} C_DIS
LIN {X 210.216, Y 120.391, Z 173.549, A -150.200, B 35.618, C -97.346} C_DIS
LIN {X 208.945, Y 121.995, Z 173.963, A -149.721, B 35.716, C -97.075} C_DIS
LIN {X 207.594, Y 123.484, Z 174.529, A -149.254, B 35.850, C -96.817} C_DIS
LIN {X 203.065, Y 127.134, Z 177.216, A -147.950, B 36.490, C -96.127} C_DIS
LIN {X 202.229, Y 127.620, Z 177.821, A -147.745, B 36.635, C -96.023} C_DIS
LIN {X 198.841, Y 128.824, Z 180.750, A -147.062, B 37.340, C -95.700} C_DIS
LIN {X 198.027, Y 128.860, Z 181.616, A -146.947, B 37.550, C -95.655} C_DIS
LIN {X 197.242, Y 128.739, Z 182.554, A -146.868, B 37.777, C -95.635} C_DIS
LIN {X 196.867, Y 128.614, Z 183.046, A -146.843, B 37.897, C -95.635} C_DIS
LIN {X 195.851, Y 128.000, Z 184.560, A -146.833, B 38.267, C -95.675} C_DIS
LIN {X 194.288, Y 125.107, Z 188.160, A -147.221, B 39.154, C -96.034} C_DIS
LIN {X 194.127, Y 124.215, Z 188.917, A -147.386, B 39.342, C -96.164} C_DIS
LIN {X 191.309, Y 132.453, Z 186.175, A -145.303, B 38.664, C -94.756} C_DIS
LIN {X 187.885, Y 127.452, Z 193.026, A -145.849, B 40.371, C -95.287} C_DIS
LIN {X 190.388, Y 119.574, Z 195.598, A -147.869, B 41.024, C -96.703} C_DIS
LIN {X 191.566, Y 115.641, Z 196.809, A -148.882, B 41.333, C -97.426} C_DIS
LIN {X 192.697, Y 111.711, Z 197.971, A -149.898, B 41.631, C -98.160} C_DIS
LIN {X 196.769, Y 96.019, Z 202.154, A -153.989, B 42.716, C -101.199} C_DIS
LIN {X 197.678, Y 92.100, Z 203.088, A -155.019, B 42.961, C -101.985} C_DIS
LIN {X 211.758, Y 76.144, Z 217.554, A -160.223, B 44.032, C -106.065} C_DIS
LIN {X 42.454, Y -149.447, Z 271.721, A 105.858, B 60.241, C 150.212} C_DIS
LIN {X 44.373, Y -142.011, Z 258.201, A 107.352, B 60.048, C 151.788} C_DIS
LIN {X 60.135, Y -134.064, Z 259.258, A 114.159, B 60.458, C 159.383} C_DIS
LIN {X 63.584, Y -127.382, Z 261.791, A 116.527, B 61.461, C 162.196} C_DIS
LIN {X 78.111, Y -97.258, Z 270.635, A 128.769, B 65.254, C 176.133} C_DIS
LIN {X 82.928, Y -86.441, Z 272.864, A 133.812, B 66.299, C -178.329} C_DIS
LIN {X 84.085, Y -83.853, Z 273.317, A 135.079, B 66.516, C -176.951} C_DIS
LIN {X 86.274, Y -78.731, Z 274.157, A 137.618, B 66.925, C -174.203} C_DIS
LIN {X 87.310, Y -76.196, Z 274.545, A 138.889, B 67.116, C -172.834} C_DIS
LIN {X 88.373, Y -73.725, Z 274.880, A 140.164, B 67.282, C -171.465} C_DIS
LIN {X 93.264, Y -61.606, Z 276.243, A 146.553, B 67.971, C -164.656} C_DIS
LIN {X 96.049, Y -54.557, Z 276.771, A 150.403, B 68.243, C -160.590} C_DIS
LIN {X 96.922, Y -52.214, Z 276.919, A 151.687, B 68.319, C -159.240} C_DIS
LIN {X 92.574, Y -52.484, Z 278.351, A 150.449, B 69.078, C -160.643} C_DIS
LIN {X 90.492, Y -52.628, Z 279.008, A 149.819, B 69.434, C -161.350} C_DIS
LIN {X 88.416, Y -52.730, Z 279.654, A 149.189, B 69.790, C -162.053} C_DIS
LIN {X 79.198, Y -56.862, Z 281.600, A 144.322, B 70.903, C -167.281} C_DIS
LIN {X 77.741, Y -60.623, Z 281.221, A 142.053, B 70.682, C -169.658} C_DIS
LIN {X 77.012, Y -62.541, Z 281.001, A 140.920, B 70.554, C -170.848} C_DIS
LIN {X 76.238, Y -64.453, Z 280.780, A 139.788, B 70.427, C -172.040} C_DIS
LIN {X 75.484, Y -66.412, Z 280.527, A 138.658, B 70.282, C -173.231} C_DIS
LIN {X 74.681, Y -68.366, Z 280.273, A 137.528, B 70.138, C -174.424} C_DIS
LIN {X 73.899, Y -70.374, Z 279.983, A 136.400, B 69.974, C -175.618} C_DIS
LIN {X 73.066, Y -72.376, Z 279.691, A 135.272, B 69.811, C -176.815} C_DIS
LIN {X 71.383, Y -76.497, Z 279.028, A 133.020, B 69.445, C -179.212} C_DIS
LIN {X 70.534, Y -78.622, Z 278.653, A 131.896, B 69.241, C 179.587} C_DIS
LIN {X 67.789, Y -85.122, Z 277.422, A 128.533, B 68.583, C 175.974} C_DIS
LIN {X 65.865, Y -89.653, Z 276.457, A 126.303, B 68.080, C 173.559} C_DIS
LIN {X 60.633, Y -101.707, Z 273.465, A 120.801, B 66.588, C 167.520} C_DIS
LIN {X 59.468, Y -104.219, Z 272.775, A 119.709, B 66.256, C 166.306} C_DIS
LIN {X 58.308, Y -106.817, Z 272.019, A 118.629, B 65.897, C 165.098} C_DIS
LIN {X 54.539, Y -114.808, Z 269.534, A 115.410, B 64.753, C 161.463} C_DIS
LIN {X 53.241, Y -117.627, Z 268.577, A 114.353, B 64.325, C 160.252} C_DIS
LIN {X 51.928, Y -120.542, Z 267.539, A 113.306, B 63.868, C 159.043} C_DIS
LIN {X 50.606, Y -123.567, Z 266.410, A 112.271, B 63.379, C 157.835} C_DIS
LIN {X 45.470, Y -113.567, Z 271.733, A 111.820, B 65.763, C 157.746} C_DIS
LIN {X 40.900, Y -100.207, Z 277.650, A 112.203, B 68.703, C 158.579} C_DIS
LIN {X 37.718, Y -91.181, Z 281.189, A 112.473, B 70.663, C 159.106} C_DIS
LIN {X 36.130, Y -86.632, Z 282.831, A 112.639, B 71.640, C 159.390} C_DIS
LIN {X 31.360, Y -72.996, Z 287.214, A 113.249, B 74.538, C 160.306} C_DIS
LIN {X 29.772, Y -68.470, Z 288.495, A 113.500, B 75.490, C 160.644} C_DIS
LIN {X 28.190, Y -63.962, Z 289.686, A 113.784, B 76.434, C 161.008} C_DIS
LIN {X 26.614, Y -59.478, Z 290.789, A 114.107, B 77.370, C 161.405} C_DIS
LIN {X 20.050, Y -55.091, Z 292.176, A 109.999, B 78.654, C 157.317} C_DIS
LIN {X 17.669, Y -55.168, Z 292.315, A 107.759, B 78.791, C 155.058} C_DIS
LIN {X 15.313, Y -55.143, Z 292.453, A 105.520, B 78.928, C 152.803} C_DIS
LIN {X 13.032, Y -55.208, Z 292.551, A 103.282, B 79.027, C 150.549} C_DIS
LIN {X 10.769, Y -55.180, Z 292.649, A 101.043, B 79.125, C 148.299} C_DIS
LIN {X 6.349, Y -55.204, Z 292.773, A 96.561, B 79.253, C 143.797} C_DIS
LIN {X 7.141, Y -57.333, Z 292.346, A 97.099, B 78.821, C 144.298} C_DIS
LIN {X 8.824, Y -61.731, Z 291.403, A 98.135, B 77.921, C 145.255} C_DIS
LIN {X 15.571, Y -79.195, Z 286.862, A 101.123, B 74.286, C 147.866} C_DIS
LIN {X 17.694, Y -84.677, Z 285.168, A 101.803, B 73.125, C 148.407} C_DIS
LIN {X 19.885, Y -90.320, Z 283.286, A 102.416, B 71.920, C 148.865} C_DIS
LIN {X 24.396, Y -101.884, Z 278.978, A 103.466, B 69.417, C 149.560} C_DIS
LIN {X 26.675, Y -107.695, Z 276.576, A 103.912, B 68.142, C 149.807} C_DIS
LIN {X 28.966, Y -113.516, Z 274.006, A 104.315, B 66.850, C 149.995} C_DIS
LIN {X 33.563, Y -125.129, Z 268.366, A 105.015, B 64.231, C 150.216} C_DIS
LIN {X 35.859, Y -130.895, Z 265.301, A 105.320, B 62.907, C 150.257} C_DIS
LIN {X 37.004, Y -133.763, Z 263.709, A 105.463, B 62.243, C 150.261} C_DIS
LIN {X 38.146, Y -136.618, Z 262.077, A 105.601, B 61.577, C 150.256} C_DIS
LIN {X 39.285, Y -139.459, Z 260.407, A 105.732, B 60.909, C 150.239} C_DIS
LIN {X 40.419, Y -142.285, Z 258.699, A 105.858, B 60.241, C 150.212} C_DIS
LIN {X 42.590, Y -149.924, Z 272.589, A 105.858, B 60.241, C 150.212} C_DIS
LIN {X 51.929, Y 102.302, Z 292.290, A -116.913, B 68.569, C -70.522} C_DIS
LIN {X 51.764, Y 101.976, Z 291.360, A -116.913, B 68.569, C -70.522} C_DIS
LIN {X 53.133, Y 96.867, Z 276.763, A -118.746, B 68.238, C -72.293} C_DIS
LIN {X 61.126, Y 96.351, Z 275.289, A -122.391, B 67.486, C -75.792} C_DIS
LIN {X 63.203, Y 96.223, Z 274.864, A -123.298, B 67.274, C -76.658} C_DIS
LIN {X 64.021, Y 110.698, Z 269.168, A -120.043, B 64.588, C -73.943} C_DIS
LIN {X 61.494, Y 134.740, Z 258.588, A -114.532, B 60.197, C -69.612} C_DIS
LIN {X 59.881, Y 147.800, Z 251.741, A -112.055, B 57.647, C -67.909} C_DIS
LIN {X 59.277, Y 152.311, Z 249.182, A -111.265, B 56.739, C -67.410} C_DIS
LIN {X 57.954, Y 161.568, Z 243.600, A -109.733, B 54.830, C -66.521} C_DIS
LIN {X 73.145, Y 163.568, Z 238.116, A -114.093, B 53.039, C -70.735} C_DIS
