Send output signal afther running X hours
  • kristofv
  • February 22, 2024 at 1:36 PM
  • kristofv
    51
    Hello all.
    I'm working with a yaskawa YRC 1000.
    I was wondering if it is possible to send an output signal when the running hours reach a certain value?
    Thanks all in advance :winking_face:
    This is what i do, that doesn't mean it's the right way to do it. :smiling_face:
  • Go to Best Answer
  • 95devils
    235
    8
    1,951
    • February 22, 2024 at 4:19 PM
    Sure. You could do it through the ladder using a timer to count down. Timer’s done turn on the output. This method depends on how many hours you need. The timer maximum is 6553.5 seconds.
    Another method would be use a Timer Variable with the SETTM instruction. You then could use a conditional instruction to turn on the output. Once again, this has a maximum amount that is even larger.
  • kristofv
    51
    • February 22, 2024 at 4:25 PM
    Great thanks for the answer!
    The reason why, is that I would like the robot to send an output when the running hours reach the
    point that maintenance is needed as a reminder.
    I know you can look it up but it's just a question :smiling_face:
    Are timers sufficient enough for this purpose?
  • 95devils
    235
    8
    1,951
    • February 22, 2024 at 4:31 PM
    • Best Answer
    The SETTM instruction would get you to 5,965 hours and change. Close enough for me for a 6000 hour service.
    Is the PM function not available on your controller?
  • running hours
