I am attempting a repair of a Yaskawa GP7, and one of the steps is to remove the ME075N2-A seal. I can't see any non-destructive means of doing this.
Has anyone attempted this before? If so, how should I approach this removal?
Thanks,
Thanks,
Looks like you can get away with only pulling the right seal. However, it appears the seal is not intended to survive the removal process as the procedure calls for a new seal to be installed during reassembly. You could try using a seal puller, but it will probably damage the seal. The new seals are around 60 bucks each and are in stock.
