FLEXIPICKER COMUNICATION PROFIBUS ERROR
CLOOD -
February 9, 2024 at 5:01 PM -
In your photo you can see signals that are mapped on a virtual board.
In the 2nd photo there are signals from the conveyor
There are no Profibus signals to be seenThere isn't enough information to help you
Thank you for the replay robiman
after i compare the status of the tow robot which are the same i found the even the dvicenet have problem we try to reach the support of the machine manufacturer they switch cf cards but doesn't seem the problem
I add some photos to of the io screen from the robot
Check the error logs
I always do it like this:
First delete all logs, then restart the system.
This way you only see current logs and it's a bit clearer.
After a restart you may see a message that will bring you closer to the cause.
