I am trying to do a Lmove when I get the following error "(E1055) Start point position error for circle". The robot is a RD080N. I have a hard time figuring out what the cause of the error is. I have tried to be in contact with kawasaki technical support in Germany, they looked through my backup and recommended turning off the folloing zswitches ZCVMOVE2MOVE.NOBREAK and ZFIX_CVMOVE_NOBREAK. They also said I should try a lower accuracy. I turned off the zswitches and tried to increase the accuracy to 5000 with no luck (I have tried a range of accuracies from 1 to 5000). I am able to move the robot manually (it is a linear movement stright down in the z axis), I have also had some luck writing "do lmove Pos1" manually in the terminal. I cannot find any documentation as to what the error means, and I see no reason the robot should not be able to do the movement. Anyone who can recommend something?
