Path Frame
  • fanucfan
  • October 26, 2023 at 3:28 PM
  • fanucfan
    I noticed that there is a 'PATH' option when cycling through coordinate systems on the teach pendant. I have not seen any mention of an accessible path frame in any Fanuc manuals. Does the 'PATH' coordinate system pertain to the path frame for a given weld?
    It just so happens I am looking for a way of obtaining a path frame in Karel. Is there any way I can use this 'PATH' to get the path frame at a certain position during a weld?
    Thank you!
  • MOM October 26, 2023 at 3:59 PM
    Approved the thread.
  • pdl
    272
    1,549
    • October 26, 2023 at 6:29 PM
    What version of controller are you using?
  • fanucfan
    • October 26, 2023 at 7:31 PM
    I am on V9.40P/45
  • retobor
    18
    207
    • October 27, 2023 at 1:54 AM
    PATH frame is a function of ArcTool, and only ArcTool. So, you likely looking in the wrong manual.
    PATH is mentioned in section 4.3.7 of MAROBAR8304141E REV H (ArcTool Setup & Ops.)
    You might be able to pull PATH frame from system variables. However, from my understanding, PATH frame is only created at the instance the program is paused.
    Maybe LPOS motion instruction would work better, as a suggestion. Not sure what you intend to do.
Similar Threads
  • Need Help Creating an Array Program, Anyone Have Examples?
    • cnseitz
    • May 2, 2023 at 4:43 PM
    • Fanuc Robot Forum
  • How transformation is calculated when base is switched
    • kiwasuse
    • February 3, 2023 at 12:57 AM
    • KUKA Robot Forum
  • Does anyone have the Staubli TX60L XML file or the URDF file that can open in Matlab simscape?
    • h8476532
    • November 21, 2022 at 12:39 AM
    • Stäubli & Bosch Robot Forum
  • Convert spatial coordinates into specific robot programming language
    • Askic
    • October 27, 2022 at 12:18 PM
    • Robot Geometry, Linear Algebra, Forward and Inverse Kinematics
  • Position of touch
    • PavelB
    • July 8, 2022 at 8:43 AM
    • Fanuc Robot Forum
  • Vision Programming NiryoOne
    • astabc34
    • June 6, 2022 at 9:39 AM
    • other Cobots
  • Mirroring a robot program
    • David_
    • November 9, 2021 at 4:45 PM
    • Fanuc Robot Forum
  • KRC2 palletiziing robot doing different movements in step by step mode than in continuous mode
    • robotecnik
    • May 7, 2020 at 6:57 AM
    • KUKA Robot Forum
  • position
  • frame
  • path
  • frames
  • target
  • Tool frame
