Disable ethernet IP io
  • MellingTC
  • April 11, 2013 at 3:54 AM
  • MellingTC
    21
    I have a Fanuc robot that was controlled by an Allen Bradley Compact logic processor through Ethernet IP. We have removed the robot from the cell and would like to reuse it on a machine that does not have Ethernet IP. I can't even get the robot to move in teach mode because it is looking for a hold release from Ethernet IP IO. How do I convert the robot to use hard wired IO again. Or at least bypass the hold signal.
    Thanks,
  • TCP
    34
    • April 11, 2013 at 1:27 PM
    Disable UI under config. Then you should be able to move the robot using the pendant.
  • Sergei Troizky
    67
    650
    • April 12, 2013 at 12:28 AM
    Under MENU>System>Config, set Remote/Local setup to Local, and Enable UI signals to FALSE.
    Also, you may need to stop the Ethernet/IP connection in I/O>Ethernet/IP, by setting its Enable switch to FALSE.
    After such setup the robot will operate as a standalone unit with no host.
    In order to use hardwire signals, you need to have some discrete I/Os available in the robot and map UOP I/O to them.
    Edited once, last by Sergei Troizky (April 12, 2013 at 11:21 PM).
  • MellingTC
    21
    • April 12, 2013 at 2:22 PM
    That worked.
    Thank You
