Workvisual connection bug?
  • akaaschool
  • October 4, 2023 at 5:53 PM
  • akaaschool
    17
    I have a KUKA KR30-3 (70114) and KR60-3 (70115) in one cell both with KRC4 controllers which were running 8.3.17 and I just updated them both to 8.3.19 which I believe has caused this error.
    I am using WorkVisual 6.0 but this also wasn't working correct on WorkVisual 5.0.
    I can ping both the robots correctly from the PC that I am running WorkVisual on both their IP addresses, 10.0.0.151 and 10.0.0.152, but when it comes to opening WorkVisual and going to "Browse", it is only ever reliably showing one robot/controller or the other, never both like it used to. I cannot find a way to have both 70114 and 70115 in the browse window at the same time, even if I do the little search icon and enter the IP addresses manually. Is there something obvious I am missing? Or is this just a WorkVisual bug and I should just reinstall it?
  • panic mode
    1,297
    13,141
    • October 4, 2023 at 7:01 PM
    any reason you are not mentioning FULL network settings of all three nodes? (two robots and PC)
    you can also compare current KLI settings with the old ones (before KSS upgrade). this can be found in archive, WoV project and HDD image.
  • akaaschool
    17
    • October 4, 2023 at 7:04 PM
    Apologies, what details do I need to add for the FULL network settings?
  • panic mode
    1,297
    13,141
    • October 4, 2023 at 7:06 PM
    for robots that would be KLI config.
    for PC that would be info obtained by command line IPCONFIG /ALL
    and since this used to work, the best option would be to compare KLIConfig files before and after migration.
  • Hes
    42
    243
    • October 5, 2023 at 11:05 AM
    do you need subnet mask to be 255.255.0.0? Have seen the same myself on a kss 8.5.xx but setting subnet mask to a more limited space sorted it out for me.
  • Hes
    42
    243
    • October 5, 2023 at 11:08 AM
    also latest version of kss 8.3 i got was 8.3.43 so there are alot newer versions if you are considering updating kss again