LIN {X 72.357, Y 167.582, Z 235.552, A -113.353, B 52.227, C -70.304} C_DIS
LIN {X 64.494, Y 168.658, Z 237.063, A -110.927, B 52.704, C -68.115} C_DIS
LIN {X 56.104, Y 173.327, Z 235.827, A -107.936, B 52.313, C -65.635} C_DIS
LIN {X 55.672, Y 176.159, Z 233.821, A -107.538, B 51.687, C -65.473} C_DIS
LIN {X 55.637, Y 177.109, Z 233.111, A -107.440, B 51.467, C -65.454} C_DIS
LIN {X 55.714, Y 178.108, Z 232.330, A -107.370, B 51.227, C -65.465} C_DIS
LIN {X 55.806, Y 178.602, Z 231.929, A -107.352, B 51.104, C -65.487} C_DIS
LIN {X 56.624, Y 180.325, Z 230.392, A -107.433, B 50.636, C -65.700} C_DIS
LIN {X 57.702, Y 181.105, Z 229.512, A -107.672, B 50.369, C -65.988} C_DIS
LIN {X 58.511, Y 181.410, Z 229.065, A -107.876, B 50.235, C -66.204} C_DIS
LIN {X 60.209, Y 181.691, Z 228.401, A -108.334, B 50.036, C -66.656} C_DIS
LIN {X 63.538, Y 181.662, Z 227.521, A -109.278, B 49.773, C -67.535} C_DIS
LIN {X 66.841, Y 181.236, Z 226.914, A -110.244, B 49.593, C -68.399} C_DIS
LIN {X 68.480, Y 180.942, Z 226.659, A -110.730, B 49.517, C -68.826} C_DIS
LIN {X 70.110, Y 180.605, Z 226.430, A -111.216, B 49.449, C -69.250} C_DIS
LIN {X 71.733, Y 180.226, Z 226.223, A -111.703, B 49.388, C -69.670} C_DIS
LIN {X 73.349, Y 179.811, Z 226.035, A -112.192, B 49.333, C -70.089} C_DIS
LIN {X 73.397, Y 183.430, Z 223.093, A -111.808, B 48.472, C -70.015} C_DIS
LIN {X 73.427, Y 187.019, Z 220.083, A -111.436, B 47.607, C -69.962} C_DIS
LIN {X 65.203, Y 189.002, Z 220.977, A -109.034, B 47.862, C -67.917} C_DIS
LIN {X 59.645, Y 189.859, Z 221.811, A -107.440, B 48.102, C -66.512} C_DIS
LIN {X 58.246, Y 190.001, Z 222.061, A -107.043, B 48.174, C -66.154} C_DIS
LIN {X 55.445, Y 190.152, Z 222.648, A -106.256, B 48.343, C -65.432} C_DIS
LIN {X 52.651, Y 190.078, Z 223.388, A -105.483, B 48.558, C -64.700} C_DIS
LIN {X 51.261, Y 189.939, Z 223.829, A -105.103, B 48.686, C -64.330} C_DIS
LIN {X 47.819, Y 189.133, Z 225.269, A -104.189, B 49.107, C -63.394} C_DIS
LIN {X 46.498, Y 188.585, Z 226.004, A -103.851, B 49.324, C -63.024} C_DIS
LIN {X 44.037, Y 186.966, Z 227.834, A -103.254, B 49.866, C -62.312} C_DIS
LIN {X 41.987, Y 183.724, Z 230.839, A -102.873, B 50.771, C -61.663} C_DIS
LIN {X 41.898, Y 177.307, Z 235.819, A -103.295, B 52.311, C -61.529} C_DIS
LIN {X 30.545, Y 171.842, Z 241.539, A -100.079, B 54.148, C -57.992} C_DIS
LIN {X 30.893, Y 167.836, Z 244.296, A -100.430, B 55.063, C -58.026} C_DIS
LIN {X 34.323, Y 163.637, Z 246.675, A -101.846, B 55.870, C -59.096} C_DIS
LIN {X 37.417, Y 163.410, Z 246.376, A -102.897, B 55.768, C -60.098} C_DIS
LIN {X 40.529, Y 163.203, Z 246.020, A -103.946, B 55.647, C -61.098} C_DIS
LIN {X 44.156, Y 158.366, Z 248.544, A -105.580, B 56.516, C -62.347} C_DIS
LIN {X 45.093, Y 149.396, Z 253.873, A -106.796, B 58.421, C -62.964} C_DIS
LIN {X 45.931, Y 140.662, Z 258.667, A -108.084, B 60.228, C -63.721} C_DIS
LIN {X 46.687, Y 132.172, Z 262.973, A -109.455, B 61.941, C -64.619} C_DIS
LIN {X 47.372, Y 123.943, Z 266.830, A -110.917, B 63.560, C -65.662} C_DIS
LIN {X 47.995, Y 115.972, Z 270.280, A -112.482, B 65.091, C -66.854} C_DIS
LIN {X 49.283, Y 97.089, Z 277.397, A -116.913, B 68.569, C -70.522} C_DIS
LIN {X 122.062, Y -91.093, Z 273.445, A 143.266, B 60.883, C -167.474} C_DIS
LIN {X 116.212, Y -86.728, Z 260.340, A 143.266, B 60.883, C -167.474} C_DIS
LIN {X 128.570, Y -84.988, Z 255.051, A 146.534, B 58.856, C -163.470} C_DIS
LIN {X 131.092, Y -84.582, Z 253.899, A 147.169, B 58.431, C -162.672} C_DIS
LIN {X 133.658, Y -84.201, Z 252.685, A 147.790, B 57.988, C -161.880} C_DIS
LIN {X 136.223, Y -83.768, Z 251.456, A 148.411, B 57.545, C -161.083} C_DIS
LIN {X 138.836, Y -83.359, Z 250.160, A 149.019, B 57.083, C -160.291} C_DIS
LIN {X 141.445, Y -82.899, Z 248.847, A 149.626, B 56.622, C -159.495} C_DIS
LIN {X 152.170, Y -80.980, Z 243.086, A 151.980, B 54.659, C -156.304} C_DIS
LIN {X 154.926, Y -80.477, Z 241.507, A 152.550, B 54.137, C -155.503} C_DIS
LIN {X 157.804, Y -77.629, Z 240.573, A 153.806, B 53.832, C -153.963} C_DIS
LIN {X 157.765, Y -74.178, Z 241.685, A 154.818, B 54.196, C -152.904} C_DIS
LIN {X 157.674, Y -73.025, Z 242.096, A 155.149, B 54.331, C -152.565} C_DIS
LIN {X 157.536, Y -71.873, Z 242.530, A 155.476, B 54.475, C -152.235} C_DIS
LIN {X 157.086, Y -69.564, Z 243.493, A 156.114, B 54.795, C -151.605} C_DIS
LIN {X 155.676, Y -66.091, Z 245.359, A 156.997, B 55.422, C -150.794} C_DIS
LIN {X 154.972, Y -64.981, Z 246.100, A 157.251, B 55.674, C -150.584} C_DIS
LIN {X 154.138, Y -63.917, Z 246.901, A 157.478, B 55.948, C -150.410} C_DIS
LIN {X 153.167, Y -62.914, Z 247.762, A 157.669, B 56.244, C -150.283} C_DIS
LIN {X 152.627, Y -62.440, Z 248.214, A 157.750, B 56.401, C -150.238} C_DIS
LIN {X 150.785, Y -61.176, Z 249.651, A 157.917, B 56.904, C -150.196} C_DIS
LIN {X 149.393, Y -60.518, Z 250.646, A 157.947, B 57.256, C -150.261} C_DIS
LIN {X 147.920, Y -60.025, Z 251.636, A 157.913, B 57.609, C -150.395} C_DIS
LIN {X 143.489, Y -59.542, Z 254.302, A 157.464, B 58.579, C -151.146} C_DIS
LIN {X 137.111, Y -60.623, Z 257.545, A 156.148, B 59.797, C -152.891} C_DIS
LIN {X 136.022, Y -60.998, Z 258.034, A 155.847, B 59.984, C -153.265} C_DIS
LIN {X 131.235, Y -63.399, Z 259.927, A 154.215, B 60.720, C -155.220} C_DIS
LIN {X 129.592, Y -64.520, Z 260.475, A 153.533, B 60.936, C -156.015} C_DIS
LIN {X 127.381, Y -66.329, Z 261.110, A 152.493, B 61.188, C -157.210} C_DIS
LIN {X 124.771, Y -68.943, Z 261.693, A 151.077, B 61.422, C -158.816} C_DIS
LIN {X 119.724, Y -76.245, Z 262.025, A 147.510, B 61.555, C -162.798} C_DIS
LIN {X 116.611, Y -84.829, Z 260.787, A 143.966, B 61.060, C -166.705} C_DIS
LIN {X 122.452, Y -91.384, Z 274.318, A 143.266, B 60.883, C -167.474} C_DIS
LIN {X 122.452, Y -91.384, Z 320.000, A 143.266, B 60.883, C -167.251} C_DIS
LIN {X -68.485, Y -136.215, Z 256.046, A 63.308, B 59.228, C 108.277} C_DIS
LIN {X -70.945, Y -115.818, Z 265.249, A 58.510, B 62.885, C 104.524} C_DIS
LIN {X -72.489, Y -100.481, Z 271.022, A 54.193, B 65.432, C 100.859} C_DIS
LIN {X -72.783, Y -97.618, Z 271.988, A 53.292, B 65.883, C 100.069} C_DIS
LIN {X -73.000, Y -94.766, Z 272.937, A 52.392, B 66.333, C 99.275} C_DIS
LIN {X -73.460, Y -89.289, Z 274.655, A 50.555, B 67.170, C 97.633} C_DIS
LIN {X -73.698, Y -86.678, Z 275.426, A 49.627, B 67.555, C 96.794} C_DIS
LIN {X -73.869, Y -84.079, Z 276.185, A 48.699, B 67.941, C 95.951} C_DIS
LIN {X -74.856, Y -69.799, Z 279.873, A 42.998, B 69.913, C 90.672} C_DIS
LIN {X -75.014, Y -67.615, Z 280.366, A 42.030, B 70.191, C 89.763} C_DIS
LIN {X -75.119, Y -65.444, Z 280.853, A 41.063, B 70.469, C 88.851} C_DIS
LIN {X -75.483, Y -59.258, Z 282.126, A 38.134, B 71.214, C 86.072} C_DIS
LIN {X -75.564, Y -57.260, Z 282.516, A 37.154, B 71.449, C 85.137} C_DIS
LIN {X -75.681, Y -55.325, Z 282.870, A 36.168, B 71.664, C 84.194} C_DIS
LIN {X -75.753, Y -53.402, Z 283.220, A 35.182, B 71.879, C 83.249} C_DIS
LIN {X -83.198, Y -53.021, Z 281.195, A 32.508, B 70.667, C 80.767} C_DIS
LIN {X -89.260, Y -52.700, Z 279.391, A 30.558, B 69.645, C 78.990} C_DIS
LIN {X -91.120, Y -56.480, Z 278.049, A 31.793, B 68.915, C 80.199} C_DIS
