Good day everyone, after installing Directory Loader, we checked the example program attached in the manual, judging by the code, the addon should transfer the src file to a new one created, which will be named 1. It creates a folder, but does not copy the file there. KSS version 8.5.8. The most interesting thing is that it works great on KSS 8.6. What can be wrong? Thank you in advance!
1 DEF DirectoryLoaderExample(PGNO:IN, OLD_PGNO:IN)
2 DESCRIPTION
34
INT PGNO ; New program number (program to load)
5 INT OLD_PGNO ; Old program number (program to delete)
67
; Declarations for CWRITE commands
8 DECL STATE_T STAT
9 DECL MODUS_T MODE
10
11 ; Declarations for string functions
12 INT OFFSET
13
14 ; Set DirectoryLoader variables
15 DLCopyToKrc = TRUE
16 DLEditModule = FALSE
17 DLEnableBackup = TRUE
18 DLDeleteTarget = TRUE
19 DLDeleteSource = FALSE
20 DLEnableAllOpModes = FALSE
21 DLResetTrigger = FALSE
22
23 ; DirectoryLoader already active?
24 IF (DLACT OR $FLAG[27]) THEN
25 RETURN
26 ENDIF
27
28 ; Only start DirectoryLoader in EXT mode
29 IF (NOT DLEnableAllOpModes AND NOT $EXT) THEN
30 RETURN
31 ENDIF
32
33 ; Stop and cancel running robot program
34 IF ($PRO_STATE1 <> #P_FREE) THEN
35 MODE = #SYNC
36
37 CWRITE($CMD, STAT, MODE, "STOP 1")
38 WAIT SEC 0.1
39
40 CWRITE($CMD, STAT, MODE, "CANCEL 1")
41 WAIT SEC 0.1
42 ENDIF
43
44 ; Build source directory string
45 IF (NOT STRCLEAR(DLSourceDir[])) THEN
46 ;******************************************
47 ;* Error clearing source directory string *
48 ;* Handle error! *
49 ;******************************************
50 ENDIF
51
52 OFFSET = 0
53 SWRITE(DLSourceDir[], STAT, OFFSET, "D:\DirectoryLoader\
%d\", PGNO)
54
55 ; Build target directory string
56 IF (NOT STRCLEAR(DLTargetDir[])) THEN
57 ;******************************************
58 ;* Error clearing target directory string *
59 ;* Handle error!
60 ;******************************************
61 ENDIF
62
63 OFFSET = 0
64 SWRITE(DLTargetDir[], STAT, OFFSET, "KRC:\R1\Program\%d
\", PGNO)
65
66 ; Build backup directory string
67 IF (NOT STRCLEAR(DLBackupDir[])) THEN
68 ;******************************************
69 ;* Error clearing backup directory string *
70 ;* Handle error!
71 ;******************************************
72 ENDIF
73
74 OFFSET = 0
75 SWRITE(DLBackupDir[], STAT, OFFSET, "D:\DirectoryLoader\
%d\Backup\", PGNO)
76
77 ; Start DirectoryLoader and stop submit interpreter
78 ;********************************
79 ;* Adjust to configured trigger *
80 ;********************************
81 $FLAG[27] = TRUE
82 END
1 GLOBAL DEF DirectoryLoaderSub()
2 DESCRIPTION
4; Init
5 INT PGNO, OLD_PGNO
6 PGNO = 2
7 OLD_PGNO = 1
8
9; Loop
10 IF ($FLAG[28] AND NOT DLACT) THEN
11 DirectoryLoaderExample(PGNO, OLD_PGNO)
12 ENDIF
13
14 IF ($FLAG[28] AND DLRDY AND NOT DLERR) THEN
15 ; -> DirectoryLoader finished
16 $FLAG[27] = FALSE
17 $FLAG[28] = FALSE
18 WAIT SEC 0
19 ENDIF
20
21 IF ($FLAG[28] AND DLERR) THEN
22 ; -> An error occurred on execution
23 ; -> Call error handling
24 $FLAG[27] = FALSE
25 $FLAG[28] = FALSE
26 WAIT SEC 0
27 ENDIF
28 END
