krc2ed05 saferobot
  • javaman
  • February 6, 2024 at 3:00 AM
  • javaman
    5
    318
    Hello.
    I have a krc2ed05 robot with unusual connectors . (is saferobot?)
    How can drive this robot with
    a standard krc2 or krc2ed05 controller?
    Thank you .
    Images
      • 158.25 kB
      • 903 × 1,200
      • 18
      • 310.58 kB
      • 1,593 × 1,200
      • 8
      • 255 kB
      • 1,593 × 1,200
      • 8
  • Go to Best Answer
  • DannyDJ
    67
    506
    • February 6, 2024 at 7:53 AM
    Hello, yes it is a safe robot, on the picture it is a SafeRDC box which is bigger than ordinary RDC Box. You can connect KRC2 ed05 or KRC2, but will have to have SafeOperation tech pack installed on it I think(which you can use or disable in the KSS, if you don't want to use it). You can also exchange the whole SafeRDC box with the ordinary RDC box, but will have to use jumper plug on A1 ESC card. Then you don't need to have SafeOperation installed.
    Images
      • 483.27 kB
      • 1,600 × 1,200
      • 12
  • javaman
    5
    318
    • February 6, 2024 at 11:59 AM
    I have krc2ed05 saferobot without its matching elelectric krc2ed05 cabinet but i have spare krc2(not ed05) cabinet.
    The first question is if can an ed05 robot work with krc2 cabinet or needs krc2ed05 cabinet?
    The second question is if a saferobot
    can work with a non saferobot cabinet
    that does not have installed esc-ci tech
    but esc-ci standard version.
    If i get a rdw board from an another krc2 robot
    and and use it instead the saferdw board of krc2ed05 robot will work or i need rdw board from krc2ed05 robot?
    krc2 and krc05 rdw boards are compatible?
  • DannyDJ
    67
    506
    • February 6, 2024 at 8:09 PM
    Quote from javaman
    That depends on KSS version that your krc2 cabinet has. For example if your krc2 cabinet has old KSS v4.1.7 SP08 or even older with WIN95(then it won't work because you won't find correct MADA for your newer KRC2ed05 robot because your robot wasn't produced at that time-> so no MADA), but if you have upgraded KRC2 to newer KSS from 5.x with DSE-IBS C33 then you will be able to find MADA for that robot) and this is meant in case if you have ordinary RDW (not safeRDC).
    If your KRC2 cabinet has old WIN95 with KSS v4.1.7 SP08 or older, this work with RDW1 and RDW2.(This i know because i have in past for some customers exchanged RDW1 with RDW2 even on KRC1 robots, because we had newer ones on stock, but never i did exchange the new RDW2 with old RDW1 on newer KRC2ed05 robots.) But problem is you don't have older robot, so you won't be able to find correct MADA for that robot on WIN95. But older robots for example KR15_2 you can find MADA for it even on KSS5.6.
    If you leave safeRDC on the robot you must have SafeOperation,(SafeOperation must be installed on in order to have communication with SafeRDC,but if you don't want to use it, you just disable it in Safeoperation settings, but must be installed). And SafeOperation was available only later from KSS5.x versions, i never saw it on win95 KSS versions).
    Quote from javaman
    I have checked the manual for the SafeOperation 1.0(i think this must be first version): this are requirements for the first version of SafeOperation, so I guess ESC CI 3 tech is a must and in the first post i was to fast to write that KRC2 can be used with saferobot.
    So for the third question, you have one KRC2 robot which could have RDW2 or for the worst case RDW1 board(if its old robot type for example KR15_2). if you have only RDW1 board, I think that won't work because you need mada from KSS5.x, but if you would have WIN95 with OLD KSSv4.1.7 SOP08 on KRC2 this one worked with RDW1 and RDW2,but you won't be able to find MADA for you robot. So I guess you will need RDW2. Like i said before I never tried to downgrade the robot with older RDW1. But you can always try and see with RDW1, it will either work or not :)-.
    Here is also link to the post with the same problem. In this case RDW1 did work with DSE-IBS C33 but he tested on WIN95 not on newer KSS5.x with XP.
    Post
    Re: KRC2 RDW1
    And why do you need to do that ? :smiling_face:
    Original KRC2s were running with RDW1 so it is/was possible but ...
    If I remember correctly software has to be KSS4.x or lower.
    DSE also had to be older model.
    Not sure about series 2000 robots.
    kr16_2
    April 6, 2014 at 3:18 PM
    Images
      • 62.67 kB
      • 774 × 480
      • 6
  • javaman
    5
    318
    • February 6, 2024 at 8:21 PM
    To clarify i have krc2 (not ed05) with soy motherboard with MFC2 & DSE-IBS C33 with winxp sp2 / kss 5.6.12 (hardware is not ed05 but software is ed05) and esc-ci standard version not esc-ci3 tech.
    If i get an rdw2 pcb from other krc2 robot and put it instead of saferdc will work ?
    Thank you.
  • DannyDJ
    67
    506
    • February 6, 2024 at 8:27 PM
    Quote from javaman
    Thank you.
    Yes that should work for sure with RDW2 and ESC standard. You just have then ordinary robot which can have different ESC cards. RDW2 even worked with KRC1. But with RDW1 I couldn't tell you for sure, because i never downgraded KRC2ed05 robots with RDW1.
  • javaman
    5
    318
    • February 7, 2024 at 1:55 AM
    I will use this rdw board instead of saferdc
    Kuka 71-039-271 RDW Board - Ballard International
    SPECS: use w/ KRC2, Resolver Digital Converter, 60MHz. CONDITION: USED - We buy and sell industrial robots, robotic systems, robot parts, and robot accessories.
    ballardintl.com
    This will work with krc2(not ed05) mfc2/dse-ibs c33/ kss 5.612 ?
