When I plug the usb to the cabinet and the teach pendant recognized the USB. But when I tried to create dir, it said device not ready. How could I resolve this issue? Thank you. I tried different USB but still same issue.
What kind of controller and version?
What size USB drive?
How is it formatted?
Have you tried formatting it in the Fanuc controller?
How many files are on the USB drive? It matters. Make sure you use a blank USB.
Fanuc robots do not like big pendrives to do backups, the best you can do buy usb drives of 128mb/256mb capacity, this memories work 99% of the time.
I've purchased a pack of 10 about 3 years ago, and all of them worked 99% of the time.
I still have them and they still work perfectly fine, using them almost every day.
The only times the backups failed wer:
If you have a memory with 4gb of capacity or less I suggest you to try it, more than that and it can give problems or the system may freeze while reading the contents.
I always use 8 and 4 Gb Sticks, never had issues with them, 32Gb has not worked for me. And i always format the USB Stick to FAT32, I'm not sure which filesystems Fanuc supports but FAT32 works for me.
