Dear Colleagues,
I will be involve in a project, where FANUC robot SR-6iA (30 kg) will be used.
On the robot wrist, automatic screw feeder and screwdriver (most probably supplied by Atlas Copco) will be installed.
My question related to movement strategy to be used for screwing the screws.
The movement speed of the robot arm at the stage of screwing, obviously will be calculated by the step of the screw thread. Is that correct?
The number of threads and the step will give the total movement length. The number of turns (the turns will be set into the software/controls system of the screwdriver) will give the speed (mm/s).
One of the thing, which bothers me is the start of screwing stage and the screwing stage itself. At the begging, when the screwdriver is started, the move down must be slow, and next, when the screwdriver reach nominal revolutions, the move down should be increased - this is my understanding.
Should this robot movement must be determined on trial and error approach?
Or probably I too complicate the task?
Can you share your experience for such screwing projects?
And advices will be highly appreciated!
Reagrds,
Svetozar Yolov