LIN {X -90.590, Y -64.671, Z 276.433, A 35.523, B 68.068, C 83.726} C_DIS
LIN {X -90.460, Y -66.809, Z 275.967, A 36.448, B 67.829, C 84.595} C_DIS
LIN {X -90.282, Y -68.959, Z 275.496, A 37.373, B 67.590, C 85.460} C_DIS
LIN {X -90.137, Y -71.167, Z 274.981, A 38.293, B 67.332, C 86.318} C_DIS
LIN {X -89.943, Y -73.387, Z 274.461, A 39.212, B 67.074, C 87.172} C_DIS
LIN {X -89.782, Y -75.671, Z 273.893, A 40.125, B 66.795, C 88.017} C_DIS
LIN {X -88.478, Y -90.145, Z 269.906, A 45.535, B 64.921, C 92.947} C_DIS
LIN {X -88.197, Y -92.693, Z 269.135, A 46.424, B 64.573, C 93.742} C_DIS
LIN {X -87.643, Y -97.967, Z 267.442, A 48.184, B 63.826, C 95.300} C_DIS
LIN {X -87.374, Y -100.695, Z 266.515, A 49.051, B 63.424, C 96.059} C_DIS
LIN {X -86.696, Y -110.881, Z 262.666, A 51.978, B 61.815, C 98.564} C_DIS
LIN {X -87.211, Y -115.900, Z 260.318, A 53.040, B 60.874, C 99.424} C_DIS
LIN {X -87.448, Y -116.825, Z 259.824, A 53.184, B 60.679, C 99.533} C_DIS
LIN {X -87.748, Y -117.767, Z 259.298, A 53.310, B 60.473, C 99.624} C_DIS
LIN {X -88.114, Y -118.694, Z 258.750, A 53.411, B 60.261, C 99.693} C_DIS
LIN {X -89.092, Y -120.430, Z 257.610, A 53.507, B 59.822, C 99.735} C_DIS
LIN {X -90.475, Y -122.056, Z 256.360, A 53.452, B 59.347, C 99.641} C_DIS
LIN {X -92.024, Y -123.342, Z 255.191, A 53.274, B 58.909, C 99.444} C_DIS
LIN {X -94.457, Y -124.660, Z 253.657, A 52.848, B 58.342, C 99.022} C_DIS
LIN {X -96.109, Y -125.231, Z 252.753, A 52.495, B 58.013, C 98.688} C_DIS
LIN {X -104.034, Y -125.819, Z 249.300, A 50.414, B 56.780, C 96.817} C_DIS
LIN {X -114.683, Y -121.755, Z 246.632, A 46.713, B 55.856, C 93.670} C_DIS
LIN {X -115.785, Y -120.907, Z 246.534, A 46.240, B 55.822, C 93.276} C_DIS
LIN {X -116.828, Y -119.989, Z 246.491, A 45.765, B 55.807, C 92.882} C_DIS
LIN {X -117.806, Y -119.003, Z 246.503, A 45.290, B 55.811, C 92.489} C_DIS
LIN {X -119.561, Y -116.835, Z 246.696, A 44.339, B 55.877, C 91.703} C_DIS
LIN {X -121.026, Y -114.415, Z 247.115, A 43.392, B 56.021, C 90.920} C_DIS
LIN {X -121.642, Y -113.116, Z 247.411, A 42.920, B 56.123, C 90.530} C_DIS
LIN {X -122.163, Y -111.784, Z 247.759, A 42.460, B 56.243, C 90.148} C_DIS
LIN {X -123.951, Y -104.722, Z 249.947, A 40.193, B 57.008, C 88.247} C_DIS
LIN {X -124.490, Y -101.868, Z 250.857, A 39.293, B 57.331, C 87.483} C_DIS
LIN {X -125.844, Y -93.412, Z 253.459, A 36.586, B 58.270, C 85.151} C_DIS
LIN {X -126.964, Y -85.159, Z 255.797, A 33.851, B 59.135, C 82.749} C_DIS
LIN {X -127.648, Y -79.803, Z 257.180, A 32.013, B 59.657, C 81.113} C_DIS
LIN {X -129.365, Y -64.358, Z 260.627, A 26.450, B 60.996, C 76.071} C_DIS
LIN {X -129.837, Y -59.383, Z 261.572, A 24.578, B 61.373, C 74.347} C_DIS
LIN {X -130.074, Y -56.925, Z 262.001, A 23.636, B 61.546, C 73.476} C_DIS
LIN {X -130.264, Y -54.476, Z 262.427, A 22.694, B 61.718, C 72.601} C_DIS
LIN {X -130.478, Y -52.048, Z 262.813, A 21.747, B 61.875, C 71.719} C_DIS
LIN {X -133.716, Y -49.371, Z 261.699, A 20.265, B 61.424, C 70.449} C_DIS
LIN {X -143.007, Y -48.443, Z 256.917, A 18.714, B 59.557, C 69.389} C_DIS
LIN {X -141.704, Y -62.565, Z 254.577, A 23.822, B 58.681, C 74.083} C_DIS
LIN {X -141.316, Y -66.173, Z 253.880, A 25.092, B 58.424, C 75.235} C_DIS
LIN {X -140.901, Y -69.815, Z 253.134, A 26.358, B 58.151, C 76.377} C_DIS
LIN {X -138.950, Y -84.748, Z 249.629, A 31.380, B 56.896, C 80.835} C_DIS
LIN {X -138.384, Y -88.580, Z 248.611, A 32.624, B 56.540, C 81.919} C_DIS
LIN {X -136.494, Y -100.350, Z 245.160, A 36.323, B 55.354, C 85.092} C_DIS
LIN {X -133.672, Y -112.233, Z 241.536, A 40.017, B 54.147, C 88.164} C_DIS
LIN {X -127.316, Y -123.637, Z 239.392, A 44.160, B 53.449, C 91.509} C_DIS
LIN {X -126.648, Y -124.384, Z 239.359, A 44.483, B 53.439, C 91.768} C_DIS
LIN {X -115.166, Y -132.394, Z 240.858, A 48.981, B 53.925, C 95.423} C_DIS
LIN {X -113.312, Y -133.202, Z 241.292, A 49.613, B 54.067, C 95.947} C_DIS
LIN {X -98.169, Y -135.917, Z 246.360, A 54.161, B 55.762, C 99.865} C_DIS
LIN {X -97.069, Y -135.828, Z 246.845, A 54.449, B 55.929, C 100.126} C_DIS
LIN {X -91.557, Y -134.523, Z 249.650, A 55.761, B 56.903, C 101.354} C_DIS
LIN {X -87.312, Y -132.212, Z 252.390, A 56.559, B 57.881, C 102.162} C_DIS
LIN {X -82.510, Y -127.309, Z 256.492, A 57.052, B 59.397, C 102.785} C_DIS
LIN {X -82.138, Y -130.011, Z 255.254, A 57.716, B 58.932, C 103.305} C_DIS
LIN {X -81.708, Y -132.712, Z 253.999, A 58.380, B 58.468, C 103.820} C_DIS
LIN {X -84.916, Y -145.183, Z 263.970, A 59.677, B 57.496, C 104.800} C_DIS
LIN {X -85.187, Y -145.647, Z 320.000, A 59.677, B 57.496, C 103.633} C_DIS
LIN {X 180.039, Y -103.423, Z 234.219, A 150.125, B 48.444, C -156.725} C_DIS
LIN {X 171.411, Y -98.467, Z 222.995, A 150.125, B 48.444, C -156.725} C_DIS
LIN {X 171.306, Y -99.848, Z 222.460, A 149.764, B 48.289, C -157.125} C_DIS
LIN {X 171.232, Y -101.248, Z 221.883, A 149.405, B 48.123, C -157.522} C_DIS
LIN {X 171.205, Y -102.658, Z 221.256, A 149.052, B 47.942, C -157.909} C_DIS
LIN {X 172.280, Y -109.570, Z 217.067, A 147.544, B 46.753, C -159.464} C_DIS
LIN {X 172.899, Y -110.880, Z 215.907, A 147.328, B 46.429, C -159.644} C_DIS
LIN {X 174.240, Y -112.638, Z 213.909, A 147.119, B 45.874, C -159.744} C_DIS
LIN {X 174.784, Y -113.122, Z 213.209, A 147.089, B 45.681, C -159.722} C_DIS
LIN {X 175.370, Y -113.536, Z 212.507, A 147.081, B 45.488, C -159.671} C_DIS
LIN {X 178.022, Y -114.426, Z 209.806, A 147.269, B 44.753, C -159.182} C_DIS
LIN {X 178.729, Y -114.493, Z 209.169, A 147.357, B 44.580, C -159.006} C_DIS
LIN {X 181.595, Y -114.317, Z 206.782, A 147.809, B 43.940, C -158.180} C_DIS
LIN {X 187.103, Y -112.743, Z 202.695, A 148.928, B 42.858, C -156.271} C_DIS
LIN {X 194.606, Y -108.217, Z 198.044, A 150.922, B 41.650, C -153.090} C_DIS
LIN {X 195.741, Y -107.252, Z 197.449, A 151.280, B 41.497, C -152.543} C_DIS
LIN {X 197.896, Y -105.166, Z 196.421, A 152.013, B 41.234, C -151.448} C_DIS
LIN {X 198.912, Y -104.049, Z 195.989, A 152.386, B 41.123, C -150.902} C_DIS
LIN {X 201.696, Y -100.436, Z 195.026, A 153.529, B 40.878, C -149.285} C_DIS
LIN {X 202.533, Y -99.153, Z 194.815, A 153.915, B 40.824, C -148.757} C_DIS
LIN {X 204.755, Y -95.121, Z 194.503, A 155.082, B 40.745, C -147.217} C_DIS
LIN {X 205.987, Y -92.305, Z 194.558, A 155.862, B 40.759, C -146.236} C_DIS
LIN {X 207.430, Y -87.943, Z 195.045, A 157.025, B 40.883, C -144.850} C_DIS
LIN {X 208.570, Y -80.467, Z 197.047, A 158.903, B 41.394, C -142.838} C_DIS
LIN {X 208.435, Y -78.254, Z 198.079, A 159.422, B 41.659, C -142.361} C_DIS
LIN {X 208.139, Y -76.817, Z 198.951, A 159.743, B 41.884, C -142.102} C_DIS
LIN {X 207.639, Y -75.471, Z 199.985, A 160.025, B 42.151, C -141.912} C_DIS
LIN {X 204.734, Y -72.626, Z 203.994, A 160.469, B 43.200, C -141.944} C_DIS
LIN {X 202.752, Y -71.925, Z 206.210, A 160.468, B 43.787, C -142.245} C_DIS
LIN {X 198.611, Y -70.902, Z 210.548, A 160.354, B 44.954, C -142.953} C_DIS
LIN {X 191.477, Y -69.458, Z 217.523, A 160.062, B 46.881, C -144.182} C_DIS
LIN {X 189.460, Y -68.748, Z 219.506, A 160.056, B 47.442, C -144.436} C_DIS
LIN {X 188.027, Y -67.435, Z 221.139, A 160.270, B 47.909, C -144.392} C_DIS
LIN {X 187.701, Y -66.882, Z 221.584, A 160.388, B 48.036, C -144.311} C_DIS
