Hello everyone!
I am trying to replace an irb6600 robot with an irb660 robot.
The issue/problem here is that I only have the backup of the program and not the pack and go file of the original robot( the IRB6600) and as if everything weren't enough I still can't open it in robot studio because the required robotware version (4.0) is not supported by robot studio.
From what I was able to understand from ABB, it is possible to migrate the program almost directly, just needing to adjust some points, speeds and trajectories.
Will this be true or will I be forced to redo the entire program again with inputs and outputs and the control logic?
I would like to know if there was a RobotWare 4.0 version available so I could open the program?
Or is there not an older version of RobotStudio that supports robotware 4.0?
Tank you for all your support!
