WAIT on multiple signals in Yaskawa
  • Woebot
  • May 1, 2024 at 10:29 AM
  • Woebot
    5
    24
    Recently I have been wanting to use a WAIT command in Yasakwa programing (YRC1000) with multiple input signals, is this possible? As a work around I have either been using two waits in a row or been making small if loops, that works fine just wondering if there is a better method I could be using to improve my code.
    example of desired command:
    WAIT IN(1)=ON AND IN(2)=ON
    next steps...
    current code:
    WAIT IN(1)=ON
    WAIT IN(2)=ON
    next steps
    other example i sometime use:
    *Label1
    if IN(1)=ON AND IN(2)=ON
    Jump *Label2
    Jump *Label1
    *Label2
    next steps..
    Edited once, last by Woebot (May 1, 2024 at 1:59 PM).
  • WattUp
    7
    96
    • May 1, 2024 at 3:27 PM
    I commonly use the IF and label jump method; but make sure you add a timer in that loop. It gets angry otherwise
    You could maybe do a JUMP *Label IF IG#1 = #, if your inputs are on the same input grouping.
  • 95devils
    235
    8
    1,951
    • May 1, 2024 at 6:18 PM
    On YRC the WAIT can have up to 15 conditions. You can also write a rung in the ladder with the conditions and output to the General Purpose Input.
  • Woebot
    5
    24
    • May 2, 2024 at 1:24 AM
    Quote from WattUp
    I like they grouping idea, I'll try that in the future.
    I have never use timers in those if loops though, what does your timer usually do? Jump to an error routine or something? Not that I think having a timer is a bad idea just never though of it or had a controller crash or anything beceue of it (yet).
  • WattUp
    7
    96
    • May 2, 2024 at 10:10 PM
    I use the timer just to slow the scan down as it loops. The software does not (at least older ones didnt) like scanning through loops at full speed.
    LABEL 1
    IF COND
    JUMP LABEL 2
    ELSE
    Timer 0.1s
    JUMP LABEL 1
  • Woebot
    5
    24
    • May 7, 2024 at 4:52 AM
    oh gotcha, that is a good idea. I thought maybe you meant some sort of timeout function to stop it from looping indefinitely.
  • INFORM
  • wait