LIN {X 187.080, Y -64.489, Z 222.814, A 160.980, B 48.391, C -143.790} C_DIS
LIN {X 187.051, Y -63.886, Z 223.012, A 161.143, B 48.449, C -143.630} C_DIS
LIN {X 187.062, Y -63.284, Z 223.175, A 161.309, B 48.496, C -143.463} C_DIS
LIN {X 187.108, Y -62.684, Z 223.305, A 161.478, B 48.534, C -143.288} C_DIS
LIN {X 187.295, Y -61.497, Z 223.479, A 161.823, B 48.584, C -142.922} C_DIS
LIN {X 187.585, Y -60.333, Z 223.553, A 162.171, B 48.606, C -142.542} C_DIS
LIN {X 189.010, Y -57.043, Z 223.215, A 163.206, B 48.508, C -141.349} C_DIS
LIN {X 190.383, Y -55.055, Z 222.547, A 163.871, B 48.314, C -140.531} C_DIS
LIN {X 191.199, Y -54.146, Z 222.070, A 164.188, B 48.176, C -140.122} C_DIS
LIN {X 191.644, Y -53.721, Z 221.790, A 164.341, B 48.096, C -139.919} C_DIS
LIN {X 193.140, Y -52.582, Z 220.762, A 164.770, B 47.801, C -139.319} C_DIS
LIN {X 195.422, Y -51.447, Z 219.014, A 165.251, B 47.303, C -138.570} C_DIS
LIN {X 196.646, Y -51.032, Z 218.014, A 165.452, B 47.020, C -138.221} C_DIS
LIN {X 199.893, Y -50.479, Z 215.171, A 165.827, B 46.224, C -137.441} C_DIS
LIN {X 203.346, Y -51.711, Z 211.614, A 165.732, B 45.244, C -137.067} C_DIS
LIN {X 203.751, Y -52.172, Z 211.110, A 165.637, B 45.107, C -137.103} C_DIS
LIN {X 204.106, Y -52.690, Z 210.638, A 165.525, B 44.978, C -137.160} C_DIS
LIN {X 205.383, Y -57.027, Z 208.254, A 164.482, B 44.334, C -137.978} C_DIS
LIN {X 205.463, Y -58.311, Z 207.819, A 164.156, B 44.217, C -138.278} C_DIS
LIN {X 211.924, Y -57.411, Z 201.485, A 164.842, B 42.542, C -136.638} C_DIS
LIN {X 211.331, Y -47.138, Z 204.747, A 167.426, B 43.399, C -134.305} C_DIS
LIN {X 210.577, Y -44.941, Z 206.014, A 167.953, B 43.735, C -133.924} C_DIS
LIN {X 209.509, Y -43.173, Z 207.475, A 168.356, B 44.125, C -133.702} C_DIS
LIN {X 208.845, Y -42.424, Z 208.298, A 168.517, B 44.346, C -133.646} C_DIS
LIN {X 208.085, Y -41.752, Z 209.192, A 168.654, B 44.587, C -133.626} C_DIS
LIN {X 207.223, Y -41.146, Z 210.166, A 168.770, B 44.850, C -133.637} C_DIS
LIN {X 206.317, Y -40.642, Z 211.153, A 168.856, B 45.118, C -133.681} C_DIS
LIN {X 200.184, Y -39.655, Z 217.158, A 168.795, B 46.779, C -134.548} C_DIS
LIN {X 193.674, Y -41.574, Z 222.634, A 167.885, B 48.339, C -136.217} C_DIS
LIN {X 192.634, Y -42.120, Z 223.433, A 167.666, B 48.571, C -136.551} C_DIS
LIN {X 189.861, Y -43.948, Z 225.445, A 166.967, B 49.159, C -137.549} C_DIS
LIN {X 186.983, Y -46.580, Z 227.314, A 166.012, B 49.712, C -138.805} C_DIS
LIN {X 182.864, Y -52.346, Z 229.401, A 164.026, B 50.336, C -141.212} C_DIS
LIN {X 182.366, Y -53.280, Z 229.582, A 163.714, B 50.391, C -141.575} C_DIS
LIN {X 181.890, Y -54.238, Z 229.735, A 163.396, B 50.437, C -141.942} C_DIS
LIN {X 181.435, Y -55.221, Z 229.861, A 163.072, B 50.475, C -142.313} C_DIS
LIN {X 181.001, Y -56.228, Z 229.959, A 162.743, B 50.504, C -142.687} C_DIS
LIN {X 180.298, Y -58.061, Z 230.056, A 162.150, B 50.534, C -143.355} C_DIS
LIN {X 179.678, Y -59.971, Z 230.051, A 161.542, B 50.532, C -144.030} C_DIS
LIN {X 178.294, Y -66.922, Z 229.209, A 159.426, B 50.278, C -146.314} C_DIS
LIN {X 178.211, Y -67.910, Z 228.983, A 159.140, B 50.210, C -146.613} C_DIS
LIN {X 178.160, Y -68.889, Z 228.730, A 158.860, B 50.134, C -146.904} C_DIS
LIN {X 178.143, Y -69.854, Z 228.450, A 158.589, B 50.051, C -147.183} C_DIS
LIN {X 178.995, Y -75.982, Z 225.813, A 156.999, B 49.267, C -148.723} C_DIS
LIN {X 180.507, Y -78.903, Z 223.597, A 156.389, B 48.619, C -149.190} C_DIS
LIN {X 183.480, Y -81.255, Z 220.311, A 156.114, B 47.672, C -149.143} C_DIS
LIN {X 191.610, Y -83.191, Z 212.530, A 156.531, B 45.495, C -147.724} C_DIS
LIN {X 197.010, Y -83.843, Z 207.271, A 156.946, B 44.070, C -146.568} C_DIS
LIN {X 199.050, Y -84.269, Z 205.138, A 157.054, B 43.502, C -146.163} C_DIS
LIN {X 199.989, Y -84.639, Z 204.070, A 157.061, B 43.220, C -146.017} C_DIS
LIN {X 200.409, Y -84.921, Z 203.540, A 157.036, B 43.080, C -145.978} C_DIS
LIN {X 200.780, Y -85.291, Z 203.020, A 156.984, B 42.943, C -145.973} C_DIS
LIN {X 201.520, Y -87.440, Z 201.365, A 156.544, B 42.510, C -146.296} C_DIS
LIN {X 201.536, Y -87.978, Z 201.115, A 156.417, B 42.445, C -146.420} C_DIS
LIN {X 200.703, Y -91.894, Z 200.195, A 155.399, B 42.206, C -147.567} C_DIS
LIN {X 200.291, Y -92.971, Z 200.110, A 155.100, B 42.184, C -147.931} C_DIS
LIN {X 199.812, Y -94.029, Z 200.094, A 154.799, B 42.180, C -148.309} C_DIS
LIN {X 197.373, Y -97.918, Z 200.648, A 153.614, B 42.324, C -149.886} C_DIS
LIN {X 194.939, Y -100.494, Z 201.752, A 152.728, B 42.611, C -151.160} C_DIS
LIN {X 193.166, Y -101.830, Z 202.785, A 152.203, B 42.882, C -151.962} C_DIS
LIN {X 192.254, Y -102.380, Z 203.374, A 151.964, B 43.036, C -152.340} C_DIS
LIN {X 191.320, Y -102.866, Z 204.009, A 151.735, B 43.204, C -152.710} C_DIS
LIN {X 186.873, Y -104.398, Z 207.325, A 150.810, B 44.085, C -154.279} C_DIS
LIN {X 185.778, Y -104.529, Z 208.241, A 150.636, B 44.330, C -154.603} C_DIS
LIN {X 183.483, Y -104.233, Z 210.412, A 150.400, B 44.917, C -155.137} C_DIS
LIN {X 183.100, Y -104.070, Z 210.827, A 150.387, B 45.030, C -155.197} C_DIS
LIN {X 181.813, Y -103.084, Z 212.419, A 150.448, B 45.464, C -155.282} C_DIS
LIN {X 181.552, Y -102.756, Z 212.800, A 150.491, B 45.569, C -155.266} C_DIS
LIN {X 181.316, Y -102.396, Z 213.175, A 150.545, B 45.672, C -155.236} C_DIS
LIN {X 180.915, Y -101.581, Z 213.904, A 150.687, B 45.873, C -155.129} C_DIS
LIN {X 180.273, Y -98.396, Z 215.926, A 151.374, B 46.434, C -154.467} C_DIS
LIN {X 180.295, Y -95.680, Z 217.124, A 152.046, B 46.770, C -153.750} C_DIS
LIN {X 180.614, Y -103.754, Z 234.968, A 150.125, B 48.444, C -156.725} C_DIS
LIN {X -46.551, Y -149.650, Z 320.000, A 72.721, B 60.058, C 116.098} C_DIS
LIN {X -44.179, Y -142.025, Z 258.227, A 72.721, B 60.058, C 116.984} C_DIS
LIN {X -32.612, Y -142.749, Z 259.544, A 77.131, B 60.570, C 121.234} C_DIS
LIN {X -29.588, Y -129.124, Z 266.937, A 77.094, B 63.607, C 121.917} C_DIS
LIN {X -29.824, Y -124.577, Z 269.063, A 76.537, B 64.541, C 121.586} C_DIS
LIN {X -30.047, Y -120.075, Z 271.078, A 75.951, B 65.458, C 121.214} C_DIS
LIN {X -30.258, Y -115.626, Z 272.982, A 75.335, B 66.355, C 120.799} C_DIS
LIN {X -30.644, Y -106.926, Z 276.463, A 74.008, B 68.083, C 119.837} C_DIS
LIN {X -30.826, Y -102.708, Z 278.037, A 73.294, B 68.909, C 119.287} C_DIS
LIN {X -29.757, Y -86.953, Z 283.474, A 71.108, B 72.037, C 117.633} C_DIS
LIN {X -29.097, Y -84.267, Z 284.353, A 70.950, B 72.593, C 117.552} C_DIS
LIN {X -28.703, Y -82.955, Z 284.778, A 70.914, B 72.869, C 117.552} C_DIS
LIN {X -27.270, Y -79.475, Z 285.909, A 71.062, B 73.623, C 117.790} C_DIS
LIN {X -25.649, Y -77.015, Z 286.731, A 71.580, B 74.193, C 118.365} C_DIS
LIN {X -25.115, Y -76.390, Z 286.946, A 71.800, B 74.345, C 118.598} C_DIS
LIN {X -24.075, Y -75.361, Z 287.307, A 72.283, B 74.605, C 119.103} C_DIS
LIN {X -23.091, Y -74.548, Z 287.599, A 72.790, B 74.818, C 119.625} C_DIS
LIN {X -21.250, Y -73.277, Z 288.068, A 73.828, B 75.166, C 120.687} C_DIS
LIN {X -19.550, Y -72.393, Z 288.411, A 74.888, B 75.426, C 121.761} C_DIS
LIN {X -17.959, Y -71.809, Z 288.661, A 75.959, B 75.618, C 122.840} C_DIS
LIN {X -16.444, Y -71.433, Z 288.844, A 77.037, B 75.760, C 123.922} C_DIS
