Hello While the robot is welding, sometimes there is a deviation from the exact welding point we want due to shrinkage and low amperage.
Is there an option to instantly correct the robot's position in x, y or z while it is in play mode?
For example, when going between two points, we want to give +1mm in x in the middle of the two points.
Pam function unfortunately did not work
Thank you
