Which would be more correct, to use "IMSTP" or "EES" to connect HMI signal R30-iB?
  • Leviafun
  • February 5, 2024 at 7:21 AM
  • Leviafun
    17
    Hello friends!
    I want to connect the physical Emergency stop button from the operator's workplace with HMI panel.
    Initially, I thought to connect UI[1] (IMSTP), UI[2](Hold), UI[3](SFSPD) through the HMI and use the EES1 EES11 EES2 EES21 signals from E-STOP BOARD (figure 1) to connect the button (At the moment, there are just electrical jumpers on the E-STOP BOARD)
    But after some thought, I began to doubt - maybe it's worth connecting only UI[1] (IMSTP) to the E-STOP button from physical robot output module (), instead of sending it via tcp/ip.
    Is it safe enough? In this case, EES is not used.
  • gustavxb
    14
    • February 5, 2024 at 8:45 AM
    Imstp, Hold, Sfspd and Enable are not safety rated Inputs so should not be used with the safty circuit or as safety.
    EES should be wired if you don't have a safety bus.
  • gpunkt
    120
    457
    • February 5, 2024 at 11:03 AM
    Just use the designated safety inputs for external emergency stops on TBOP13?
  • Leviafun
    17
    • February 7, 2024 at 3:23 AM
    Quote from gustavxb
    Thanks, the most confusing thing was that my paper manual says: "IMSTP - this signal determines an emergency stop controlled by the system".
    As I understand it, these are different categories of ESTOP.
  • Alihan Yilmaz
    21
    • February 7, 2024 at 7:39 AM
    hello
    There are several ways to connect emergency stops. Do you want to cut off all outputs instantly ?
    And do you have safety plc ?
  • gpunkt
    120
    457
    • February 7, 2024 at 8:41 AM
    Quote from Leviafun
    This has nothing to do with Emergency Stop.
    From the R-30iB Plus manual:
    All things related to machine safety (not meaning "do not injure the mechanical unit", but "do not injure humans") needs to be safety rated.
    The UOP-signals are only "normal" digital signals, not safety signals.
  • Leviafun
    17
    • February 8, 2024 at 4:23 AM
    Quote from gpunkt
    I've already figured it out, thanks guys.
    It is a translation error in the localized manual
  • Emergency Stop
  • R30-iB plus