LIN {X -14.981, Y -71.199, Z 288.981, A 78.117, B 75.868, C 125.003} C_DIS
LIN {X -13.555, Y -71.084, Z 289.080, A 79.204, B 75.946, C 126.089} C_DIS
LIN {X -12.157, Y -71.071, Z 289.146, A 80.293, B 75.998, C 127.176} C_DIS
LIN {X -10.781, Y -71.138, Z 289.184, A 81.382, B 76.028, C 128.260} C_DIS
LIN {X 0.000, Y -74.049, Z 288.653, A 90.000, B 75.612, C 136.808} C_DIS
LIN {X 5.681, Y -60.287, Z 291.783, A 95.383, B 78.276, C 142.519} C_DIS
LIN {X 6.335, Y -58.585, Z 292.116, A 96.172, B 78.595, C 143.344} C_DIS
LIN {X 1.903, Y -56.440, Z 292.600, A 91.931, B 79.076, C 139.131} C_DIS
LIN {X 0.000, Y -55.694, Z 292.749, A 90.000, B 79.229, C 137.211} C_DIS
LIN {X -4.214, Y -54.410, Z 292.960, A 85.571, B 79.448, C 132.801} C_DIS
LIN {X -17.818, Y -54.182, Z 292.491, A 71.796, B 78.966, C 119.058} C_DIS
LIN {X -19.062, Y -54.567, Z 292.341, A 70.744, B 78.816, C 118.004} C_DIS
LIN {X -24.126, Y -57.172, Z 291.468, A 67.121, B 77.981, C 114.358} C_DIS
LIN {X -27.040, Y -59.836, Z 290.676, A 65.682, B 77.271, C 112.885} C_DIS
LIN {X -28.176, Y -61.144, Z 290.296, A 65.259, B 76.943, C 112.442} C_DIS
LIN {X -31.883, Y -66.245, Z 288.789, A 64.299, B 75.717, C 111.399} C_DIS
LIN {X -33.172, Y -68.311, Z 288.162, A 64.099, B 75.236, C 111.161} C_DIS
LIN {X -34.551, Y -68.346, Z 287.991, A 63.182, B 75.108, C 110.256} C_DIS
LIN {X -34.846, Y -56.582, Z 290.496, A 58.373, B 77.115, C 105.706} C_DIS
LIN {X -34.864, Y -54.837, Z 290.829, A 57.552, B 77.405, C 104.919} C_DIS
LIN {X -36.527, Y -54.822, Z 290.627, A 56.325, B 77.229, C 103.709} C_DIS
LIN {X -39.955, Y -54.742, Z 290.191, A 53.875, B 76.855, C 101.297} C_DIS
LIN {X -47.417, Y -54.541, Z 289.104, A 48.997, B 75.965, C 96.516} C_DIS
LIN {X -49.407, Y -54.452, Z 288.787, A 47.781, B 75.716, C 95.330} C_DIS
LIN {X -49.294, Y -57.926, Z 288.130, A 49.603, B 75.212, C 97.081} C_DIS
LIN {X -49.254, Y -59.761, Z 287.761, A 50.505, B 74.937, C 97.944} C_DIS
LIN {X -48.795, Y -71.874, Z 285.056, A 55.827, B 73.051, C 102.977} C_DIS
LIN {X -48.599, Y -76.433, Z 283.901, A 57.550, B 72.305, C 104.577} C_DIS
LIN {X -48.122, Y -86.440, Z 281.098, A 60.895, B 70.610, C 107.624} C_DIS
LIN {X -47.952, Y -89.101, Z 280.296, A 61.712, B 70.151, C 108.355} C_DIS
LIN {X -47.292, Y -100.743, Z 276.439, A 64.853, B 68.071, C 111.086} C_DIS
LIN {X -47.135, Y -103.874, Z 275.304, A 65.593, B 67.494, C 111.706} C_DIS
LIN {X -46.461, Y -113.541, Z 271.576, A 67.746, B 65.690, C 113.460} C_DIS
LIN {X -45.433, Y -127.352, Z 265.559, A 70.366, B 63.016, C 115.431} C_DIS
LIN {X -45.141, Y -130.945, Z 263.855, A 70.979, B 62.303, C 115.859} C_DIS
LIN {X -44.835, Y -134.590, Z 262.067, A 71.576, B 61.573, C 116.261} C_DIS
LIN {X -46.402, Y -149.174, Z 271.225, A 72.721, B 60.058, C 116.984} C_DIS
LIN {X -46.551, Y -149.650, Z 272.092, A 72.721, B 60.058, C 116.984} C_DIS
$VEL.CP=0.00166666666666667
LIN {X -96.722, Y 146.800, Z 258.966, A -56.620, B 55.829, C -10.720} C_DIS
$VEL.CP=0.00333333333333333
LIN {X -85.395, Y 140.794, Z 248.372, A -58.762, B 56.456, C -13.180} C_DIS
LIN {X -75.630, Y 142.172, Z 250.741, A -61.989, B 57.290, C -16.820} C_DIS
LIN {X -72.424, Y 142.551, Z 251.472, A -63.067, B 57.550, C -18.019} C_DIS
LIN {X -69.267, Y 142.958, Z 252.129, A -64.149, B 57.787, C -19.216} C_DIS
LIN {X -66.118, Y 143.294, Z 252.783, A -65.231, B 58.023, C -20.405} C_DIS
LIN {X -63.011, Y 143.659, Z 253.368, A -66.317, B 58.237, C -21.594} C_DIS
LIN {X -59.913, Y 143.956, Z 253.951, A -67.403, B 58.450, C -22.773} C_DIS
LIN {X -56.849, Y 144.283, Z 254.470, A -68.495, B 58.641, C -23.956} C_DIS
LIN {X -53.793, Y 144.543, Z 254.985, A -69.587, B 58.832, C -25.130} C_DIS
LIN {X -50.765, Y 144.833, Z 255.442, A -70.684, B 59.002, C -26.307} C_DIS
LIN {X -47.744, Y 145.059, Z 255.895, A -71.782, B 59.172, C -27.477} C_DIS
LIN {X -44.743, Y 145.315, Z 256.292, A -72.886, B 59.321, C -28.650} C_DIS
LIN {X -41.829, Y 146.940, Z 255.858, A -74.110, B 59.158, C -30.027} C_DIS
LIN {X -42.207, Y 149.712, Z 254.182, A -74.256, B 58.535, C -30.349} C_DIS
LIN {X -44.323, Y 154.977, Z 250.643, A -74.040, B 57.255, C -30.463} C_DIS
LIN {X -51.804, Y 160.314, Z 245.804, A -72.092, B 55.573, C -28.779} C_DIS
LIN {X -52.832, Y 160.642, Z 245.371, A -71.795, B 55.426, C -28.488} C_DIS
LIN {X -57.919, Y 161.559, Z 243.615, A -70.277, B 54.835, C -26.938} C_DIS
LIN {X -58.941, Y 161.619, Z 243.330, A -69.964, B 54.740, C -26.608} C_DIS
LIN {X -70.881, Y 159.985, Z 241.215, A -66.104, B 54.042, C -22.325} C_DIS
LIN {X -72.779, Y 159.358, Z 241.065, A -65.454, B 53.993, C -21.573} C_DIS
LIN {X -78.219, Y 156.859, Z 241.000, A -63.496, B 53.972, C -19.259} C_DIS
LIN {X -79.934, Y 155.821, Z 241.111, A -62.843, B 54.008, C -18.473} C_DIS
LIN {X -83.187, Y 153.442, Z 241.536, A -61.536, B 54.147, C -16.881} C_DIS
LIN {X -86.134, Y 150.668, Z 242.248, A -60.244, B 54.381, C -15.286} C_DIS
LIN {X -91.046, Y 142.923, Z 245.128, A -57.502, B 55.344, C -11.840} C_DIS
LIN {X -91.776, Y 140.854, Z 246.051, A -56.913, B 55.657, C -11.092} C_DIS
LIN {X -97.031, Y 147.269, Z 259.794, A -56.620, B 55.829, C -10.720} C_DIS
LIN {X -97.031, Y 147.269, Z 320.000, A -56.620, B 55.829, C -10.426} C_DIS
LIN {X -139.676, Y 119.722, Z 320.000, A -40.601, B 54.135, C 8.480} C_DIS
LIN {X -139.676, Y 119.722, Z 254.466, A -40.601, B 54.135, C 8.758} C_DIS
LIN {X -139.231, Y 119.341, Z 253.656, A -40.601, B 54.135, C 8.758} C_DIS
LIN {X -132.559, Y 113.621, Z 241.500, A -40.601, B 54.135, C 8.758} C_DIS
LIN {X -133.342, Y 112.118, Z 241.772, A -40.058, B 54.225, C 9.412} C_DIS
LIN {X -134.152, Y 110.642, Z 242.003, A -39.514, B 54.301, C 10.067} C_DIS
LIN {X -135.876, Y 107.781, Z 242.332, A -38.422, B 54.409, C 11.381} C_DIS
LIN {X -138.779, Y 103.755, Z 242.444, A -36.783, B 54.446, C 13.359} C_DIS
LIN {X -139.848, Y 102.493, Z 242.367, A -36.237, B 54.421, C 14.021} C_DIS
LIN {X -142.183, Y 100.097, Z 242.009, A -35.146, B 54.303, C 15.355} C_DIS
LIN {X -143.462, Y 98.979, Z 241.715, A -34.603, B 54.206, C 16.026} C_DIS
LIN {X -148.570, Y 95.657, Z 239.960, A -32.776, B 53.633, C 18.336} C_DIS
LIN {X -149.385, Y 95.275, Z 239.605, A -32.529, B 53.518, C 18.657} C_DIS
LIN {X -153.831, Y 93.781, Z 237.371, A -31.368, B 52.802, C 20.219} C_DIS
LIN {X -156.807, Y 93.351, Z 235.587, A -30.766, B 52.238, C 21.085} C_DIS
LIN {X -157.834, Y 93.328, Z 234.909, A -30.596, B 52.026, C 21.345} C_DIS
LIN {X -162.166, Y 94.215, Z 231.581, A -30.156, B 50.997, C 22.159} C_DIS
LIN {X -163.948, Y 95.297, Z 229.877, A -30.168, B 50.480, C 22.292} C_DIS
LIN {X -166.568, Y 98.598, Z 226.578, A -30.623, B 49.493, C 22.023} C_DIS
LIN {X -166.990, Y 99.530, Z 225.858, A -30.796, B 49.281, C 21.871} C_DIS
LIN {X -167.317, Y 100.473, Z 225.198, A -30.985, B 49.086, C 21.694} C_DIS
LIN {X -167.730, Y 102.390, Z 224.024, A -31.402, B 48.743, C 21.275} C_DIS
LIN {X -167.842, Y 103.364, Z 223.492, A -31.626, B 48.588, C 21.039} C_DIS
LIN {X -167.907, Y 107.292, Z 221.585, A -32.578, B 48.037, C 19.995} C_DIS
LIN {X -167.742, Y 109.229, Z 220.762, A -33.071, B 47.801, C 19.432} C_DIS
LIN {X -167.470, Y 111.156, Z 220.005, A -33.574, B 47.584, C 18.847} C_DIS
