Does anyone have a basic program for following a journal on a crankshaft
Fanuc programming
Wellrick -
March 8, 2024 at 1:35 AM -
I'd guess the likelihood that you can be helped will probably be much greater if you describe the task "a little" more precisely.
I'm trying to follow a crankshaft journal with a thermal spray gun and maintain a 15inch standoff.
So ... it's basically a periodic, uniform movement in one axis (like up and down in Z of the tool frame) that follows a sine curve?!
Edit:
... or do you actually follow the journal of the crankshaft thus it's a circular movement?
If you understand math you could write your own program to trace that profile. Otherwise I know RoboGuide and likely other offline programming software will allow you to import a cad file and generate a normal path from the geometry.
