I have ABB IRB 2400L m98
I have connected my welder to the system and also declared arc_Ok signal (arc supervision)
And my question is:
Should arc_Ok signal be stable during the welding?
Due to welding process it is not stable, my arc_Ok signal can drop by a 0.1 - 0.2 seconds
Welding process stops with Arc supervision error 110023
Are there any parameters to be set for "delaying" Arc Supervision error?
In the ArcWare manual I found arc_ok_delay parameter . But as I understand it works only at the start of welding process ( it waits number of seconds before the arc stabilises)
But I have not found any similar parameters during welding process.
Thank you!
ABB Arc Supervision problem
PaulSola -
November 8, 2023 at 3:28 PM -
