Power loss to encoder, trick the remaster process?
  • Duranthas
  • February 28, 2024 at 12:40 PM
  • Duranthas
    39
    When changing the J1 reducer on a M10 or M20 robot, it requires unhooking the wiring harness from the base and pulling it through the middle of the J1 joint. In doing so, I will lose power to all my encoders requiring a remaster of all joints. Is there a way to trick J2-J6 so that they can retain their position? Obviously, J1 will be off, but it seems like there should be a way to get the other 5 to play nice since they will be physically identical to where they were before power was removed from them.
    I know that I could move joints to their zero position before I turn off power, but that only works well for J4-J6. If J2 & J3 are at their zero marks, the robot is a bit unstable when the J1 is unbolted from the base so I'm uncomfortable with doing it that way.
  • pdl
    270
    1,548
    • February 28, 2024 at 8:40 PM
    Yes.
    Quick master.
  • ROBOT_G
    23
    241
    • February 29, 2024 at 5:20 AM
    We use a make shift battery pack and attach it to the battery backup leads off the battery box. It works just make sure you have 6volts.
    Of course you have to attach this while the power is on and the rcc cables are attached.
Users Viewing This Thread
  • 1 Guest