LIN {X -167.113, Y 113.082, Z 219.294, A -34.085, B 47.382, C 18.241} C_DIS
LIN {X -160.818, Y 114.983, Z 222.981, A -35.564, B 48.440, C 16.057} C_DIS
LIN {X -151.506, Y 117.610, Z 228.075, A -37.821, B 49.938, C 12.842} C_DIS
LIN {X -148.436, Y 118.429, Z 229.664, A -38.584, B 50.415, C 11.784} C_DIS
LIN {X -136.325, Y 121.449, Z 235.520, A -41.697, B 52.217, C 7.601} C_DIS
LIN {X -133.347, Y 122.165, Z 236.851, A -42.494, B 52.637, C 6.562} C_DIS
LIN {X -130.368, Y 122.815, Z 238.169, A -43.291, B 53.056, C 5.533} C_DIS
LIN {X -127.419, Y 123.487, Z 239.415, A -44.102, B 53.456, C 4.497} C_DIS
LIN {X -121.553, Y 124.723, Z 241.812, A -45.737, B 54.238, C 2.441} C_DIS
LIN {X -118.636, Y 125.288, Z 242.966, A -46.562, B 54.619, C 1.418} C_DIS
LIN {X -117.167, Y 132.567, Z 239.795, A -48.529, B 53.580, C -1.008} C_DIS
LIN {X -116.960, Y 134.077, Z 239.056, A -48.901, B 53.341, C -1.475} C_DIS
LIN {X -116.638, Y 138.766, Z 236.524, A -49.952, B 52.533, C -2.814} C_DIS
LIN {X -116.666, Y 140.424, Z 235.530, A -50.280, B 52.220, C -3.240} C_DIS
LIN {X -116.791, Y 142.109, Z 234.455, A -50.585, B 51.884, C -3.642} C_DIS
LIN {X -117.419, Y 145.450, Z 232.080, A -51.087, B 51.150, C -4.323} C_DIS
LIN {X -119.616, Y 149.987, Z 228.035, A -51.427, B 49.926, C -4.842} C_DIS
LIN {X -120.154, Y 150.635, Z 227.324, A -51.422, B 49.714, C -4.851} C_DIS
LIN {X -122.071, Y 152.361, Z 225.142, A -51.298, B 49.070, C -4.734} C_DIS
LIN {X -124.290, Y 153.672, Z 223.027, A -51.034, B 48.453, C -4.427} C_DIS
LIN {X -125.064, Y 153.997, Z 222.369, A -50.919, B 48.263, C -4.286} C_DIS
LIN {X -126.643, Y 154.489, Z 221.131, A -50.657, B 47.906, C -3.958} C_DIS
LIN {X -131.482, Y 154.960, Z 217.954, A -49.686, B 47.003, C -2.690} C_DIS
LIN {X -136.241, Y 154.380, Z 215.428, A -48.572, B 46.296, C -1.181} C_DIS
LIN {X -137.806, Y 154.015, Z 214.693, A -48.179, B 46.091, C -0.640} C_DIS
LIN {X -139.357, Y 153.577, Z 214.004, A -47.779, B 45.901, C -0.085} C_DIS
LIN {X -140.893, Y 153.075, Z 213.357, A -47.373, B 45.722, C 0.482} C_DIS
LIN {X -145.388, Y 151.248, Z 211.637, A -46.132, B 45.251, C 2.233} C_DIS
LIN {X -151.067, Y 148.066, Z 209.903, A -44.425, B 44.779, C 4.670} C_DIS
LIN {X -153.748, Y 146.179, Z 209.278, A -43.555, B 44.610, C 5.917} C_DIS
LIN {X -155.044, Y 145.170, Z 209.024, A -43.116, B 44.541, C 6.546} C_DIS
LIN {X -159.908, Y 140.743, Z 208.387, A -41.353, B 44.370, C 9.063} C_DIS
LIN {X -164.201, Y 135.796, Z 208.331, A -39.591, B 44.354, C 11.545} C_DIS
LIN {X -166.123, Y 133.147, Z 208.516, A -38.712, B 44.405, C 12.762} C_DIS
LIN {X -167.887, Y 130.394, Z 208.842, A -37.836, B 44.492, C 13.959} C_DIS
LIN {X -168.711, Y 128.983, Z 209.055, A -37.399, B 44.550, C 14.549} C_DIS
LIN {X -169.497, Y 127.550, Z 209.299, A -36.962, B 44.615, C 15.135} C_DIS
LIN {X -170.244, Y 126.097, Z 209.572, A -36.527, B 44.689, C 15.712} C_DIS
LIN {X -172.259, Y 121.635, Z 210.561, A -35.226, B 44.957, C 17.409} C_DIS
LIN {X -172.857, Y 120.118, Z 210.942, A -34.795, B 45.061, C 17.960} C_DIS
LIN {X -174.430, Y 115.499, Z 212.223, A -33.511, B 45.411, C 19.570} C_DIS
LIN {X -176.609, Y 106.096, Z 215.307, A -30.995, B 46.262, C 22.580} C_DIS
LIN {X -177.127, Y 98.143, Z 218.627, A -28.990, B 47.193, C 24.802} C_DIS
LIN {X -177.029, Y 96.543, Z 219.418, A -28.606, B 47.417, C 25.202} C_DIS
LIN {X -176.537, Y 93.380, Z 221.176, A -27.877, B 47.919, C 25.927} C_DIS
LIN {X -176.113, Y 91.834, Z 222.159, A -27.540, B 48.202, C 26.241} C_DIS
LIN {X -175.549, Y 90.324, Z 223.222, A -27.227, B 48.510, C 26.514} C_DIS
LIN {X -174.407, Y 88.148, Z 224.980, A -26.813, B 49.023, C 26.836} C_DIS
LIN {X -173.939, Y 87.450, Z 225.614, A -26.691, B 49.209, C 26.918} C_DIS
LIN {X -171.647, Y 84.973, Z 228.300, A -26.338, B 50.006, C 27.068} C_DIS
LIN {X -170.265, Y 83.985, Z 229.696, A -26.255, B 50.425, C 27.025} C_DIS
LIN {X -169.518, Y 83.561, Z 230.402, A -26.240, B 50.639, C 26.972} C_DIS
LIN {X -165.330, Y 82.211, Z 233.905, A -26.439, B 51.713, C 26.390} C_DIS
LIN {X -163.559, Y 81.996, Z 235.222, A -26.626, B 52.123, C 26.042} C_DIS
LIN {X -160.108, Y 82.003, Z 237.581, A -27.120, B 52.869, C 25.240} C_DIS
LIN {X -152.199, Y 83.512, Z 242.209, A -28.754, B 54.369, C 22.917} C_DIS
LIN {X -149.316, Y 84.513, Z 243.652, A -29.510, B 54.848, C 21.915} C_DIS
LIN {X -147.933, Y 85.070, Z 244.301, A -29.901, B 55.065, C 21.407} C_DIS
LIN {X -146.598, Y 85.660, Z 244.899, A -30.298, B 55.266, C 20.897} C_DIS
LIN {X -145.311, Y 86.282, Z 245.447, A -30.701, B 55.452, C 20.384} C_DIS
LIN {X -142.868, Y 87.620, Z 246.405, A -31.520, B 55.778, C 19.357} C_DIS
LIN {X -136.461, Y 92.294, Z 248.323, A -34.072, B 56.439, C 16.243} C_DIS
LIN {X -133.672, Y 94.946, Z 248.840, A -35.386, B 56.619, C 14.671} C_DIS
LIN {X -131.926, Y 96.807, Z 249.054, A -36.271, B 56.694, C 13.619} C_DIS
LIN {X -130.270, Y 98.729, Z 249.171, A -37.158, B 56.735, C 12.569} C_DIS
LIN {X -127.238, Y 102.757, Z 249.110, A -38.924, B 56.714, C 10.484} C_DIS
LIN {X -125.854, Y 104.871, Z 248.931, A -39.804, B 56.651, C 9.448} C_DIS
LIN {X -124.553, Y 107.058, Z 248.655, A -40.680, B 56.555, C 8.416} C_DIS
LIN {X -121.102, Y 114.084, Z 247.231, A -43.291, B 56.061, C 5.331} C_DIS
LIN {X -123.940, Y 114.012, Z 245.854, A -42.611, B 55.590, C 6.182} C_DIS
LIN {X -173.023, Y 129.218, Z 320.000, A -36.753, B 46.549, C 14.107} C_DIS
LIN {X -173.023, Y 129.218, Z 227.951, A -36.753, B 46.549, C 14.943} C_DIS
LIN {X -159.622, Y 124.097, Z 218.917, A -37.863, B 47.275, C 13.304} C_DIS
LIN {X -155.064, Y 125.495, Z 221.383, A -38.984, B 47.979, C 11.684} C_DIS
LIN {X -150.533, Y 126.829, Z 223.737, A -40.115, B 48.659, C 10.081} C_DIS
LIN {X -146.029, Y 128.103, Z 225.985, A -41.259, B 49.318, C 8.491} C_DIS
LIN {X -141.552, Y 129.320, Z 228.130, A -42.414, B 49.955, C 6.914} C_DIS
LIN {X -137.101, Y 130.481, Z 230.178, A -43.583, B 50.571, C 5.347} C_DIS
LIN {X -132.676, Y 131.589, Z 232.133, A -44.764, B 51.166, C 3.790} C_DIS
LIN {X -128.276, Y 132.645, Z 233.997, A -45.959, B 51.741, C 2.239} C_DIS
LIN {X -128.019, Y 138.751, Z 230.572, A -47.304, B 50.690, C 0.535} C_DIS
LIN {X -128.580, Y 141.433, Z 228.622, A -47.725, B 50.102, C -0.009} C_DIS
LIN {X -129.528, Y 143.087, Z 227.052, A -47.847, B 49.634, C -0.170} C_DIS
LIN {X -131.747, Y 145.019, Z 224.535, A -47.745, B 48.892, C -0.036} C_DIS
LIN {X -132.563, Y 145.427, Z 223.790, A -47.650, B 48.675, C 0.090} C_DIS
LIN {X -133.385, Y 145.723, Z 223.108, A -47.531, B 48.477, C 0.250} C_DIS
LIN {X -136.043, Y 146.155, Z 221.213, A -47.052, B 47.930, C 0.897} C_DIS
LIN {X -136.959, Y 146.165, Z 220.640, A -46.862, B 47.766, C 1.156} C_DIS
LIN {X -137.873, Y 146.116, Z 220.103, A -46.663, B 47.612, C 1.428} C_DIS
LIN {X -139.653, Y 145.864, Z 219.146, A -46.246, B 47.340, C 2.001} C_DIS
LIN {X -141.369, Y 145.458, Z 218.314, A -45.817, B 47.105, C 2.594} C_DIS
LIN {X -143.065, Y 144.934, Z 217.556, A -45.372, B 46.891, C 3.212} C_DIS
LIN {X -144.720, Y 144.309, Z 216.875, A -44.919, B 46.700, C 3.843} C_DIS
LIN {X -149.379, Y 141.890, Z 215.307, A -43.527, B 46.262, C 5.791} C_DIS
LIN {X -157.342, Y 134.900, Z 214.125, A -40.609, B 45.934, C 9.847} C_DIS
LIN {X -158.467, Y 133.522, Z 214.159, A -40.117, B 45.944, C 10.519} C_DIS