  • DannyDJ
    67
    506
    • February 7, 2024 at 3:58 PM
    • Best Answer
    RDW card in your link is RDW1 card. You can tell which RDW is by searching for the LED lights on the card. RDW1 has only one green LED light(which shows you that RDW has power), RDW2 has 2 LED lights one green(for power), and RED one(for properly booting) RED LED light during booting flashes and after it stays on.
    If you have only RDW1 already, you can try with RDW1 and see, it will work or it won't work. With RDW2 it will work.
    Images
      • 386.96 kB
      • 1,080 × 1,075
      • 7
  • javaman
    5
    318
    • February 7, 2024 at 4:21 PM
    I got RDW1 in very good price already...
    Anyway if doesn't work i will have it as spare for other robot.
  • javaman
    5
    318
    • May 19, 2024 at 6:21 AM
    Ok tested krc2ed05 robot with rdw1 and kss 5.6.12
    and works.
    It will work with saferdw2 and standard esc-ci (not tech esc-ci) or saferdw2 must replaced with rdw2 to work with standard esc-ci?
  • javaman
    5
    318
    • May 21, 2024 at 10:54 AM
    • #11
    Robot gives me in T1 these alarms
    The following errors for A2 axis are thrown when jog the A2 back in a specific angle(very back near counterbalance) not in other angles maybe is the hard limit of robot so this is normal error.
    Can this be a cut power cable that in this angle looses contact ?
    1133 Gear torque exceeded axis A2
    1161 Ackn. monitoring of the actual velocity A2.
    Also these random errors for example when jog A3 or A6 axis after press for 60sec the dead mans button in kcp.
    1241 Ackn I-t mon. current limit of motor cable A2 after 60.0 s exceeded....
    1242 Ackn I-t mon. current limit of motor cable A2 after 60.0 s exceeded....
    Can all these errors be because rdw1 is not configured correctly for krc2 ed05 robot ?
    How can i configure correct rdw1 ?
    SkyeFire
    1,061
    9,461
    • May 21, 2024 at 3:29 PM
    • #12
    Quote from javaman
    The following errors for A2 axis are thrown when jog the A2 back in a specific angle(back near counterbalance) not in other angles.
    I don't think that's a cable issue -- the A2 motor doesn't move when A2 moves, only when A1 moves.
    It sounds more like A2 is getting excessive resistance at one end of the counterbalance stroke. The 1241 and 1242 errors happen when the motor needs excessive torque to maintain position over 60sec -- the amperage drawn by the motor isn't exceeding the motor's maximum-current limit, but is more than it should be for the robot's position and not settling.
  • panic mode
    1,297
    13,141
    • May 21, 2024 at 3:55 PM
    • #13
    the messages show that A2 is tripping due overcurrent... so THAT is the real issue.
    but it may as well be the RDW1 related problem. RDW1 has NVM/flash with rather limited number of writes. practically every single one that i have ever seen has reached and exceeded that write limit. so the data stored on RDW may not be correct. which is why controller checks if the data on RDW matches what is on the HDD. but if you made a mistake it could be that data from RDW is copied to HDD instead of the other way around. and then it would appear as "robot is working" but not right. and with wrong MADA everything is possible, even axes may move the wrong way. you may think you are jogging away from hardstop when your A2 is actually driven into the hardstop.
    RDW1 is old and not very smart. it requires each axis to be jogged some 40-50 deg to collect enough of data for calculating symmetry and offset.
    check if the MADA etc are correct for your robot type.
    driving the motor wrong way when axis is already at hardstop can and will cause damage. something has to give.
    try moving A2 away from hard limit using any means necessary. but be VERY careful to not get hurt since work on A2 can be very dangerous. not only it supports entire arm but it has counterbalance. this can kill you and arm weight combined with gravity and energy stored in the counterbalance are beyond what frail human bodies can handle.
    for example use crane or forklift to sling/support the arm, then remove motor or release A2 brake manually using 24VDC and move axis away from hard limit... or use manual release device (12mm socket wrench).
  • javaman
    5
    318
    • May 21, 2024 at 5:23 PM
    • #14
    I have replaced rdc1 with rdc2 and switched ksd48s between A2 and A3 and the following errors are the same they are due to hard limit so it is ok.
    The following errors are gone with rdc2
    So the problem is rdc1.
    When put rdc1 first thing to do is log on as Administrator in kss and set correct mada from hdd.
    So mada are correct.
    I have got some screenshots with rdc2 the offsets in rdc tool.
    Can put these offsets to rdc1?
    I want to use rdc1 because i don't have free spare rdc2 only rdc1 and saferdc2 witch works only with
    tech esc-ci3 and safeoperation tech package
  • panic mode
    1,297
    13,141
    • May 21, 2024 at 5:34 PM
    • #15
    Quote from javaman
    not necessarily... it is possible that data on the HDD is also for the wrong robot or have been modified. some modifications are common like when integrating external axes. some could be accidental.
    did you really check if the used MADA is really for this robot? did you compare it with factory MADA found on D:\... ?
    the offsets are specific to the used hardware (not just resolvers but also hardware on the RDC). since you are connecting to same motors, resolvers are the same but the RDC are different. if the two RDCs were the same type, the difference between them would be small but that is not the case here so i don't think that would help.
  • javaman
    5
    318
    • May 21, 2024 at 7:13 PM
    • #16
    I have read here in some post that someone configured resolvers with rdw tool.
    How can do this?
    Or is there any change to use saferdw2 with simple esc-ci
    without safeoperation tech package with some jumpers in saferdw2 pcb?
Similar Threads
  • KUKA KRC2 ED05 SAFE ROBOT BYPASS
    • rmzn81
    • January 23, 2020 at 7:22 PM
    • KUKA Robot Forum
