Shakey hand simulation
  • ChrisFS
  • February 16, 2024 at 11:57 AM
  • ChrisFS
    8
    hi all,
    my company makes a handheld measuring device, but it can also be attached to robots for automative purposes. we use a Kawasaki robot to do the calibration of this. the process is that the robot moves the device into position, start the robot "shaking", take a measurement, stop the "shaking", and move to the next position.
    the shaking a just basically moving the device suedo-randomly in the cartesian x/y axes around the main position using relative offset movements.
    we have aquired a Fanuc CRX-10iA and have written a Tablet plugin to measure with the device - which works fine BUT without the shaking bit.
    I've been reading that the robot can't be moved using KAREL code but was suggested that a KAREL program could start a TP program to "shake".
    would this be something like:
    RUN_TASK "looping shake TP prog" -> measure code -> ABORT_TASK "looping shake TP prog" ?
    but this of course bring me to TP programs which i have very little experience with. how would i go about doing the shake in the TP program? i can't seem to find anything about moving the robot relatively using offsets in an easy way.
    the "shaking" offsets just needs to be something like:
    X,Y,Z,Rx,Ry,Rz
    1,0,0,0,0,0 -- 1mm X axis
    0,1,0,0,0,0 -- 1mm Y axis
    -1,0,0,0,0,0 -- -1mm X axis
    0,-1,0,0,0,0 -- 1mm Y axis - back to the start position
    this is simplified a bit but to give a idea of what i need to achieve
    thanks in advance for any help you can give me.
    regards,
    Chris
  • PnsStarter
    96
    337
    • February 16, 2024 at 1:08 PM
    Hi
    use Offset command like
    J PR[10001] 100% FINE Offset,PR[10002]
    ( using local vars)
    Example:
    /PROG  TEST21
    1:J P[1] 100% FINE    ;
    2:  CALL SHAKE_RANDOM(5.1,1.1,1.1) ;
    3:J P[1] 100% FINE    ;
    /PROG  SHAKE_RANDOM
    1:  !AR[1]: MinMaxRandomX ;
    2:  !AR[2]: MinMaxRandomY ;
    3:  !AR[3]: MinMaxRandomZ ;
    4:  PR[10001]=LPOS    ;
    5:  R[10001]=AR[1]*(-1)    ;
    6:  R[10002]=AR[2]*(-1)    ;
    7:  R[10003]=AR[3]*(-1)    ;
    8:  !RAND2REG(Min,Max,targetReg) ;
    9:  CALL RAND2REG(R[10001],AR[1],1) ;
    10:  CALL RAND2REG(R[10002],AR[2],2) ;
    11:  CALL RAND2REG(R[10003],AR[3],3) ;
    12:  PR[10002,1]=R[1]    ;
    13:  PR[10002,2]=R[2]    ;
    14:  PR[10002,3]=R[3]    ;
    21:  PR[10002,4]=0    ;
    22:  PR[10002,5]=0    ;
    23:  PR[10002,6]=0    ;
    24:J PR[10001] 100% FINE Offset,PR[10002]    ;
    No global Vars Version:
    4:  PR[10001]=LPOS    ;
    15: CALL RAND2REG(R[10001],AR[1],10001) ;
    16: CALL RAND2REG(R[10002],AR[2],10002) ;
    17: CALL RAND2REG(R[10003],AR[3],10003) ;
    18: PR[10002,1]=R[10001]    ;
    19: PR[10002,2]=R[10002]    ;
    20: PR[10002,3]=R[10003]    ;
    21:  PR[10002,4]=0    ;
    22:  PR[10002,5]=0    ;
    23:  PR[10002,6]=0    ;
    RAND2REG is the sub prog which generate pseudo random values:
    TP-Tools/2reg/rand2reg at main · Backdate/TP-Tools (github.com)
    best
    Backdate/TP-Tools: A small collection of tools that simplify the commissioning and programming of Fanuc robots. (github.com)
  • ChrisFS
    8
    • February 16, 2024 at 3:10 PM
    hi @PnsStarter
    thanks for the quick answer. i think i can follow whats happening in there :smiling_face:
    but i get an error "INTP-204: (SHAKE_RANDOM, 4) Invalid value for index"
    here's the full code saved out...
    /PROG  SHAKE_RANDOM
    /ATTR
    OWNER        = MNEDITOR;
    COMMENT        = "";
    PROG_SIZE    = 582;
    CREATE        = DATE 24-02-16  TIME 14:00:36;
    MODIFIED    = DATE 24-02-16  TIME 14:00:36;
    FILE_NAME    = ;
    VERSION        = 0;
    LINE_COUNT    = 18;
    MEMORY_SIZE    = 890;
    PROTECT        = READ_WRITE;
    TCD:  STACK_SIZE    = 0,
          TASK_PRIORITY    = 50,
          TIME_SLICE    = 0,
          BUSY_LAMP_OFF    = 0,
          ABORT_REQUEST    = 0,
          PAUSE_REQUEST    = 0;
    DEFAULT_GROUP    = 1,*,*,*,*;
    CONTROL_CODE    = 00000000 00000000;
    LOCAL_REGISTERS    = 0,0,0;
    /MN
       4:  PR[10001]=LPOS    ;
       9:  CALL RAND2REG(R[10001],AR[1],10001) ;
      10:  CALL RAND2REG(R[10002],AR[2],10002) ;
      11:  CALL RAND2REG(R[10003],AR[3],10003) ;
      12:  PR[10002,1]=R[10001]    ;
      13:  PR[10002,2]=R[10002]    ;
      14:  PR[10002,3]=R[10003]    ;
      15:  PR[10002,4]=0    ;
      16:  PR[10002,5]=0    ;
      17:  PR[10002,6]=0    ;
      18:J PR[10001] 50% FINE Offset,PR[10002]    ;
    /POS
    /END
    Edited once, last by ChrisFS (February 16, 2024 at 3:21 PM).
  • PnsStarter
    96
    337
    • February 16, 2024 at 3:47 PM
    Quote from ChrisFS
    21 LOCAL_REGISTERS = 0,0,0;
    You have to setup your local registers in detail screen of prog
    e.g.
    LOCAL_REGISTERS = R,PR,SR; -->LOCAL_REGISTERS = 3,7,1;
    this will give you access to 3 local Register, 7 PR's and 1 StringReg
    in your case:
    LOCAL_REGISTERS = 3,2,0;
    Local Regs 10001-10003
    Local PRegs 10001-10002
    best
  • ChrisFS
    8
    • February 16, 2024 at 3:58 PM
    hi @PnsStarter
    yes that's working perfectly now. thank you.
    Regards,
    Chris
  • Nation
    Typical Robot Error
    556
    1,937
    • February 16, 2024 at 8:50 PM
    INC (incremental) motion option on a move could work as well.
  • FANUC KAREL PROGRAMMING