LIN {X -162.937, Y 125.983, Z 215.369, A -37.711, B 46.279, C 13.720} C_DIS
LIN {X -163.608, Y 124.334, Z 215.818, A -37.233, B 46.404, C 14.334} C_DIS
LIN {X -164.207, Y 122.634, Z 216.336, A -36.753, B 46.549, C 14.943} C_DIS
LIN {X -45.915, Y 132.239, Z 320.000, A -70.852, B 63.525, C -25.191} C_DIS
LIN {X -45.769, Y 131.818, Z 280.176, A -70.852, B 63.525, C -25.515} C_DIS
LIN {X -46.979, Y 119.745, Z 268.808, A -68.579, B 64.428, C -22.903} C_DIS
LIN {X -49.470, Y 116.601, Z 269.742, A -67.010, B 64.847, C -21.142} C_DIS
LIN {X -50.785, Y 115.218, Z 270.092, A -66.213, B 65.006, C -20.257} C_DIS
LIN {X -53.555, Y 112.798, Z 270.578, A -64.602, B 65.228, C -18.484} C_DIS
LIN {X -55.008, Y 111.747, Z 270.723, A -63.791, B 65.294, C -17.597} C_DIS
LIN {X -61.295, Y 108.491, Z 270.696, A -60.535, B 65.282, C -14.061} C_DIS
LIN {X -62.995, Y 107.905, Z 270.540, A -59.724, B 65.210, C -13.184} C_DIS
LIN {X -72.394, Y 106.269, Z 268.831, A -55.736, B 64.438, C -8.875} C_DIS
LIN {X -77.853, Y 106.432, Z 267.236, A -53.815, B 63.736, C -6.793} C_DIS
LIN {X -79.033, Y 106.600, Z 266.823, A -53.447, B 63.557, C -6.393} C_DIS
LIN {X -80.247, Y 106.839, Z 266.364, A -53.090, B 63.360, C -6.006} C_DIS
LIN {X -81.495, Y 107.163, Z 265.855, A -52.748, B 63.142, C -5.635} C_DIS
LIN {X -87.592, Y 110.094, Z 262.699, A -51.494, B 61.829, C -4.282} C_DIS
LIN {X -90.283, Y 112.470, Z 260.775, A -51.245, B 61.055, C -4.029} C_DIS
LIN {X -91.425, Y 113.891, Z 259.758, A -51.244, B 60.653, C -4.044} C_DIS
LIN {X -92.381, Y 115.404, Z 258.750, A -51.323, B 60.261, C -4.150} C_DIS
LIN {X -93.147, Y 116.962, Z 257.774, A -51.467, B 59.884, C -4.332} C_DIS
LIN {X -93.965, Y 119.311, Z 256.397, A -51.777, B 59.361, C -4.715} C_DIS
LIN {X -94.338, Y 120.843, Z 255.541, A -52.022, B 59.039, C -5.016} C_DIS
LIN {X -94.794, Y 125.273, Z 253.229, A -52.885, B 58.186, C -6.074} C_DIS
LIN {X -94.774, Y 126.704, Z 252.523, A -53.204, B 57.929, C -6.466} C_DIS
LIN {X -92.230, Y 129.888, Z 251.847, A -54.622, B 57.685, C -8.154} C_DIS
LIN {X -89.898, Y 130.215, Z 252.520, A -55.380, B 57.928, C -9.021} C_DIS
LIN {X -85.307, Y 130.863, Z 253.775, A -56.900, B 58.385, C -10.748} C_DIS
LIN {X -71.964, Y 132.537, Z 257.020, A -61.499, B 59.596, C -15.875} C_DIS
LIN {X -67.645, Y 133.014, Z 257.945, A -63.044, B 59.950, C -17.569} C_DIS
LIN {X -50.897, Y 134.569, Z 260.968, A -69.282, B 61.132, C -24.289} C_DIS
LIN {X -34.905, Y 135.637, Z 263.036, A -75.569, B 61.966, C -30.905} C_DIS
LIN {X -27.099, Y 136.012, Z 263.762, A -78.732, B 62.265, C -34.186} C_DIS
LIN {X -26.802, Y 144.024, Z 259.505, A -79.458, B 60.554, C -35.388} C_DIS
LIN {X -26.988, Y 146.702, Z 257.981, A -79.576, B 59.964, C -35.672} C_DIS
LIN {X -27.678, Y 150.713, Z 255.585, A -79.594, B 59.056, C -35.945} C_DIS
LIN {X -28.432, Y 153.329, Z 253.941, A -79.495, B 58.446, C -36.015} C_DIS
LIN {X -28.895, Y 154.590, Z 253.122, A -79.413, B 58.147, C -36.016} C_DIS
LIN {X -33.512, Y 161.842, Z 247.968, A -78.301, B 56.316, C -35.384} C_DIS
LIN {X -36.005, Y 164.090, Z 246.135, A -77.624, B 55.685, C -34.852} C_DIS
LIN {X -36.884, Y 164.739, Z 245.570, A -77.380, B 55.493, C -34.649} C_DIS
LIN {X -37.783, Y 165.342, Z 245.027, A -77.128, B 55.310, C -34.433} C_DIS
LIN {X -39.630, Y 166.419, Z 244.004, A -76.605, B 54.966, C -33.973} C_DIS
LIN {X -47.328, Y 169.260, Z 240.656, A -74.378, B 53.859, C -31.870} C_DIS
LIN {X -59.192, Y 170.139, Z 237.388, A -70.817, B 52.807, C -28.166} C_DIS
LIN {X -65.071, Y 169.532, Z 236.281, A -69.002, B 52.456, C -26.166} C_DIS
LIN {X -76.511, Y 166.525, Z 234.988, A -65.323, B 52.050, C -21.920} C_DIS
LIN {X -78.357, Y 165.785, Z 234.903, A -64.703, B 52.024, C -21.181} C_DIS
LIN {X -80.173, Y 164.976, Z 234.860, A -64.082, B 52.010, C -20.434} C_DIS
LIN {X -88.701, Y 159.938, Z 235.279, A -60.987, B 52.141, C -16.630} C_DIS
LIN {X -91.801, Y 157.477, Z 235.749, A -59.760, B 52.289, C -15.091} C_DIS
LIN {X -100.802, Y 147.019, Z 238.806, A -55.564, B 53.260, C -9.757} C_DIS
LIN {X -105.132, Y 137.993, Z 242.300, A -52.697, B 54.399, C -6.116} C_DIS
LIN {X -105.781, Y 136.070, Z 243.104, A -52.138, B 54.665, C -5.413} C_DIS
LIN {X -106.866, Y 132.144, Z 244.789, A -51.037, B 55.229, C -4.038} C_DIS
LIN {X -107.314, Y 130.150, Z 245.660, A -50.493, B 55.524, C -3.365} C_DIS
LIN {X -107.691, Y 128.135, Z 246.552, A -49.955, B 55.828, C -2.703} C_DIS
LIN {X -107.988, Y 126.097, Z 247.471, A -49.423, B 56.144, C -2.053} C_DIS
LIN {X -108.197, Y 124.033, Z 248.422, A -48.901, B 56.473, C -1.419} C_DIS
LIN {X -108.310, Y 119.822, Z 250.431, A -47.889, B 57.180, C -0.204} C_DIS
LIN {X -108.088, Y 116.565, Z 252.059, A -47.161, B 57.762, C 0.658} C_DIS
LIN {X -107.938, Y 115.445, Z 252.638, A -46.925, B 57.971, C 0.935} C_DIS
LIN {X -107.503, Y 113.180, Z 253.845, A -46.474, B 58.411, C 1.460} C_DIS
LIN {X -107.211, Y 112.042, Z 254.473, A -46.262, B 58.642, C 1.705} C_DIS
LIN {X -105.461, Y 107.530, Z 257.136, A -45.557, B 59.641, C 2.504} C_DIS
LIN {X -104.823, Y 106.395, Z 257.869, A -45.426, B 59.921, C 2.648} C_DIS
LIN {X -103.282, Y 104.145, Z 259.404, A -45.238, B 60.515, C 2.848} C_DIS
LIN {X -98.243, Y 99.283, Z 263.240, A -45.302, B 62.050, C 2.734} C_DIS
LIN {X -93.877, Y 96.797, Z 265.747, A -45.877, B 63.096, C 2.064} C_DIS
LIN {X -91.732, Y 95.947, Z 266.802, A -46.287, B 63.548, C 1.598} C_DIS
LIN {X -90.674, Y 95.595, Z 267.290, A -46.513, B 63.759, C 1.343} C_DIS
LIN {X -86.646, Y 94.584, Z 268.980, A -47.508, B 64.504, C 0.233} C_DIS
LIN {X -77.895, Y 93.799, Z 271.916, A -50.292, B 65.849, C -2.821} C_DIS
LIN {X -74.766, Y 93.867, Z 272.769, A -51.462, B 66.253, C -4.089} C_DIS
LIN {X -73.263, Y 93.956, Z 273.146, A -52.055, B 66.434, C -4.730} C_DIS
LIN {X -64.896, Y 95.001, Z 274.895, A -55.663, B 67.289, C -8.603} C_DIS
LIN {X -62.326, Y 95.534, Z 275.305, A -56.880, B 67.494, C -9.903} C_DIS
LIN {X -59.850, Y 96.151, Z 275.639, A -58.100, B 67.663, C -11.204} C_DIS
LIN {X -55.123, Y 97.654, Z 276.096, A -60.557, B 67.895, C -13.820} C_DIS
LIN {X -44.410, Y 103.243, Z 275.994, A -66.725, B 67.843, C -20.402} C_DIS
LIN {X -38.491, Y 108.120, Z 275.014, A -70.404, B 67.348, C -24.369} C_DIS
LIN {X -35.664, Y 111.167, Z 274.179, A -72.213, B 66.935, C -26.345} C_DIS
LIN {X -34.743, Y 112.301, Z 273.835, A -72.809, B 66.767, C -27.002} C_DIS
LIN {X -32.062, Y 116.103, Z 272.573, A -74.563, B 66.160, C -28.957} C_DIS
LIN {X -29.584, Y 120.688, Z 270.856, A -76.227, B 65.356, C -30.862} C_DIS
LIN {X -28.821, Y 122.433, Z 270.154, A -76.754, B 65.034, C -31.481} C_DIS
LIN {X -31.871, Y 124.626, Z 268.806, A -75.655, B 64.427, C -30.451} C_DIS
LIN {X -164.784, Y -102.971, Z 320.000, A 32.001, B 51.770, C 80.093} C_DIS
LIN {X -164.259, Y -102.643, Z 245.870, A 32.001, B 51.770, C 81.891} C_DIS
LIN {X -156.387, Y -97.724, Z 234.087, A 32.001, B 51.770, C 81.891} C_DIS
LIN {X -156.282, Y -99.592, Z 233.370, A 32.508, B 51.547, C 82.317} C_DIS
LIN {X -156.305, Y -102.575, Z 232.058, A 33.275, B 51.143, C 82.963} C_DIS
LIN {X -156.387, Y -103.577, Z 231.557, A 33.517, B 50.990, C 83.168} C_DIS
LIN {X -156.701, Y -105.531, Z 230.460, A 33.959, B 50.656, C 83.545} C_DIS
