How do I run input power to this thing? It's a 2010 model robot. R30ai controller. I need to simply run input 220VAC single phase as input power but don't know where in the internal power supply to simply wire up input power. Help is appreciated. I'm new and this is a new hobby.
Help
GA8314 -
April 20, 2024 at 4:23 PM -
Nation
April 20, 2024 at 4:45 PM Approved the thread. -
Nation
April 20, 2024 at 4:46 PM Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum. -
Default for a R-30iA controller is 3 phase 400 V (Europe) or 480 V (US). What is your exact controller type? Can you provide a photo of the name plate of the controller?!
Thank you for the reply. This is a 220vac for an LR200i. I figured it out.
That is correct. The Mate controller is normally 1 phase and 220 V (at least in Europe).
Generally for all robot cabinets you connect the input power to the main breaker.
But make sure that the supplied power has the correct voltage for your cabinet and also make sure that the capacity is sufficient (you should have the kVA-value on the metal sign on the cabinet), please check the manual for the controller.
