After the failure of the motherboard in KPC Kuka KRC4 I replaced with the same model. It was a Fujitsu D3236-K13 GS4 model. After replacing the motherboard, the system booted up without any problems. But on the Smartpad there was an error KCP IP Could not set IP address ... .
After connecting the monitor to the KPC I found the following errors:
KSS00272 , KSS00276 etc.
Have you encountered this problem?
Can you advise me how to insert an image in the forum to the text?
