Good afternoon, my friends! Please tell me the sequence of transferring the working project of robot a krc 4 through work visual 6.0 to officelite 8.6. To test the robot program
Ryno -
March 27, 2024 at 4:54 PM -
process is exactly the same way it is done on a real robot...
If I upload a project from officelite using work visual, I upload it back without any problems. If I try to upload a working robot project to office lite, it doesn't work. The types of robots in office lite and in the work project are different.
Please tell me how to upload another robot's project to officelite?
start WoV, press F1 to open help (or click on ? then Help)
on search tab type transfer
that will get you few topics including "Transferring and activating project".
there are some prerequisites though... KSS version has to match.
you can change it to look for KRCs with other versions
the project is not loading
What is the correct ip address to assign from the work project or from officelite?
that is because you are not following instructions... Do not just blindly click on things. read the steps, read the messages. you are skipping step 3 which tells you to click on button with three dots. this is where you select new network path to a target controller. your screenshot clearly shows that target controller is without any info. you should see some details there including name or serial number and network address
The KSS version and option package must be the same between real controller and OfficeLite, and network setting must be the same also. if the real controller and OfficeLite everything same it should be work.
