Sorry to repost (previous post was marked resolved but was not).
I’d like to use the RI/Os to control a 24VDC solenoid. I have a CRX10 and R30iB Mini plus cabinet.
I have the 24V wire from my solenoid to port D03 on the JRM19 and Solenoid Ground to 0V on JRM 19. Looks like I need to connect an external 24VDC power supply to the cabinet to power my device based on the manuals.
To connect the external power supply, should it be done as:
Power supply 24V – to both D0SRC1 ports on JRM19
Power supply GND – to both DICOM1 and DICOM2 on ports located below CRMC23 (I believe this would be CRMC24 but I don’t see it labeled on the board).
Then to toggle the D03 to turn on and off the solenoid, do I just toggle R03 under the RI/Os on the teach pendant?
Thanks in advance
