  3. Simulation Systems
  4. Delmia / Igrip
Defining Tools
  • schnorklunder
  • December 5, 2011 at 5:22 PM
  • schnorklunder
    Guest
    Hello Guys,
    does anybody of you know how to define something as a tool? I´ve created my own gripper but delmia doesn´t know that this CATProduct File is a tool. Unfortenately i can´t use the Function "Set Tool" on the Device Task Definition Workbench.
    I hope this is an easier request :winking_face:
    greez schnorklunder
  • zqzx0608
    Guest
    • February 21, 2012 at 5:07 PM
    you can get more information from YOUTOBE. Searching Delmia, you will get more video. It is good for you to study it.
    You can contact me with ZQZX0608@126.com
  • locobot
    23
    • May 6, 2012 at 12:47 AM
    Here goes another late response...
    When you create your 'tool' or gripper in V5 device building you have to add Frames Of Interest to the product these define the attachment point and 'Tool Center Point' for your gripper. When you create your FOI you have to choose what type of frame you are creating. I believe Base = attachment frame, Tool = TCP.
  • nsinke
    • June 12, 2012 at 7:58 PM
    Do you have to create this gripper in Delmia or did you have to import it from some other software? Where's the "Set Tool" function?
  • nsinke
    • July 26, 2012 at 3:17 PM
    How do I add Frames of Interest? I'm in the CATProduct section and I know where the Frames of Interest option is, but I can't seem to get it to work.
  • enriqueboroni
    • July 15, 2014 at 7:34 PM
    Late answer for future researchers.
    A tool is created from scratch in two steps (at least).
    First you have to create or import the geometry. You can use CATIA for example, to create a product composed by some parts.
    Constraints created in the Assembly Design have effect further on the design, but not the Joints, that have to be created in DELMIA.
    Do not set up a constraint where you have to define a joint afterwards.
    Once you finish your design in CATIA, you have to open the tool in the Device Building workbench in DELMIA. There you are able to define the Frames of Interest, where you must configure the base frame and the tool center point. These two frames are references you will use to show the robot where to pick up the tool and which is the specific point the tool apply its force, spot weld, etc.
    Also, you have to define the tool joints and mechanisms, and create the commands to control the tool movements. At this point, you can also create home positions for the tool, that will be useful for positioning for example, the open and close states of a spot welding machine.
    Once you completed this tasks, the tool is ready to import into a DELMIA Process as a resource. To be able to use it as a robot tool, you have to "Set Tool" in the Robot Management toolbar. There you will be asked for the base frame and the tool center point. It is also important to create a Tool Profile, that you can use when you are teaching a task to your robot, to specify him which tool his is using at every moment (specially important when you change tools during a process).
    A tool can also mounted / unmounted, that is in case you have for example a quick exchanger.
  • alviter
    • July 23, 2014 at 1:53 PM
    hi if you want to créate a tool in delmia
    1. open your tool (step, igs, other.........)
    2. save as catpart
    3. open a new product
    4. in the three select components .......new part
    5. select the new part (right click) components then select replace component (search your product that you save as cat part)
    6. your cat part is now inserted
    7. select fixed part
    8. créate new mechanim select your tool a new mechanism has been created (see the three application mecanism )
    9. save the product
    10. now go to device task definition and insert in now you can use de tool set
    i hope this help you sorry for my english