LIN {X -157.259, Y -107.352, Z 229.236, A 34.319, B 50.286, C 83.858} C_DIS
LIN {X -158.113, Y -108.960, Z 227.886, A 34.572, B 49.882, C 84.089} C_DIS
LIN {X -158.668, Y -109.658, Z 227.164, A 34.649, B 49.667, C 84.167} C_DIS
LIN {X -160.922, Y -111.211, Z 224.811, A 34.648, B 48.973, C 84.226} C_DIS
LIN {X -161.823, Y -111.494, Z 224.023, A 34.566, B 48.743, C 84.184} C_DIS
LIN {X -164.698, Y -111.653, Z 221.838, A 34.134, B 48.110, C 83.916} C_DIS
LIN {X -167.588, Y -111.045, Z 219.971, A 33.529, B 47.575, C 83.516} C_DIS
LIN {X -168.501, Y -110.732, Z 219.431, A 33.311, B 47.421, C 83.369} C_DIS
LIN {X -169.383, Y -110.378, Z 218.930, A 33.090, B 47.279, C 83.220} C_DIS
LIN {X -173.440, Y -108.017, Z 216.922, A 31.914, B 46.713, C 82.414} C_DIS
LIN {X -174.185, Y -107.439, Z 216.611, A 31.667, B 46.626, C 82.242} C_DIS
LIN {X -175.611, Y -106.199, Z 216.071, A 31.163, B 46.475, C 81.890} C_DIS
LIN {X -178.754, Y -102.749, Z 215.160, A 29.890, B 46.221, C 80.986} C_DIS
LIN {X -179.853, Y -101.247, Z 214.956, A 29.377, B 46.164, C 80.615} C_DIS
LIN {X -180.868, Y -99.684, Z 214.835, A 28.861, B 46.131, C 80.239} C_DIS
LIN {X -181.803, Y -98.066, Z 214.790, A 28.343, B 46.118, C 79.857} C_DIS
LIN {X -182.662, Y -96.399, Z 214.816, A 27.823, B 46.125, C 79.470} C_DIS
LIN {X -184.168, Y -92.940, Z 215.054, A 26.778, B 46.191, C 78.680} C_DIS
LIN {X -187.631, Y -80.136, Z 217.202, A 23.127, B 46.791, C 75.793} C_DIS
LIN {X -188.463, Y -74.571, Z 218.460, A 21.588, B 47.146, C 74.521} C_DIS
LIN {X -188.640, Y -72.712, Z 218.934, A 21.079, B 47.280, C 74.092} C_DIS
LIN {X -188.751, Y -67.166, Z 220.603, A 19.588, B 47.755, C 72.799} C_DIS
LIN {X -188.621, Y -65.340, Z 221.261, A 19.107, B 47.944, C 72.367} C_DIS
LIN {X -187.877, Y -61.627, Z 222.953, A 18.160, B 48.432, C 71.478} C_DIS
LIN {X -187.564, Y -60.722, Z 223.465, A 17.939, B 48.580, C 71.260} C_DIS
LIN {X -186.773, Y -58.984, Z 224.591, A 17.526, B 48.908, C 70.836} C_DIS
LIN {X -186.291, Y -58.164, Z 225.203, A 17.339, B 49.088, C 70.634} C_DIS
LIN {X -185.745, Y -57.393, Z 225.851, A 17.170, B 49.279, C 70.444} C_DIS
LIN {X -184.361, Y -56.029, Z 227.323, A 16.904, B 49.714, C 70.107} C_DIS
LIN {X -183.470, Y -55.437, Z 228.187, A 16.813, B 49.972, C 69.962} C_DIS
LIN {X -179.559, Y -54.319, Z 231.542, A 16.831, B 50.986, C 69.706} C_DIS
LIN {X -175.736, Y -54.911, Z 234.319, A 17.352, B 51.842, C 69.923} C_DIS
LIN {X -171.557, Y -57.099, Z 236.880, A 18.409, B 52.646, C 70.618} C_DIS
LIN {X -170.864, Y -57.658, Z 237.245, A 18.647, B 52.762, C 70.792} C_DIS
LIN {X -169.016, Y -59.474, Z 238.118, A 19.386, B 53.040, C 71.352} C_DIS
LIN {X -166.516, Y -62.807, Z 239.022, A 20.666, B 53.330, C 72.368} C_DIS
LIN {X -165.675, Y -64.204, Z 239.236, A 21.183, B 53.399, C 72.789} C_DIS
LIN {X -161.961, Y -73.200, Z 239.195, A 24.321, B 53.386, C 75.415} C_DIS
LIN {X -156.823, Y -73.128, Z 242.617, A 25.000, B 54.503, C 75.786} C_DIS
LIN {X -153.037, Y -68.624, Z 246.322, A 24.152, B 55.749, C 74.856} C_DIS
LIN {X -159.681, Y -55.341, Z 245.445, A 19.115, B 55.451, C 70.585} C_DIS
LIN {X -161.108, Y -53.445, Z 244.932, A 18.352, B 55.277, C 69.961} C_DIS
LIN {X -165.334, Y -49.005, Z 243.038, A 16.510, B 54.643, C 68.507} C_DIS
LIN {X -166.312, Y -48.186, Z 242.534, A 16.158, B 54.476, C 68.241} C_DIS
LIN {X -169.600, Y -45.925, Z 240.688, A 15.151, B 53.870, C 67.517} C_DIS
LIN {X -173.391, Y -44.121, Z 238.312, A 14.276, B 53.102, C 66.959} C_DIS
LIN {X -177.699, Y -42.984, Z 235.328, A 13.598, B 52.157, C 66.633} C_DIS
LIN {X -179.245, Y -42.796, Z 234.187, A 13.428, B 51.801, C 66.587} C_DIS
LIN {X -184.674, Y -43.138, Z 229.866, A 13.148, B 50.476, C 66.735} C_DIS
LIN {X -187.534, Y -44.177, Z 227.340, A 13.255, B 49.719, C 67.055} C_DIS
LIN {X -188.852, Y -44.932, Z 226.098, A 13.383, B 49.351, C 67.275} C_DIS
LIN {X -189.476, Y -45.358, Z 225.490, A 13.463, B 49.172, C 67.397} C_DIS
LIN {X -191.173, Y -46.806, Z 223.755, A 13.757, B 48.664, C 67.799} C_DIS
LIN {X -191.671, Y -47.336, Z 223.217, A 13.872, B 48.508, C 67.943} C_DIS
LIN {X -192.563, Y -48.459, Z 222.205, A 14.125, B 48.215, C 68.243} C_DIS
LIN {X -193.334, Y -49.657, Z 221.269, A 14.405, B 47.946, C 68.557} C_DIS
LIN {X -193.993, Y -50.914, Z 220.405, A 14.706, B 47.699, C 68.880} C_DIS
LIN {X -194.550, Y -52.215, Z 219.609, A 15.023, B 47.472, C 69.208} C_DIS
LIN {X -195.979, Y -57.653, Z 216.962, A 16.393, B 46.724, C 70.539} C_DIS
LIN {X -196.486, Y -64.670, Z 214.511, A 18.218, B 46.041, C 72.180} C_DIS
LIN {X -196.473, Y -66.082, Z 214.092, A 18.590, B 45.925, C 72.502} C_DIS
LIN {X -196.348, Y -68.913, Z 213.313, A 19.340, B 45.710, C 73.144} C_DIS
LIN {X -193.392, Y -85.903, Z 209.819, A 23.950, B 44.756, C 76.868} C_DIS
LIN {X -189.384, Y -96.790, Z 208.732, A 27.071, B 44.463, C 79.217} C_DIS
LIN {X -188.757, Y -98.090, Z 208.694, A 27.459, B 44.452, C 79.500} C_DIS
LIN {X -188.101, Y -99.372, Z 208.680, A 27.847, B 44.448, C 79.782} C_DIS
LIN {X -187.415, Y -100.636, Z 208.692, A 28.234, B 44.452, C 80.061} C_DIS
LIN {X -183.525, Y -106.629, Z 209.171, A 30.157, B 44.581, C 81.424} C_DIS
LIN {X -179.840, Y -110.964, Z 210.115, A 31.675, B 44.836, C 82.478} C_DIS
LIN {X -178.836, Y -111.974, Z 210.437, A 32.052, B 44.924, C 82.737} C_DIS
LIN {X -176.724, Y -113.895, Z 211.188, A 32.801, B 45.128, C 83.250} C_DIS
LIN {X -175.616, Y -114.805, Z 211.620, A 33.174, B 45.246, C 83.505} C_DIS
LIN {X -172.113, Y -117.260, Z 213.145, A 34.266, B 45.664, C 84.248} C_DIS
LIN {X -170.888, Y -117.981, Z 213.733, A 34.621, B 45.826, C 84.489} C_DIS
LIN {X -168.359, Y -119.268, Z 215.022, A 35.314, B 46.183, C 84.960} C_DIS
LIN {X -165.732, Y -120.337, Z 216.463, A 35.983, B 46.584, C 85.416} C_DIS
LIN {X -162.994, Y -121.182, Z 218.064, A 36.630, B 47.034, C 85.858} C_DIS
LIN {X -160.165, Y -121.717, Z 219.854, A 37.233, B 47.541, C 86.270} C_DIS
LIN {X -158.734, Y -121.828, Z 220.829, A 37.506, B 47.820, C 86.457} C_DIS
LIN {X -157.302, Y -121.810, Z 221.861, A 37.753, B 48.116, C 86.625} C_DIS
LIN {X -155.167, Y -121.510, Z 223.523, A 38.064, B 48.597, C 86.834} C_DIS
LIN {X -154.462, Y -121.328, Z 224.109, A 38.149, B 48.768, C 86.889} C_DIS
LIN {X -151.071, Y -119.653, Z 227.299, A 38.380, B 49.707, C 87.022} C_DIS
LIN {X -150.458, Y -119.176, Z 227.955, A 38.382, B 49.903, C 87.015} C_DIS
LIN {X -148.381, Y -116.892, Z 230.485, A 38.230, B 50.664, C 86.864} C_DIS
LIN {X -147.971, Y -116.259, Z 231.068, A 38.156, B 50.841, C 86.798} C_DIS
LIN {X -147.268, Y -114.945, Z 232.172, A 37.973, B 51.178, C 86.640} C_DIS
LIN {X -146.471, Y -112.882, Z 233.683, A 37.621, B 51.644, C 86.342} C_DIS
LIN {X -150.877, Y -99.933, Z 236.756, A 33.518, B 52.607, C 83.017} C_DIS
LIN {X -153.637, Y -98.859, Z 235.428, A 32.760, B 52.188, C 82.451} C_DIS
;FOLD PTP P3 Vel= 50 % PDATP3;%{PE}%R 5.2.26,%MKUKATPBASIS,%CMOVE,%VPTP,%P 1:PTP, 2:P3, 3:, 5:50, 7:PDATP3
$BWDSTART = FALSE
PDAT_ACT = {VEL 50,ACC 100,APO_DIST 100}
FDAT_ACT = {TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE}
BAS (#PTP_PARAMS,50)
$H_POS= {A1 5,A2 -90,A3 100,A4 5,A5 10,A6 -5,E1 0,E2 0,E3 0,E4 0,E5 0,E6 0}
PTP {A1 5,A2 -90,A3 100,A4 5,A5 10,A6 -5,E1 0,E2 0,E3 0,E4 0,E5 0,E6 0}
;ENDFOLD
END
[/noae]
thanks,
